Heat my office. Ele...
[Closed] Heat my office. Electric heater experts to the forum please.
Located in Surrey. 5mx2.5x2.2m high timber framed man cave, double layer of breathable felt(one int one ext) 120mm insulation all round, walls ceiling, floor, but with double glazed (28mm) windows all along the from, about 5m2 window area. 100mm off ground, 10degree sloping roof. Timber clad, plasterboard internal, hardwood floor.
I don't like a really hot room, 16-18 is my comfort zone.
I think I need a 1kw heater. Fancy timer, even internet control would be good? Free standing or wall mounted.
Posted : 15/10/2018 11:03 am
I bought a cheap 6ft 240w tube heater for my storeroom/drying room. It's really effective. Really heats up the space effectively. Far better than the 2kw wall heater I had previously.
https://www.ebay.co.uk/itm/Low-Level-Sunhouse-Tubular-Heater-Low-Energy-Electric-Tube-Heater-Thermostat-/112579437792
Posted : 15/10/2018 11:08 am
If you are in there a lot oil filled radiator on low worked for me in unheated bits of the house.
Posted : 15/10/2018 11:09 am
Oil filled radiator on a smart plug.
Posted : 15/10/2018 11:10 am
I am in here 6-10 hrs a day mon to fri...
Posted : 15/10/2018 11:18 am
Oil filled radiator for me in my study/office in the winter so I don't have to heat the rest of the house up when no one else is in. Unglamourous but effective and portable and it goes away for 7 months of the year.
Posted : 15/10/2018 11:28 am
You don't need anything more complicated than an oil-filled radiator on a timer plug.
Posted : 15/10/2018 11:42 am
Some kind of IR heater aimed at you would be the most efficient way.
Posted : 15/10/2018 11:56 am
Could "smart plugs" and the like save you some money by turning it off when you leave the house, or just don't go in there in the morning. I guess some sort of hub with "rules" would be required.
Posted : 15/10/2018 12:11 pm
yeah, a basic timer might not be good enough. I'd quite like to lie in bed and think, ohh gotta start work at 9, heating on for 0830 and have some remote way of turning it on.
And then other days I might have to go in to the actual office at work in Crawely so it is variable..
Posted : 15/10/2018 12:18 pm
Oil radiators are better (in my opinion) than other electric options.
Posted : 15/10/2018 12:21 pm
When working in the home office:
1) Go into home office
2) Turn on oil-filled radiator
3) Go to kitchen to make a brew (or artisan single estate espresso)
4) Go back to office, work
5) When leaving office for the day, switch oil-filled radiator off.
Steps 2 and 3 can be interchanged depending how precious you are about being a teensy-bit chilly for 15 minutes while radiator warms up.
When working in Crawley office:
1) Go to Crawley office.
Posted : 15/10/2018 12:32 pm
No need, office has sink and kettle..
I get you, but a bit of 2018 would be nice...
Posted : 15/10/2018 12:46 pm
If by '2018' you mean "over-complicating simple operations", then fill yer boots.
Posted : 15/10/2018 12:58 pm
No I mean automation and remote control. I'd like to experience a bit before armageddon hits in march 19.
Posted : 15/10/2018 1:08 pm
If you want to move into 2018 you can get a Wi-Fi connected plug and an oil filled radiator.ย  Plug goes into your socket, then the radiator plugs into that.ย  Control it via Wi-Fi - assumes that you have Wi-Fi in the man-cave.ย  Some on the web appear to be able to connect to Alexa, so can just tell it to turn on from your bed!
Posted : 15/10/2018 1:38 pm
Boom, 25 quid. I like it. That's a good solution, thanks.
Posted : 15/10/2018 1:48 pm
5) Switch oil-filled radiator off 30 mins before you leave the office. (Could save 2 1/2 hours leccy per week).
6) Leave office.
25 quid.
Posted : 15/10/2018 1:54 pm
TBH it will probs only be on for a couple of hrs in the morning. I am a heating avoider as a rule, in the depths of winter I have CH on for getting up and going, but when the office was in a bedroom last winter I found after 10amย  it was all really toasty and no more heating needed for the day, apart from an hour at 9-10pm for a bit of warming up before bed. (we have dog now, so even that isn't likely to be necessary this winter)
The wife would rather not have heating on at all..
Although we do use the fire in the lounge quite a lot. Last winter and the one before I lit the fire every morning in the kitchen before the kids came down so all the rads were just turned off in there. However I found the fire a false economy and CH is much cheaper.
PS don't fret IHN, I found one for 15 quid and another forย  fiver.
https://www.appliancesdirect.co.uk/p/iq-wifiplugmeter/electriq-iqwifiplugmeter-smart-plug?
Posted : 15/10/2018 2:30 pm
Oil filled rad and a smart plug?
Posted : 15/10/2018 2:48 pm
I've just moved my home office to the garden room, it's insulated but has a tiled floor and no rads.
I purchased a fancy Delonghi oil rad which has an electronic timer (no weekend setting) but the electronicsย stop it playing nicely with a smart plug (when power is switched back on it goes into standby unlike and manual rad).
So now I have a smart plug, the plug itself can be controlled by its own app for full timer control but I use it will a combination of IFTTT and Stringify so it switches off when I leave home or return on a workday. I had originally intended to trigger it with our Tado thermostat but the Tado does not have any triggers based on whether it is on or off.
Everything appears to work well but it's been mild until today.
The smart plug also has an energy monitor which is handy. Oh and make sure that the smart plug can handle the power of the oil rad.
Posted : 15/10/2018 4:19 pm
