Help with some simp...
[Closed] Help with some simple Javascript
4 Users
 bash
well obviously not simple to me but I'm sure it'll be a piece of cake to some of you. I'm trying to concatenate some segments of an HL7 message but not really getting anywhere, this is the message:
NTE|1|T| Hi|
NTE|2|T| this|
NTE|3|T| is|
NTE|4|T| really|
NTE|5|T| annoying|
NTE|6|T| me|
the code I have is this but not doing anything:
var strFinalNTE = '';
for each (seg in msg.NTE)
strFinalNTE = strFinalNTE + seg ['NTE.3']['NTE.3.1'].toString();
Any ideas?
Posted : 01/10/2015 7:39 am
Should be pretty simple. What's the format of the input message - a multiple-line string, or something else? An example of your expected result in strFinalNTE would be helpful also!
Posted : 01/10/2015 7:51 am
Hard (for me) to say without knowing a bit more about the HL7 message structure - I'm not sure if the structure you have sketched matches the structure you are iterating through
Here are some examples of iterating through an object/data structure from Stack Overflow
[url= http://stackoverflow.com/q/921789 ]How to Loop through JavaScript object literal with objects as members?[/url]
[url= http://stackoverflow.com/q/8312459 ]Iterate through object properties
[/url]
I think that the first may help you
Posted : 01/10/2015 7:54 am
is this in a broswer, what error's it's throwing? I assume you knowit should be "forEach".
Posted : 01/10/2015 7:57 am
There's quite a few things in there that aren't right.
Anyhow, assuming no preprocessing and the msg is just a multi-line string:
var msg = "NTE|1|T| Hi|\n"
+"NTE|2|T| this|\n"
+"NTE|3|T| is|\n"
+"NTE|4|T| really|\n"
+"NTE|5|T| annoying|\n"
+"NTE|6|T| me|";
var msgSplit = msg.split("\n");
msgSplit.forEach(
function append(value) {
strFinalNTE += value.split("|")[3].toString();
alert(strFinalNTE);
https://jsfiddle.net/aa89ntpk/2/
Posted : 01/10/2015 8:47 am
Got bored whilst on phone to marketing man...
If you're doing this regularly then...
String.prototype.HlCodeToArray = function (){
var output = [];
var msgSplit = this.split("\n");
output = msgSplit.map(function(value) {
return value.split("|");
return output;
+"NTE|2|T| this|\n"
+"NTE|3|T| is|\n"
+"NTE|6|T| me|";
var msgArray = msg.HlCodeToArray();
msgArray.forEach(
function(value) {
strFinalNTE += value[3].toString();
document.getElementById('output').innerHTML = strFinalNTE;
https://jsfiddle.net/aa89ntpk/21/
Posted : 01/10/2015 11:05 am
 bash
Cheers guys managed to work it out plus delete the old 'fields' so it just comes through as the one message. Don't do this a lot hence the daft question.
Posted : 01/10/2015 11:32 am
