I've been nosy about my account settings and some of the features and I checked recent activities.. it is showing has been logged on last Jan 5 and 18 in Daventry with BT IP address.
Never been to Daventry of Northampton area in 3 years... Im from Cov 🙁
changed password and 2 step verification now 😐
Where's your isp located?
Roaming ip thingy. Probably not hacked
You should enable 2 step verification if you're not already using it. You'll be notified if a new device tries to log on to your account.
what is roaming IP thingy? ...might be, I am BT as well.
just enabled the 2 step verification thingy as well
Sorry, the term is dynamic IP. You get a different IP whenever you connect. The IP could be located at some distance from you. You may spot a repeated pattern of distant locations depending on your use/times etc.
Daventry or Northampton I suspect 😉
If you're accessing via a mobile phone, you can get false locations.
Also, BT are sharing IP V4 addresses, or something like that, leading to location issues.
And, yes, turn on two step verification.
thanks all, I think I can sleep better tonight now after reading what dynamic IP address is.
