How to stop joggers...
[Closed] How to stop joggers nipple?
31 Users
I seem prone to joggers nipple what is the cure ?
Posted : 30/08/2010 2:43 pm
I can see a few options.
Stop jogging. Failing that:
Remove your nipples.
If both of those are too extreme, try a different Tshirt material, or protect them with plasters.
But surely those are obvious enough for you to have tried them already, so sorry, not help really!
Posted : 30/08/2010 2:44 pm
Vaseline?
Posted : 30/08/2010 2:45 pm
get a dab of vaseline on them. Plasters are also good, but smarts when taking them off if you've got a hairy chest- ouch!
Posted : 30/08/2010 2:47 pm
+1, +1 vaseline, works a treat.
[url= http://www.peteblandsports.co.uk/brands/175/ ]Nip guards....................[/url]
Posted : 30/08/2010 2:51 pm
tried plasters ouch vaseline seems ok but does not always work should I buy a dedicated running top?
Posted : 30/08/2010 2:58 pm
Tasels, works best if you go topless so they flick about in the wind and titillate the general public.
Posted : 30/08/2010 3:02 pm
Plasters are best. Even the silky base layers didn't help mine. Just get big plasters and slap 'em on. By the time you finish the run your sweat will have loosened them up a bit.
When you pull them off don't mince about it, get a firm grip and make sure you rip it off all the way in one go. It's just like getting a wax I guess except a bit more painful.
Posted : 30/08/2010 3:05 pm
I have the same problem when doing a long ride...
I use plasters, but it is only a problem if it is hot and the ride is more than 30 or 40mi
Posted : 30/08/2010 3:09 pm
Bodyglide
[url] http://www.wiggle.co.uk/p/cycle/7/Bodyglide_Skin_Formula_Regular_369g/5360019081/ [/url]
Posted : 30/08/2010 4:41 pm
Another one for bodyglide here. People s**** at the name, but it's fantastic. Doesn't make a mess of your clothes like vaseline can, either
Posted : 30/08/2010 4:55 pm
Juat use gaffer, it'll be fine, and a roll will last you years!
Posted : 30/08/2010 5:15 pm
Cut up Tubeless tyre and stan's?
Posted : 30/08/2010 7:53 pm
Breast reduction surgery.
Posted : 31/08/2010 7:39 am
Merino base has been working for me for ages now.
Vaseline works but you end up with greasy patches around the nipple area on all your baselayers :p Best I've found is a bit of vaseline then a bit of sellotape over the top, these are conveniently sized... http://www.whsmith.co.uk/CatalogAndSearch/ProductDetails.aspx?productID=27524329
Posted : 31/08/2010 7:45 am
gaffatape a cumberland sausage to each breast?
Posted : 31/08/2010 7:48 am
You have nipples???? 😯
Posted : 31/08/2010 7:59 am
Since no one's suggested it yet - micropore tape, available from Boots, etc - the 1"ish wide version - removes easily enough (unlike plasters - ouch!) but sticks in place - so long as you press it firmly on when applie (which may look funny!) 🙂
Posted : 31/08/2010 8:05 am
A sports bra?
Posted : 31/08/2010 8:12 am
You don't?!!!!
Posted : 31/08/2010 8:23 am
You don't?!!!!
Not since he took your advice CK 🙂
Posted : 31/08/2010 9:01 am
I am a bit ignorant about such things but is joggers nipple just a male thing?
Posted : 31/08/2010 10:07 am
On the basis that most women wear bras, presumably their nipples don't get rubbed while running/cycling... (sounds dodgy doesn't it...)
Posted : 31/08/2010 10:16 am
I only suffer from this when it's cold so my gf bought me a super tight lycra-esque themal top from lidl last winter, I wear that under a t-shirt (branded or otherwise) and that does the trick in preventing the joggers nipple. Prior to her buying me the top I had drawn blood on my two previous runs as it was freezing.
The added bonus is that without the t-shirt over the top you look like a super hero which can only be a good thing.
Posted : 31/08/2010 10:17 am
As Steve-G says, a super tight base layer helps, the movement of the fabric against the nipple is a big problem.
I use some cheap Helly Hansen Lifa base layers, plus vaseline, be aware when used regularly the vaseline will stain lighter coloured tops giving the impressio0n that you are lactating 😯
Might look at that bodyglide stuff as an alternative though, although bog standard vaseline is cheaper and comes in massive tubs that last nearly forever, and I'm only 1/4 way through my current vaseline tub. They'll probably have stopped making Bodyglide by the time it runs out!
Posted : 31/08/2010 10:59 am
Stop jogging?
Posted : 31/08/2010 11:29 am
just get some of that micropore tape stuff from Boots, used for taping bandages etc. comes off easy once you're done too.
Posted : 31/08/2010 11:40 am
yep vaselines the thing for it
Posted : 31/08/2010 11:41 am
 D0NK
Are you [s]claiming[/s] admitting to having first hand knowledge of waxing samuri?
Posted : 31/08/2010 11:45 am
I didn't find tight baselayers helped for me, I certainly wouldn't go out and buy some in lieu of using tape...
Posted : 31/08/2010 11:52 am
Can you not use anti chaff cream for the rear on the nips?
Posted : 31/08/2010 12:51 pm
A dab of sudocrem also works wonders on sore bits 😉
Posted : 31/08/2010 12:59 pm
clubber - Member
Alas, not true, even for those with er, boyish figures 😥
Posted : 31/08/2010 1:04 pm
I stand corrected! Guess women just don't talk about it then 😳
Posted : 31/08/2010 1:05 pm
All good advice I think I shall try the full range of options.However a sports bra and vaseline seems strangely tempting.
Posted : 31/08/2010 1:38 pm
 sor
I only suffered this after using a new, proper running top (as opposed to any old t-shirt) in the rain.
Used Vaseline to repair the damage and use plasters to avoid it happening again.
Posted : 31/08/2010 1:53 pm
LOL @ "joggers nipple" ... that's the first time I have heard it. I will observe next time ...
Well the answer is simple. Stop jogging/running 😆
Posted : 31/08/2010 2:05 pm
[b]clubber[/b]
We do talk plenty haha probably just with other wimmin tho !! 🙂
Posted : 31/08/2010 2:26 pm
SfB mode:
Shame 😉
Posted : 31/08/2010 2:29 pm
In response to your question Divagirl, SFB is [url= http://www.singletrackworld.com/forum/profile/simonfbarnes ]simonfbarnes[/url], a dirty old man who frequents this forum and likes taking photos of women's @rses...
Posted : 31/08/2010 3:14 pm
Haha thanks clubber :-))
Posted : 31/08/2010 3:23 pm
Posted : 31/08/2010 4:10 pm
