Gps question.
[Closed] Gps question.
5 Users
Hello all
If I were to follow this route...
...then is there a tolerance around WP18 at which my old Etrex would consider me to have 'arrived', i.e. begin directing me to the next waypoint?
Snippet of route nicked from [url= http://www.singletrackworld.com/forum/topic/another-peaks-route-reqeust ]this[/url] thread, btw.
Posted : 26/04/2010 8:12 pm
Look at the map.
There are four tracks at the junction. Given the angles the meet at, what's the chance you'll take wrong one? GPSRs are only so accurate anyway - as are the maps.
Posted : 26/04/2010 8:16 pm
IIRC you can set the arrived tolerance on the unit. It will be a distance of between 5 and 100m or so.
Posted : 26/04/2010 8:20 pm
Fair enough, druidh, in this specific case, but my GPS's won't start navigating to the next point until it knows you've been to this one.
This pic was to illustrate a point. When planning a route, a WP may end up on the other side of a (unmarked) fence, say i.e. inaccessible.
@Geoff - I'd have thought that, too. Can't find anything, though.
Ta anyway
Posted : 26/04/2010 8:35 pm
What GPS, you can defo do it on some Garmins
Posted : 26/04/2010 8:43 pm
ph0010421 - Member
...and to think some folk on here mock the SatNav drivers who end up driving off piers etc....
Posted : 26/04/2010 8:50 pm
Hi Geoff
Something like [url= http://www.ebuyer.com/product/177662 ]this one.[/url]
druidh - I'm struggling to simplify the problem enough so you can grasp it.
Posted : 26/04/2010 8:53 pm
I use a Garmin etrex, and navigate via tracklogs, not routes. The etrex displays the route as a coloured line on the map (you can tweak the colour) and your position as a point with a circle which varys in diameter to show uncertainty (as fix signal varies).
You get to decide whether you are on track or not!
Posted : 26/04/2010 10:29 pm
chrispalmr - Member
Good idea. Mine is a simple LCD screen, but I'll give it a try.
Posted : 27/04/2010 5:36 am
I'm not familiar with your unit but on my Garmin, I'd manually select 'Goto WP19' when I was at the junction of tracks, then go back to auto navigate after I'd reached WP19 - is that possible?
Posted : 27/04/2010 6:47 am
There's a technique in walking with a compass called "bearing off". This can be adapted when using a GPS by re-plotting WP18 to some small distance before the junction, then perhaps adding an additional, interim, waypoint some small distance after it.
Posted : 27/04/2010 6:53 am
