If you every get st...
[Closed] If you every get stranded and your phone is about to die...
Cut'n'paste from elsewhere but seems like a reasonable idea in an emergency
If you are ever lost while hiking, get stranded with a broken down car, etc... and you notice your cell phone is either low on juice or has no signal, here is a tip that very well may save your life.
Change the voicemail on your phone to a message that gives your approximate location, the time, the date, your situation (lost, out of gas, car broken down, injured, etc...) and any special instructions such as you are staying with the car, you are walking toward a town, etc.... The best part of this is that even if your cell phone dies or stops working, voicemail still works, so anyone calling your phone looking for you will hear the message and know where to find you or where to send help.
Posted : 25/10/2021 11:35 pm
If I have no signal I can’t change my voicemail message……
I’ve seen this posted a few times on fb and I’m not sure this is great advice. If I was in that much trouble I’d rather use my last 1% battery to send someone a text and phone 999.
Posted : 25/10/2021 11:45 pm
Mountaineering Scotand are saying to ignore the advice in the OP.
[url= https://i.postimg.cc/3w58WDw6/Screenshot-20211025-230422.pn g" target="_blank">https://i.postimg.cc/3w58WDw6/Screenshot-20211025-230422.pn g"/> [/img][/url]
Posted : 26/10/2021 12:06 am
Text your what 3 words position to 999.
Posted : 26/10/2021 12:35 am
Make sure you register first though
https://firstaidtrainingcooperative.co.uk/can-i-text-999/?amp
Edit: it’s actually been developed for deaf people, but I guess there’s no reason it can’t be used by anyone unable to make a call.
Posted : 26/10/2021 12:38 am
That advice is viral guff. Please ignore it and please don’t share it. Mountaineering Scotland have shut this down with their accurate, expert statement.
You need a signal and battery to change your voicemail message. You are much, much better off using that to call or text 999 or another reliable contact.
Posted : 26/10/2021 12:40 am
1) I don't have a cellphone, I'm not American.
2) How do you propose to change the voicemail when you're out of signal?
3) 999 works across all carriers, even if you're out of regular signal it could still work.
4) Tell someone where you're going and when you expect to check back in. They can raise an alert if you can't.
No no no. What Three Words is evil. Absolutely no emergency services will advise you to use it, it's not fit for that purpose.
Also, texting 999? You can set this up but it's really for accessibility issues like folks who are deaf. You'd need to provide actual details in an emergency, randomly texting "frog herringbone gremlins" ain't gonna do squat.
Posted : 26/10/2021 12:50 am
^^ or, what Frank said.
Posted : 26/10/2021 12:51 am
There is a place for W3W but do us a favour and download OS locate. You can get grid ref and share it via sms without need for data. It’s quick, reliable and free. Send a W3W to MRT and it will only end up being converted to grid ref anyway.
Posted : 26/10/2021 12:57 am
 Aidy
I'd have to be *really* desperate to rely on telemarketers to come to my rescue.
Posted : 26/10/2021 12:59 am
You could just ignore unknown numbers in case it's the rescue team trying to find you
https://www.theguardian.com/us-news/2021/oct/26/hiker-lost-on-us-mountain-ignored-calls-from-rescuers-because-he-didnt-recognise-the-number?CMP=Share_AndroidApp_Other
Posted : 26/10/2021 7:08 am
I do a lot of remote solo riding and kayaking. I ended up buying a SPOT tracker. They are not 100% because they do not work under heavy tree cover, but that is my emergency backup device now. You do need an ongoing contract but it probably works out pence per trip for me over the year.
Posted : 26/10/2021 7:58 am
And yet strangely some of them do, but we've already done that to death.
Posted : 26/10/2021 8:22 am
No no no. What Three Words is evil. Absolutely no emergency services will advise you to use it, it’s not fit for that purpose.
If that's what you've got, then use W3W. The emergency services will take whatever you've got, and most (if not all) call centres can locate you using it.
Posted : 26/10/2021 8:30 am
Was on an outdoor first aid course at the weekend - we were told this -
Rather than dialling 999 from your mobile, dialling 112 is better (from a mobile). 112 will connect your phone on any available network (not just your own) to help get the call through to emergency services. Apparently if the network is busy, it will also prioritise the 112 call over anything else trying to use the network (so when network frees up, it will connect a 112 call first).
What 3 Words does work, but isn't as quick as grid co-ordinates (something like OS Locate on your phone works well for grid coordinates). W3W also needs to be centred on your device each time you open it - it doesn't seem to locate your position immediately but shows your last position when you used W3W last. The emergency services person you have connected to may not have the ability to convert the W3W reading to coordinates so will then need to get them converted to get the call raised.
I suspect in reality 999 or 112 will work for almost all the times it is required; likewise, W3W is probably also good for most cases (just hope you don't have any plurals!), but the course was covering what could be done to speed up rescue and avoid confusion.
Posted : 26/10/2021 9:14 am
I thought that 999/112 thing had previously been discounted too.
Posted : 26/10/2021 9:17 am
nickc is spot on, a search manager will be delighted at any information received whether it's W3W or OS or whatever is available.
What 3 Words does work, but isn’t as quick as grid co-ordinates (something like OS Locate on your phone works well for grid coordinates). W3W also needs to be centred on your device each time you open it – it doesn’t seem to locate your position immediately but shows your last position when you used W3W last. The emergency services person you have connected to may not have the ability to convert the W3W reading to coordinates so will then need to get them converted to get the call raised.
The speed issue is a red herring, MRT deployment isn't quick, people have jobs/families and have to travel to an agreed RV point, my search manager would have a W3W point converted to a grid reference before I'm even out the street.
As Scotroutes says, I'm sure the 112 thing has been debunked.
as per the opening post, I'm pretty sure you'd have to be very lucky for that to work.
Posted : 26/10/2021 9:27 am
112 depends on what is programmed in your sim. TBH it makes no sense to use 112 over 999 on a UK sim.
Posted : 26/10/2021 9:28 am
I think the moral of the story here, WCA, is don't ever, for any reason, suggest anything, to anyone, for any reason, ever, no matter what, no matter where, or who, or who you are with, or where you are going, or where you've been, ever, for any reason whatsoever, because the know-it-alls will shoot you down in flames.
Posted : 26/10/2021 9:29 am
Was on an outdoor first aid course at the weekend – we were told this –
Hope you didn’t pay for it 😀 What other urban myths did they pass off as fact? 🤔
more constructively - don’t believe anything you read on FB 😂
112 or 999 work, no difference.
https://www.gov.uk/guidance/999-and-112-the-uks-national-emergency-numbers
Posted : 26/10/2021 9:32 am
I think the moral of the story here, WCA, is don’t ever, for any reason, suggest anything, to anyone, for any reason, ever, no matter what, no matter where, or who, or who you are with, or where you are going, or where you’ve been, ever, for any reason whatsoever, because the know-it-alls will shoot you down in flames.
I don't think anyone is really shooting anyone down, but if there's nonsense being spouted by folk on Faceboak, then it needs called out, but more importantly, the right way to do things offered instead.
Posted : 26/10/2021 9:35 am
I don’t think anyone is really shooting anyone down
Is it the first thing I'd do? No
Is it worth knowing as a 2nd/3rd/whatever layer of backup? Yes
Posted : 26/10/2021 9:38 am
randomly texting “frog herringbone gremlins” ain’t gonna do squat.
“Here is a precise what3words address, made of 3 random words. Every 3 metre square in the world has its own unique what3words address.”
https://w3w.co/frog.herring.gremlin
///frog.herring.gremlin
As close as I could get it😅
Posted : 26/10/2021 9:43 am
Same for me but with the Garmin InReach. Not had much use this last year though.
Posted : 26/10/2021 10:04 am
I don't use voicemail and have no idea how to set a message - in fact no one I know uses voicemail
What 3 words is very second best to a grid reference
Posted : 26/10/2021 10:07 am
Inreach here too, expensive but work bought me it for a charity trek, I pay the monthly fee. Good for keeping my wife updated that I'm safe when doing multi day stuff, and the ultimate hope-you-never-need-it SOS button too.
There is one that doesn't have a monthly fee, fast find 220, but it's SOS only, may suit some folks better.
https://marinestore.co.uk/Merchant2/merchant.mvc?Screen=PROD&Product_Code=cs11060-c&msclkid=27b1a01bd1da13dd8285c16c66f759d0
Posted : 26/10/2021 10:08 am
I'm slightly stunned that the Myth of 112 is still alive and well.
112 = 999. End of.
Posted : 26/10/2021 10:22 am
Of course, but lots of folk have it (my daughter for instance) and are familiar with it and it's easy to use and couldn't give an operator a grid reference. Bear in mind that the first thing the emergency operator might ask for is a postcode. We've done this argument to death, if you want to use Grid or Lat-Long go ahead, there's nothing to stop you, and whatever one's own feeling about how a business conducts itself, who cares about that when it could mean the difference between being found quickly or not?
Posted : 26/10/2021 10:29 am
you might as well shout at the wind as leave me a voicemail.
IF its important you'll call back - most likely people leave the message AND call back which is an irritant
IF your phone goes to voice mail - ill hang up and try again later - People know you called - their phone tells them you called.
if its something im willing to leave in a message ill text it.
LAst time i needed an MRT - it was at fords of Avon - a german tourist with what looked to me to be either dislocated or broken ankle(blue foot , lots of swelling and at a jaunty angle) . Between us we had three phones on three different networks - not one of us got signal before we got to linn of dee(my works phone has had signal in the middle of the karokuram desert and in the middle of the black sea yet ......cairngorms foxed it) - and the phone at derry lodge had been vandalised as per standard issue (Those people if caught should be castrated)
- we left Fords of Avon (and the IP) at 9am on bikes MRT were alerted by 10.30. The IP was extracted at 6pm.
Posted : 26/10/2021 10:33 am
The chat about W3W is predicable and has been done. I've posted on it extensively before and would be happy to do so if the debate demands it. W3W is fine but OS locate is better. I'd still recommend having W3W on your phone though in case the call handler asks for it (as they are now known to do)
This new chat about Voicemail is just silly. If you have signal and battery use it to call for help, don't waste it on voicemail.
112 / 999, doesn't make the slightest jot of a difference.
If you want to speed things up and help the process along, the one thing you can do that you probably don't realise will make a big difference (but does) is to make sure when you call 999 / 112 make sure you ask for Police / Mountain Rescue rather than asking for Ambulance.
Posted : 26/10/2021 10:34 am
Of course, but lots of folk have it (my daughter for instance) and are familiar with it and it’s easy to use and couldn’t give an operator a grid reference.
I appreciate that this has been done to death, but the "but W3W is easy" thing doesn't really wash, as it's just as easy to have an app that'll give a grid reference. I've got one, called Grid Reference, it's tiny (2mb!) and free.
Posted : 26/10/2021 10:35 am
but W3W is easy
spelling three separate words letter by letter over the phone to ensure 100% accuracy of W3W is not as easy as reading an OS Locate GR such as NT 654 786.
Locally though I know our control rooms (ambulance and police) seem very determined to get W3W off a caller, even when this means them talking the caller through the process of downloading the app whilst running out of battery on a windy wet hillside! Therefore, whatever your thoughts on the merit of it, it is still worth having W3W in case you are asked for it.
Posted : 26/10/2021 10:54 am
Mleh, I'm completely agnostic when it comes to location devices on my phone, I've got everything from W3W to Lat Long (apple compass)  to Grid (OS locator.) Hell, sometimes I've even got a paper map with me. Whatever folk want from me I can give it to them.
Spelling three separate words letter by letter over the phone to ensure 100% accuracy is not as easier than reading a GR such as NT 654 786.
(imaginary scenario) "Was that 654 or 564, can you repeat it for me, you're breaking up..." EVERYTHING has an upside and a downside. For folk who're unfamiliar with what a Grid or Lat-Long is then you may as well ask in Urdu.  Whatever your own personal feelings are, or your own experience is, great. Other people (shocking I know) have different views. I will guarantee you that my daughter can fire up and give you a W3W location faster than you can give anyone a Lat long. Mostly because like most young folk, she has better FPF (fast phone fingers) than you do.
TL;DR: whatever works for you, use that.
Posted : 26/10/2021 11:10 am
Final thought on the matter, irrespective of what location platform you use, most MRT will send you a PhoneFind or SARLOC SMS message anyway. This will prompt you to share your location via SMS. Just make sure your phone GPS is on and grant permission . In most cases, this will then be the single source of truth for the troops coming to get you (assuming that you are in the same place as the casualty).
Posted : 26/10/2021 11:27 am
What Frank said (I believe there's some kind of GDPR requirement to ask your permission to use your location, crazy - yes, but there you go).
Posted : 26/10/2021 11:35 am
I don’t type. Open app click share and send. What’s not to like?
https://w3w.co/quarrel.adopt.blur
///quarrel.adopt.blur
Is what goes into a message.
Posted : 26/10/2021 12:15 pm
Exactly the same as OS locate then.
Posted : 26/10/2021 12:21 pm
How do you do that with a police or ambulance control room call handler?
Posted : 26/10/2021 12:26 pm
 Aidy
But... the *whole point* of w3w was that it was easier to dictate. If you're sharing a location using an app, then *any* other coordinate system is just as good. Better, in fact, as not reliant on a closed-source service being available.
Posted : 26/10/2021 12:29 pm
No, the whole point of W3W is a location device. How you transmit that information to a third party is totally irrelevant. I get that people don't like the closed nature of the code an' all. But who gives a **** when people are lost on the hillside and they've no idea what a Grid Ref is or how to read a Lat-Long? And people in the actual emergency services have repeatedly said on threads like this is that they'll take whatever information they can get.
It seems to me that people have taken offence to it, and that's fair enough don't use it, but for people for whom it's going to be useful because they can understand it why put them off just because you have a personal beef about it. It's stupid.
Posted : 26/10/2021 12:40 pm
I assume W3W may be very helpful to someone who suffers from Discalculia?.
Posted : 26/10/2021 12:43 pm
I’m slightly stunned that the Myth of 112 is still alive and well.
I remember on a first aid course years ago when the tutor seemed to be suggesting that 112 was some sort of magic number that would connect even if you were in a cave/underwater.
I'm still not sure if he was confused by the thing about *your* network having no signal but it might be able to pick up A.N.Other network and use that or if he genuinely thought it would work at the bottom of a mineshaft.
Posted : 26/10/2021 12:45 pm
I think the original post information is more relevant for large areas OZ outback parts of America parts of Africa. Where phone signal is bizarrely good (as it's cheaper to erect masts that lay cable, I was in Zambia and everyone had two mobiles but no-one had a landline). For UK MTN rescue not so good.
The original post I saw certainly seemed to apply to a broken down in the outback scenario.
Posted : 26/10/2021 12:46 pm
And people in the actual emergency services have repeatedly said on threads like this is that they’ll take whatever information they can get.
I've been one of those people. I also said that a high percentage of W3W locations I get are wrong, nearly always as a result of spelling errors. Caller - Police Call Handler - MRT means more than one opportunity to get it wrong. Sometimes the error is obvious, sometimes not. OS Locate GR is easier to read over the phone and doesn't rely on a call handler being able to spell (and very often they cannot spell).
But hey, any location tool is better than the olden days and will always be backed up with PhoneFind message.
Posted : 26/10/2021 12:48 pm
I’d text it to someone else or 999. If low battery the last thing I’d do is call.
Posted : 26/10/2021 12:51 pm
If you want to speed things up and help the process along, the one thing you can do that you probably don’t realise will make a big difference (but does) is to make sure when you call 999 / 112 make sure you ask for Police / Mountain Rescue rather than asking for Ambulance.
I'd debate that if you have a casualty in serious condition (could die fairly soon) which you are certain of location and it's accessible then ambulance gets the air ambulance in the air quicker. Which gets a well equipped trauma team to you faster. Obviously only really works where there is an air ambulance service, not to be wasted on non life-threatening injuries. So in lakes/ remote Scotland I'd go police/MRT.
Yes it's based on being in a real incident. The guy survived, still has his leg, and a family still has a dad. The air ambulance was scrambling before I had finished phonetically spelling the W3W after giving grid.
The voicemail idea is pretty poor way to spend your last bit of battery and phone signal.
Posted : 26/10/2021 12:52 pm
 Aidy
But... it's not. What you send depends on what methods you have available to send it with.
Posted : 26/10/2021 12:54 pm
Where do they get this shit from?
112 and 999 are functionally identical. The only reason 112 exists in the UK is for the benefit of European travellers who may be more familiar with that number than ours. The notion that there's a "secret" emergency number that's better than 999 is flat-Earth levels of bollocks.
No, the whole point of W3W is to make money for its creators.
Posted : 26/10/2021 1:42 pm
What methods do you have other than "a phone"?
Posted : 26/10/2021 1:43 pm
As an aside if you're in Shetland (probably Orkney too) and away from the roadside ask for Coast Guard if you're unlucky enough to need them. They deal with everything a standard ambulance can't get to.
And get registered with Emergency SMS service on your phone.
Posted : 26/10/2021 1:46 pm
Alright, random example.
PhoneFind. Mature technology. Widely supported by emergency services. Works off mobile triangulation. Emergency services send you an SMS, you click the link, they know where you are. Requires healthy phone reception, that's it.
SARLOC. Mature technology. Widely supported by emergency services. Works off GPS. Can be SMS-triggered as above but requires Internet access. Can be used without a data connection if you have the app installed.
W3W. Technology in its infancy. Considered by most emergency services to be not fit for purpose. Requires phone signal, GPS, Internet connection, the app to be installed, W3W's servers to be operational, the recipient to pay for API access, manual communication, and the caller to be conversant in the local language because the system's entire schema changes between languages.
Posted : 26/10/2021 1:59 pm
 Aidy
What methods do you have other than “a phone”?
If you have data, and charge, then you might send some kind of live tracking link. That way if you need to move for safety/shelter, people have better odds of finding you.
If you're in a really patchy signal area, you might only be able to get an sms out.
Although, if you're sending any kind of text message, it really doesn't matter what kind of coordinates you send. Personally I'd go for OS grid if I wanted mountain rescue - I figure they'll be using OS maps to find me. Perhaps lat/long otherwise, as you can put it into pretty much anything.
If you're trying to talk over a patchy voice connection, I might consider w3w.
But yeah, the point really was that extolling w3w because you could click a button to send your location via a text messaging thing was weird - you can do the same with any other coordinate system.
Posted : 26/10/2021 2:03 pm
 poly
I think you misunderstood the instructions and premise of the OP. The “advice” is to change your own voicemail message from “this is poly, leave a message after the beep” to: “this is poly, I’m running late but at 4pm I’ve reached the summit of Ben Nevis, and aiming to return via the tourist path, my battery is low and if you still can’t get hold of me after 7 you may want to call for help”. For those of us on bikes, it may be saying “I’ve had a mechanical so walking out and will be much longer”.
I don’t think it’s a genius piece of advice as anyone who has the wherewithall to change their voicemail message probably has a contact they could specifically message (or indeed left details with before they went). If you don’t have that person then you probably don’t have anyone that will either try calling or report you overdue so the police trying calling you!
Posted : 26/10/2021 2:12 pm
Telling people about its existence also has the advantage of getting UK travellers used to the European number.
Posted : 26/10/2021 2:22 pm
The advice to change your voicemail message also relies on the caller a) not terminating the call as soon as voicemail picks up and b) actually listening properly to the message.
Can just imagine a concerned person checking up and cutting it off as soon as vociemail picks up saying "ooh, he's still not picking up, I hope he's OK!"
Posted : 26/10/2021 2:25 pm
yep I do this 😂 can’t remember the last time I left a voicemail or even listened to the message. I just ring off immediately and shoot them an iMessage/WhatsApp because then you actually know when they’ve got it.
Posted : 26/10/2021 2:28 pm
exactly my thought process hence why leaving me a voicemail is as good as shouting at the wind.
now extrapolate that through anyone younger than my self - and it seems quite a number of those older than me .... and you are left with the telemarketer automated calls, the ghostbusters and the 5 people who use voicemail coming to your rescue.
the theorys good but its about 20 years late.
Posted : 26/10/2021 2:37 pm
 irc
Carry a small power bank around 120g. And most importantly have your phone in a waterproof bag. He says after destroying a phone in a wet day's hillwalking last Saturday.
Posted : 26/10/2021 2:49 pm
after destroying a phone in a wet day’s hillwalking last Saturday.
What phone? Many are waterproof these days - a fact I have relied upon for the last two years
Just wondering if yours has failed to live up to its advertised IP rating?
Posted : 26/10/2021 2:55 pm
 poly
I’d debate that if you have a casualty in serious condition (could die fairly soon) which you are certain of location and it’s accessible then ambulance gets the air ambulance in the air quicker. Which gets a well equipped trauma team to you faster. Obviously only really works where there is an air ambulance service, not to be wasted on non life-threatening injuries. So in lakes/ remote Scotland I’d go police/MRT.
Sometimes that might bring you an advantage but not always. An air ambulance needs to land, in areas with active MRTs that is often not trivial for a helo. The crew need to get the casualty from where they are into the back of the helo - which will be at least a short distance away, and likely over awkward ground. It’s not uncommon for the MRT to turn up on foot to help package and transport the casualty the 100m to the spot the pilot was happy with. Air ambulances have other limitations (like being on another job, being on the way back from another job and needing to refuel, weather conditions they can’t fly in, some don’t work at night, etc). And there’s a natural tendency by the ambulance service to try to deal with a call themselves first. So if either the call handler doesn’t appreciate a helo is needed or it’s not available you are likely to get a land crew of two people deployed in the first instance to work out what’s needed… the police mostly know they can’t deal with this shit themselves so will look to get help early.
Posted : 26/10/2021 3:01 pm
PhoneFind. Mature technology. Widely supported by emergency services. Works off mobile triangulation. Emergency services send you an SMS, you click the link, they know where you are. Requires healthy phone reception, that’s it.
Not quite accurate. PhoneFind uses the phones GPS, not triangulation. It is the same at SARLOC.
Posted : 26/10/2021 3:11 pm
now extrapolate that through anyone younger than my self – and it seems quite a number of those older than me …. and you are left with the telemarketer automated calls, the ghostbusters and the 5 people who use voicemail coming to your rescue.
Our search managers are all over mid 50's at least (generally team members who have done their 20 years out searching for folk in all weathers, and have fantastic experience to use as SM), will attempt to call a missper, and will leave a voice message on the off chance that the person has powered their phone down - which has been done in rescue situations (mentioned quite a few times in Cairngorm John - missper has little power left on phone, and is told to power phone up at certain time intervals).
I'm not saying that it's any kind of standard to pin hopes on, but it's not entirely unfeasable to say it wouldn't ever work.
What phone? Many are waterproof these days – a fact I have relied upon for the last two years
I've killed 2 phones this way, a 6 year old samsung that basically lost it's waterprrofing over time, and a year old motorola that wasn't advertised as IP68, hey ho in both situations.
Posted : 26/10/2021 3:13 pm
 poly
W3W. Technology in its infancy. Considered by most emergency services to be not fit for purpose. Requires phone signal, GPS, Internet connection, the app to be installed, W3W’s servers to be operational, the recipient to pay for API access, manual communication, and the caller to be conversant in the local language because the system’s entire schema changes between languages.
@cougar
I’m not here to defend W3W but some of what you said is misinformation.
Whilst some emergency services have raised valid concerns about W3W errors it’s misleading to say “most emergency services think it’s not fit for purpose”
It does require gps - as does sarloc, but there can’t be many places where you can get cell phone signal and not at least get partial gps coverage? There’s a bias in the tone of how you wrote the this need for sarloc and W3W.
However if you have it preinstalled you don’t need an internet connection. The recipient will need W3W servers to be live to interpret it - but do sarloc not have any servers that might go down? The recipient does not need api access just a browser with an internet connection. In contrast for someone to initiate the sarloc request they need to be set up in advance.
The main risk with languages is misspelling/mispronunciation- I believe l you can send foreign words and it works for the recipient? The risk of miscommunication with foreign language / accents doesn’t go away with OSGB or Lat/Lon when spoken.
I assume phone find is only really helpful if you are in range of at least 2 masts? Given often I’m not in range of 1 that seems likely to be a weakness?
Posted : 26/10/2021 3:23 pm
If you’re in a really patchy signal area, you might only be able to get an sms out.
If you’re trying to talk over a patchy voice connection, I might consider w3w.
That being the case, W3W wouldn't work as it requires access to their servers.
Does it? I sit corrected if so. Does it use both, maybe? I was sure it worked off cell masts.
Posted : 26/10/2021 3:34 pm
I may well be wrong but I'm not intentionally misleading.
Posted : 26/10/2021 3:36 pm
 Aidy
That being the case, W3W wouldn’t work as it requires access to their servers.
Yes, sure - that wasn't my point though. My point was that the transmission mechanism was entirely relevant to the format in which you send your location. Claiming otherwise is silly.
Posted : 26/10/2021 3:39 pm
 irc
Samsung Galaxy A8. IP68 rated.
IP68 is wateerproof for 30 minutes. It was it the top pocket of my rucsac for about 3 hours in driving rain.
On the plus side it was 3 years old. Survived numerous other hillwalking trips and cycling outings with light rain.
Cost about £250 so not a disaster after 3 years use. But waterproof ziplock type case.
Posted : 26/10/2021 4:11 pm
Yep, Phonefind sends a GPS generated 8 fig grid reference with accuracy comment in format of +/- ?m's.
Posted : 26/10/2021 4:31 pm
Are Mountain Rescue using this version yet?
https://www.fourkingmaps.co.uk/
Posted : 26/10/2021 5:09 pm
Again - not to defend/promote any service but this is more misinformation. W3W uses an algorithm to calculate the words. No internet service / server access required as it's all done in your phone.
Posted : 26/10/2021 5:21 pm
 poly
No that's actually the advantage of any preinstalled solution over Sarlock etc - the latter requires you to have good enough signal to receive a text message, click on a link and then open a webpage, and have credit for the data connection. If already installed W3W allows you (with no data connection) to open the app and send a text message (or read the words) from the screen. Other solutions allow you to do much the same with OSGrid or Lat/Lon etc, they are marketed less successfully (aggressively) and may not be quite as nice to use, and may suffer from similar transcription errors if you read enough digits for the same precision. However with W3W the recipient does need an internet connection to convert to a real world position - in most cases that will not be a problem as they'll be sitting in a building somewhere with an internet connection.
To me the advantage of W3W is not actually for calling the emergency services. Its for me calling/texting my wife (or my kids calling me) and being able to say - I'm at xxx.yyy.zzz I've tacho'd my wheel and carrying my bike out can you meet me at aaa.bbb.ccc and give me a lift?
Posted : 26/10/2021 6:39 pm
 Aidy
To me the advantage of W3W is not actually for calling the emergency services. Its for me calling/texting my wife (or my kids calling me) and being able to say – I’m at xxx.yyy.zzz I’ve tacho’d my wheel and carrying my bike out can you meet me at aaa.bbb.ccc and give me a lift?
I just use google maps pins, so they can just click it and go "navigate to".
Posted : 26/10/2021 6:53 pm
chauvinism
secede
veterinarian
pseudonym
paraphernalia
clairvoyant
ratatouille
adjournment
hierarchy
acquiesce
tithe
etiquette
parochial
idiosyncrasy
prerogative
fuchsia
macaque
baccalaureate
How many would you get in a spelling test? All of these are in the w3w dictionary
Posted : 26/10/2021 7:09 pm
I'd probably just hit "send location" in what's app these days
Posted : 26/10/2021 7:10 pm
I agree, it's a fine call and either way getting a call in to one of the services matters to get help moving.
In my case the MRT took 30 mins longer than the air ambulance to get to the casualty the air ambulance had more gear to stabilise and a trauma surgeon. They also made the call to mobilise coastguard helo support within a few minutes of arrival, again saving time. That said it's one set of particular circumstances, the guy who fell was very lucky. He has years of pain and rehab to come but is beating the doctors expectations at every stage.
Posted : 26/10/2021 7:16 pm
I’d probably just hit “send location” in what’s app these days
You've just added the green pill, on top of the blue or red choice...
Posted : 26/10/2021 7:20 pm
Matt
One pill makes you larger
And one pill makes you small
And the ones that mother gives you
Don't do anything at all?
Posted : 26/10/2021 7:23 pm
We (family) routinely use live track in WhatsApp when travelling to each others homes, arranging to meet etc.
My Mum in particular used to be a nightmare for calling or texting as I or or my sister were driving to hers and then she'd get worried when we didn't reply for ages cos y'know, texting / calling while driving... 🙄
On the rare occasions I bothered to answer while handsfree, she'd then waste 20 seconds telling me that I shouldn't be talking while driving. Honestly, it was comical while also being incredibly frustrating.
Now it's just a case of hitting live track and having done with it.
Posted : 26/10/2021 7:28 pm
In my case the MRT took 30 mins longer than the air ambulance to get to the casualty the air ambulance had more gear to stabilise and a trauma surgeon. They also made the call to mobilise coastguard helo support within a few minutes of arrival, again saving time. That said it’s one set of particular circumstances, the guy who fell was very lucky. He has years of pain and rehab to come but is beating the doctors expectations at every stage.
Sounds like luck more than good choices. Mean while in a residential area of Glasgow 2 weeks ago my uncle had a heart attack and the 999call handler told them it was 45 minutes before any one would be with them......cue a neighbour going hell for leather in their car. - he was also saved by a lucky call.
"I'd rather be lucky than good"
Posted : 26/10/2021 7:40 pm
