Home electrical wir...
[Closed] Home electrical wiring question
 MTT
Before I inadvertently burn my new old house down I thought I’d check if the follow was going to be possible and how to go about doing it. I have no practical skills.
In short, I’m looking to add a timer module to a 3kw immersion heater:
Module – [url= http://www.timeguard.com/products/time/immersion-and-general-purpose-timeswitches/24-hour-fused-spur-timeswitch ]here[/url]
Bathroom socket selection, 'heat' is the one in question:
Inside:
Two questions:
1.The existing setup has two earth connections, one on the power line in and one on the lead out to the heater, each is connected to a separate earth screw. The timer above has a single earth screw – is this a problem? If so, what is the solution?
2.Can you see any other issues with this?
Thanks
Posted : 09/01/2018 2:55 pm
1. No problem. That metal bar is linking the two earth connections.
2. Nope.
Posted : 09/01/2018 3:02 pm
 MTT
Flap - thanks, the issue with the new module is that it only appears to have one earth connection, see page 4 [url= http://www.timeguard.com/media/3027/FST24_FST77_Instructs_135x85_issue2.pdf ]here[/url]
Could you just bodge both earth connections into the same hole/screw?
Posted : 09/01/2018 3:26 pm
no harm to you, but that wall is a mess. looks like a re wire is due to me .
Posted : 09/01/2018 3:27 pm
Provided they fit, yes you can do that, but make sure you've done the screw up really tight afterwards and that they can't pull out.
Posted : 09/01/2018 3:29 pm
Its fine to do that. Just give them both a tug once tightened to make sure they have caught properly.
Posted : 09/01/2018 3:30 pm
 MTT
Ok, thanks all, I'll give it a go.
rmacattack - that wall wont exist before long... new wiring, heating/plumbing, floors, kitchen, bathroom, quite a few windows... Saving the money is the biggest issue.
This is a temporary measure to make things a bit easier in the morning.
Posted : 09/01/2018 3:35 pm
It's fine to stick them in together.
Although the load cable looks like it's a flex so it might be tricky, but not impossible, to get them tightened up together.
As others have said give it a tug once you have tightened up the earth terminal to make sure they are in properly.
Posted : 09/01/2018 3:38 pm
If you have some needle pliers you could twist the wires into one piece to aid them going in and staying in.
I wish I had done just that last night after fitting a new ceiling light and the second one in the run stopped working as one of the live terminals popped out, which meant I had to take the whole thing down again which, given its design, was a faff.
Posted : 09/01/2018 3:50 pm
 ajaj
Spoken like a true Sparky, but you forgot to say that he needs a new consumer unit too.
Posted : 09/01/2018 4:26 pm
 MTT
It needs the works.
The boiler is 36 years old...
Posted : 09/01/2018 4:49 pm
That wallpaper tho.....wow
Posted : 09/01/2018 4:50 pm
 MTT
Ps. thanks again for the feedback, I've ordered the timer module so should be good to go soon enough.
 MTT
Posted : 09/01/2018 4:59 pm
Post that on an electricians forum and it'll run to 78 pages 😀
Posted : 09/01/2018 5:51 pm
Do the curtains match exactly? If they do OMG.
Posted : 09/01/2018 9:50 pm
Does it really need to say "plug" on the one with a... plug... in it?
Posted : 09/01/2018 10:23 pm
How do you know it says PLUG? all I can see is _UG
Posted : 09/01/2018 10:39 pm
 MTT
But we didnt know to put a plug in it until we wrote plug on it. Now that it's got a plug in it makes perfect sense.
If you mean: Are they the same pattern - Yes
If you mean: When fully drawn, do the curtains line up with the wallpaper - also Yes.
Posted : 10/01/2018 9:12 pm
