Heating Oil Tank In...
[Closed] Heating Oil Tank Installation
[#5391209]
Hi All
Does the oil feed pipe from the tank to boiler need to be in copper with threaded fittings or is there an alternative these days, no pressure just head of tank to pump
Posted : 04/08/2013 1:28 pm
I would do it in copper - plastic pipe may be approved (I have no idea if they are or not), but a crushed/cracked plastic pipe will leak all your oil away, whereas a crushed or bent copper pipe will still not leak.
You can get a load of plastic coated 10mm copper pipe for not that much compared to the cleanup costs of a split plastic pipe!
Posted : 04/08/2013 2:23 pm
Mines 10mm plastic coated copper with compression fittings
Posted : 04/08/2013 2:49 pm
Copper pipe can crack if bent too much as well , infact ime splits easier than plastic pipe as its more flexible encouraging ambitious bends....
Posted : 04/08/2013 2:50 pm
Thinking of running combination of 15mm down 10 mm due to the length of run 30ish Ft, tank to boiler
Posted : 04/08/2013 3:10 pm
But the copper pipe is likely to crack on installation, not when the car/trailer/kids bike etc collides with it. It's after the installation I would be worried about the pipe cracking. 10mm pipe would be fine throughout, after all, the flow rate is (hopefully) quite low.
Use compression fittings, and you may need some oil resistant tape (it's like plumbing PTFE tape, but oil resistant)
Posted : 04/08/2013 3:32 pm
Would hydraulic lock, thread sealent be ok. We use this in work on standard oil piping so I presume this would be the same as heating oil/ kerosene
Posted : 04/08/2013 9:24 pm
We've just had a new line fitted last week from the tank to the boiler. Our heating chap used plastic coated copper. It looks about 10mm.
Posted : 04/08/2013 10:08 pm
Ok thanks for the above info, however, will have to bury part of the supply pipe.
Oftec info only says consult with installation team etc, what have they done in your case, I was going to pass copper pipe through hose for additional protection prior to back filling
Posted : 06/08/2013 6:02 pm
 br
[i]Oftec info only says consult with installation team etc, what have they done in your case, I was going to pass copper pipe through hose for additional protection prior to back filling [/i]
The line from our oil tank to house is partial underground (just covered with soil as I found out...), and then attached to the wall.
It looks 10mm copper with a plastic (not sure what) covering.
I'd guess it's to a specific spec, so just buy whatever is required.
A simple google brought this up:
Posted : 06/08/2013 6:18 pm
Thanks b r couldn't find that page of info, will ring local plumbers merchant about the plastic coated piping, however,one of my neighbours recently had there tank replaced and relocated but has been done in standard 10mm copper with screw fitting on every corner- carried out by registered installer
Posted : 06/08/2013 11:38 pm
 br
tbh Now I've found out that ours (inherited) isn't shielded in any way and just been covered with earth I'll be protecting it.
One of our neighbours had a leak (into the wall), they only found out when it started showing through the plaster - big insurance job as not only loads of oil but they needed to dismantle about 10ft of house wall (3ft thick stone job too).
So I'd err on over-build myself.
Posted : 06/08/2013 11:43 pm
Ok, cleared the area for sighting of tank, so before I start lets see your installations, preferably with buried supply pipe under walkways
Posted : 07/08/2013 6:16 pm
As a plumber I always use plastic coated 10mm copper, its pretty much standard practice for oil lines. ( do not use 15mm pipe as it will bring potentially more problems)
If you are going to use compression fittings then you need brass inserts to stop the pipe from deforming too much when tightening the fitting. (All compression fittings need to be accessible)
For sealing both the threaded tank connection and the compression fittings I would recommend either Heldite or Stag jointing compound.
I work with oil appliances day in and day out and 9 times out of 10 any leaks with regards to pipework are from mechanical damage.
Hope that helps 🙂
Posted : 07/08/2013 6:56 pm
Redben
The plastic coated pipe, qualpipe, on there web site says it isn't I've stable and only suitable for burying. This will mean starting in standard copper going to plastic, under the path and then returning to copper for the rest of the run
Posted : 07/08/2013 8:10 pm
Erm I would try going to another stockist to get conventional plastic coated copper pipe then, because it will not only be easier to run if its one continuous pipe but also it means the chances of leaking joints in dramatically reduced 🙂
You need part number 8883
http://www.bes.co.uk/products/139.asp Part
Posted : 07/08/2013 9:55 pm
What this like to bend, using hand bender for most angles rather than fittings, does it need internal ferrules
Posted : 08/08/2013 5:42 pm
I just did bending by hand putting in big radius curves
Posted : 08/08/2013 5:46 pm
