Does anyone know if I can use my BlackBerry Curve charger with a HTC Wildfire, connection is the same but I know theres more to it than that, I cant read the writing on the BB charger so cant compare.
If they're both the same, mini USB I believe? then it'll be fine... I use whatever charger I can find at work and have never had a problem.
They're both microUSB I suspect. Basically, USB is USB(*), if it fits it'll work.
(* - not [i]strictly[/i] true, but near enough for the purposes of the question.
Almost certainly, but it might not charge as fast, I know the HTC car charger charges much faster than unbranded ones, because the cheap ones only put out 500ma not 1000ma.
Yeah, hence my disclaimer. But that's a difference in charger, not handset. If it charges one it'll charge the other.
