Hydrogen tea?
[Closed] Hydrogen tea?
14 Users
Printed on the back of a box of tea bags from M&S...
Use only freshly boiled water as reboiled water has lost its oxygen.
Good lord. 🙄
Posted : 21/03/2014 10:17 am
Boiling water removes the dissolved oxygen from the water. This is different to the elemental oxygen that is contained within the water molecules.
Whether that makes a difference to the taste of the tea is another matter entirely.
Posted : 21/03/2014 10:21 am
Yes it does.
Posted : 21/03/2014 10:25 am
Additional oxygen can be in solution, as well as the oxygen bonded to the hydrogen. That's what fish breathe, and it's why you don't see bubbles of hydrogen coming out of every aquatic creature.
Posted : 21/03/2014 10:27 am
Good lord.
And ?
Posted : 21/03/2014 10:31 am
well, you learn something new every day.
And ?
Yes?
Posted : 21/03/2014 10:33 am
This is interesting. So why does the oxygen leave? When you look at the surface disruption of boiling water you could almost imagine more oxygen getting added
Posted : 21/03/2014 10:56 am
The heat drives it off. Hot water can't hold the same amount of oxygen in solution as does cold water.
Posted : 21/03/2014 10:58 am
Because of the extra energy making everything move around more? That kind of makes sense
Posted : 21/03/2014 10:59 am
I guess reboiling might affect the ph level further, it's also going to concentrate minerals and contaminants such as nitrates further.
That could possibly affect the taste.
Posted : 21/03/2014 11:01 am
Scientists call it deaeriation. Nitrogen n stuff in there too. If you want to make clear ice for sculpture you boil it.
Water that has sat for a while is better as the chlorine smell goes away. Mineral water is salty, and hard English water is just crap.
Posted : 21/03/2014 11:08 am
What about water from an urn that is kept constantly (ish) hot?
Posted : 21/03/2014 11:12 am
Assuming that your water does boil at 100 degrees (which i understand it won't as its not distilled), from that graph, surely the water has no oxygen once its boiled the first time?
Posted : 21/03/2014 11:14 am
There is significantly more deuterium in water that has been boiled over and over.
Heavy, man.
Posted : 21/03/2014 11:16 am
if you were to use ionically filtered or Reverse Osmosis water then reoxygenate it you'd theoretically get a "fuller" flavour as you'd have stripped the water of impurities enabling you more molecular "room" for the tea extract.
Posted : 21/03/2014 11:20 am
That's why I questioned whether it would make any real world difference in my first post. 😉
Posted : 21/03/2014 11:27 am
Edit.
Posted : 21/03/2014 11:41 am
Boiling water also precipitates some soluble minerals into insoluble ones, which affects its composition. Hence limescale in kettles.
Also - the increased solubility of gasses in cold water is the reason why cold oceans are full of life - you'd expect it to be the other way round, but cold water holds more oxygen which helps the life.
Posted : 21/03/2014 12:00 pm
I'll have H2O too
Posted : 21/03/2014 12:38 pm
So hang on. The instructions say, "Use only freshly boiled water as reboiled water has lost its oxygen." If the oxygen has been removed by the boiling process, what difference does it make whether it's freshly boiled or not? The horse has already bolted by that point.
Posted : 21/03/2014 12:44 pm
Much like this point bolted an hour ago when mrjmt made it? 😀
Posted : 21/03/2014 12:48 pm
Bumcakes, I missed that. As you were, then.
Posted : 21/03/2014 12:59 pm
