How the...? (Borked...
How the...? (Borked washing machine content)
15 Users
Our 8 year old LG spat water all over the floor today.
Investigation has found a round hole, just smaller than a finger, in the drum on the edge of one of the support web/tabs which the drum is suspended on.
I assumed something like a coin or key had got into the machine, but the trap is empty and nothing rattles.
I'm now thinking flex from the support tab has led to a weak spot...?
Anyway, a shame I can't get the correct new tub in stock and so new wading machine has been ordered instead of of 1/3 of a new canoe we had saved...
Posted : 27/11/2022 6:37 pm
Sounds like a Spot weld parted . Probably through 8 years of fatigue?
Posted : 27/11/2022 6:42 pm
It's the plastic outer drum - the one that contains the water.
Posted : 27/11/2022 7:38 pm
We had something similar. Heavy duty steel rod punched through the drum. JB weld sorted it. You may need a couple of fillets
Posted : 27/11/2022 7:55 pm
It’s the plastic outer drum – the one that contains the water
As above. I used glass fibre from memory.
I cut a hole in the side of the casing to avoid stripping it down.
Pushed into place the hole couldn't be seen.
Posted : 27/11/2022 8:03 pm
I was thinking the stainless drum. If it's just the plastic one I'd be getting out the p38 ....or what ever it is you use to fix your canoes.
Posted : 27/11/2022 8:08 pm
new wading machine has been ordered instead of of 1/3 of a new canoe we had saved…
Is it leaking that bad?
But really - unless desperately anti-credit, AO have got loads on Buy Now, pay in 12 months interest free. You have to pay the minimum by DD monthly and the rest by the end of 12mo, but I just set the DD to be the amount owed / 12
Posted : 27/11/2022 8:11 pm
Yeah it's not pressurised. Definitely worth a shot with the fibre glass repair kit or similar.
Posted : 27/11/2022 8:25 pm
Had a similar issue today, luckily it was a tear in the door seal, still £60 for replacement though. At least it is replaceable. Good luck with drum repair.
Posted : 27/11/2022 8:52 pm
Other option is to drill it out and screw an appropriately sized (and lengthed, really important in this case) bolt into it. I may have done that with a diesel tank that has held fast since. Of course that's assuming the drum has enough clearance.
Actually that doesn't sound like a good solution in this case. I'd repair the hole as above.
Posted : 27/11/2022 9:05 pm
I'd certainly be putting a fiberglass patch or similar over the hole.  I've recently had to discard a 5 year old washing machine as the main bearing had gone, and with a sealed tub it's impossible to replace.  £500 unit thrown away because of a £15 part, as the manufacturers wanted to save a few quid on a welded tub instead of bolted.  Unimpressed would be an understatement...
Posted : 28/11/2022 10:58 am
If anyone wants it for free, we have chosen to go for a new machine as mrs_oab is not convinced of a repair.
Fully working LG of about 7 years age - touchscreen operation and works very well.
One small hole....
Posted : 28/11/2022 11:01 am
How many previous owners?
Posted : 28/11/2022 11:04 am
Can you post?
Posted : 28/11/2022 11:25 am
Do you have it in small?
Posted : 28/11/2022 11:30 am
I'd like it but I'm out of the country. I can send someone to pick it up?
Posted : 28/11/2022 11:41 am
Is this still available?
Can you deliver to Edinburgh ?
What's your lowest price?
Do you accept returns?
Posted : 28/11/2022 11:42 am
Speaking of which, I am loath to part with my 20 year old Miele, but we have a free replacement from our neighbour who is moving. If anyone wants a boat anchor of a machine that does work, let me know before I freecycle.
Posted : 28/11/2022 12:27 pm
Can you post?
I’d like it but I’m out of the country. I can send someone to pick it up?
What’s your lowest price?
Far too much correct spelling and grammar here.
"u abe delever m8 i stay cummernold."
Posted : 28/11/2022 1:22 pm
