This seemed a little leftfield even for this place, but does anyone know anywhere to get a Hager ADN106 and an ADN 116 from for good price?
Reckon there's someone on here who knows basically everything, so cheers in advance!
Local wholesaler is the only real option unless you fancy chancing a used ebay one, should be able to get them for £30 each from an eddy,s
ok, cheers. seeing them for mid £20s online. "used" doesn't sound very tempting!
Mid £20s sounds reasonable for Hager. Be thankful it isn't a Merlin Gerin/Schneider or you'd be looking at £60-70 each 😯
Only buy used if you've got access to an RCD trip tester to make sure they're working.
I'm pretty sure newey and eyre do Hagar, and personally I never use a second hand unit unless I had no choice.
good stuff, cheers people.
do not buy secondhand unless you have an RCD tester which also has a ramp test facility as well as time test
personally I would buy new everytime
Good stuff, i've found somewhere localish that beats most of the web prices so will go for them. Cheers again all.
