Ideal workbench dep...
[Closed] Ideal workbench depth & material?
Was going to go with 27" (using 3 9"x3" boards) - would you go to 36 with 4 boards or not use 9x3s and for a different material on top?
Posted : 11/04/2015 10:52 am
27-30" sounds like a good start, maybe a bit deeper depending on what you expect to put on there and if you are having a tool board behind it. Normal kitchen worktop is 600mm deep so about 23.5" if it helps.
Posted : 11/04/2015 10:54 am
General purpose bench.
2 ft/24 inches deep
Whats the rest of the bench made of ?
My issue with 3 boards jointed is ....do you have a surface planer or thicknesser to at least make the top flat , or are you gonna stick something else on top to make it flat. The joints in your boards would give me the rage.
I ended up with a 2x4 frame with 18mm ply on top and cheap laminate floor on top of that
Posted : 11/04/2015 11:03 am
Mines about 27" deep. Four boards joined together and planed flat by hand with a Stanley no5.
Posted : 11/04/2015 11:21 am
 sv
Mine is 3 planks wide (9inch each) middle one is 50mm and two outside ones 70mm, stops stuff rolling off.
Posted : 11/04/2015 11:27 am
Nothing yet but plan is to mount 100x100 angle on wall at each end then have a 3" box L frame at the centre which is bolted to floor and wall. Was going to mount a tool board.
Goldfish how did you join yours?
Posted : 11/04/2015 11:53 am
The old fashioned way, planed the joint edges flat and square by hand, slightly convex towards the middle, then just glued and clamped in some hefty clamps. Learned how to do it on you tube, didn't take too long and was fun to do proper traditional joinery.
Any variation was then taken out by planing the whole top after it dried up.
Posted : 11/04/2015 12:06 pm
That's my design as well.
[url= https://farm9.staticflickr.com/8089/8523133335_6510bbc354.jp g" target="_blank">https://farm9.staticflickr.com/8089/8523133335_6510bbc354.jp g"/> [/img][/url][url= https://flic.kr/p/dZahAK ]Bench #1 with base, sides and back[/url] by [url= https://www.flickr.com/people/75003318@N00/ ]brf[/url], on Flickr
Posted : 11/04/2015 12:17 pm
Goldfish.
Failure on the "Man Points" there. If a job is woth doing, it's worth doing with new power tools! There was the opportunity there to buy at least a router, biscuit jointer, and a nice plane. ๐Ÿ™„
๐Ÿ˜‰
Posted : 11/04/2015 12:20 pm
 br
Mine was an old workbench with a knackered top, so flattened it off and then attached a sheet of 1/2" steel that was 'handy'.
I then fixed uprights to the back and added a sheet of ply with a light at the top. Mainly as I've stone walls and they are next to impossible to fix stuff to (easily).
Posted : 11/04/2015 12:25 pm
Mine is 12 foot by 3 foot built on a 100x100x5mm RHS box steel frame and decked out with 6mm steel plate, all welded together. Whole thing is rawl-bolted to the concrete. Reckon it would withstand a nuclear blast ๐Ÿ™‚
EDIT: Beware. It doesn't matter how big you build it, you will always find plenty of crap to fill it and it will end up no bigger than the small one it replaced!
Posted : 11/04/2015 3:12 pm
I made mine from some old gazebo wood a bloke dropped off. Recycling at it's best.
[url= https://farm8.staticflickr.com/7602/16706125278_5e2e389aec_b.jp g" target="_blank">https://farm8.staticflickr.com/7602/16706125278_5e2e389aec_b.jp g"/> [/img][/url][url= https://flic.kr/p/rsgg1J ]Workbench[/url] by [url= https://www.flickr.com/people/53067724@N00/ ]Jon Wyatt[/url], on Flickr
Posted : 11/04/2015 6:09 pm
Lower shelf is recycled decking i was given to burn and the uprights are fence posts.
Posted : 11/04/2015 6:22 pm
There are two 'benches', work-tops, tables, call them what you will, at work, that I'd dearly love to get my grubby paws on: the tops are cast iron, the uprights around 4-5", and they each require a pallet-truck to move them!
Of course, you couldn't attach anything to them, but for bashing the bejaysus out of things, or making sure stuff is dead level, they're unbeatable.
Not something I could sneak out of the building with, however... ๐Ÿ˜‰
Posted : 11/04/2015 7:05 pm
I covet a 8'x4' bench that I can walk all around.
Posted : 11/04/2015 8:53 pm
It's having the space to walk around it that's the problem...
Posted : 11/04/2015 9:12 pm
You want [url= http://singletrackworld.com/forum/topic/live-near-leeds-want-instant-workbench-kudos-with-a-record-52-vice ]this[/url]
๐Ÿ™‚
Posted : 11/04/2015 9:37 pm
bigblackshed - Member
Goldfish.
POSTED 10 HOURS AGO # REPORT-POST
In every single way building something with hand tools trumps resorting to power tools.
Posted : 11/04/2015 10:40 pm
footflaps - Member
castors and workbench feet that drop and lift the bench. Sorted.
Posted : 11/04/2015 10:47 pm
Height is also important if doing lots of vice work such as hacksaw, filing etc. Apprenticeship rule of thumb was top of vice should be level with your elbow when stood straight.
My bench is 650 deep - wouldn't want it any narrower unless very restricted for space (but more important to have space to move than having a deep bench).
Posted : 11/04/2015 10:54 pm
[i]Apprenticeship rule of thumb was top of vice should be level with your elbow when stood straight.[/i]
Yeah, mine is too tall. I need to take a couple of inches off the legs. Can't get the leverage at times.
Posted : 11/04/2015 11:03 pm
I made my workbench then finished the top with a sacrificial sheet of hardboard. Just cut it to exactly fit on the top then edge it with 1x2 or something else similar so it sits nicely and doesn't slide off, but can easily be lifted to replace it.
Posted : 12/04/2015 3:40 am
Buy a cheap fire door with a sacrificial 18mm ply top screwed onto it forms a good solid work surface and then a simple frame of 4x4 legs and 2x4 stringers and rails. Is my suggestion ๐Ÿ˜€
Posted : 12/04/2015 6:45 am
I got my local diy shop to cut a sheet of 22mm mdf to size, which I then applied a sacrificial layer of hardboard and also rubber matting to. I think it is about 750-800mm ish deep, and nice and high so I don't get a bad back when using it
Posted : 12/04/2015 7:04 am
[img] http://flic.kr/p/52P3Qf [/img]
Posted : 17/04/2015 9:10 pm
