How easy is it to f...
[Closed] How easy is it to fit a mixer shower?
Combi boiler system. Local plumbers are wanting around £350 for labour.
Edit - still half asleep. Title should have originally been fit not fix.
Posted : 22/02/2011 10:59 am
is it just a thermostatic mixer valve on the wall? Is it surface mounted or flush mounted behind a splash plate? What's wrong with it - temp control or valve?
Posted : 22/02/2011 11:03 am
New install, so whichever shower type is easiest to fit. But I am thinking the thermostatic mixer valve on the wall.
Posted : 22/02/2011 11:05 am
Depends whats up.
I had one similar to this about 5 years ago that started gushing waster from the inards and wouldnt hold temperature.
I got the internal valve from plumbase which was about £70 and fitted it myself.
http://www.mirashowers.co.uk/onlinecatalog/detail.htm?productNumber=1.1595.004&section=Mixer%20showers&resultPageKey=2000826190-0&category=
Posted : 22/02/2011 11:06 am
oh, you mean "how much to intall a mixer shower" not "how much to repair a mixer shower".
Scots english is not equal to english english is it! 😉
Posted : 22/02/2011 11:07 am
£350, that's a lot. Then again it depends how easy the pipes are to get to. To access the connections for our mixer shower I had to cut a hole in the wardrobe wall of the room the en suite backs on to, which isn't a huge task.
I'd say probably an hours work for a plumber.
Before I fitted mine I got a quote for supply and fit and it was around £450 so that's was probably around £200 labour maybe.
Sounds expensive but difficult to say really without knowing what's involved.
Posted : 22/02/2011 11:08 am
Yip, sorry. Fit not fix.. Still half asleep.
Pipes are easy to get to. There was a shower in there previously so channels etc are already there.
Next question - what bits, apart from the shower, will In need?
some pipes, valves, solder, flux, gas torch, pipe bender and ptfe tape.
Posted : 22/02/2011 11:14 am
Do you have enough water pressure with the combi boiler as we couldn't have one fitted due to the lack of pressure.
Posted : 22/02/2011 11:27 am
you need mains pressure cold water supply as well to the bath which might be an issue?
Posted : 22/02/2011 11:28 am
There is plenty pressure in both taps.
Posted : 22/02/2011 11:30 am
Not difficult to do if the pipework is already there. If it's onto tiles then spend some of the money you are saving on a nice drill bit for tiles. Similarly don't cheap on the mixer either as having changed one last year I can say that there is a difference between them. 'Grohe' are nice
Posted : 22/02/2011 11:47 am
We had a new shower room last year. The plumber charged £350 for plyboarding the floor, fixing the walk in shower in place and doing the plumbing and drainage for the shower.
Installation was resaonably straight forward though as the walls were plastered after wards and the pipe work came up from a cellar that was being converted.
Posted : 22/02/2011 11:49 am
[i]imilarly don't cheap on the mixer either as having changed one last year I can say that there is a difference between them. 'Grohe' are nice[/i]
Normally I would agree that you get what you pay for but I wanted a cheap mixer to get by untill I redo the shower room completely. [url= https://www.screwfix.com/prods/85252/Bathrooms-Showers/Showers-Enclosures/Showers/Manual-Mixer-Showers/Triton-Kaho-Built-In-Manual-Mixer-Shower ]This[/url] was £70 from screwfix and it's fantastic for the money - very simple but does the job very well.
Posted : 22/02/2011 2:07 pm
Recommendations always rock, but he wanted a thermostatic unit I thought and getting a nice one of those is loads more expensive
Posted : 22/02/2011 2:59 pm
