gone and had my van...
[Closed] gone and had my van remapped ( wow )
Whilst it's certainly right to strive for reductions in emissions to ensure continued health of people and the planet, given that the US military is apparently more polluting IN PEACE TIME than the entire civilian population, perhaps if anyone has a real concern for the welfare of their neighbours and the habitat that 7 billion odd of us are sharing, it might be worth channeling some of this outrage elsewhere...
Posted : 29/05/2017 10:26 am
There's no outrage here, there was outrage on the litter thread, "scum" etc. But here the strongest language I've used is "anti-social".
We are all collectively responsible for many polluting activities and my appeal on this thread is to not deliberately do something that will make a vehicle pollute much more than it normally would.
There are other things we can do to reuce how much we pollute, and the more people who are prepared to do them the better. Rather than saying "everybody else pollutes as much as they can afford so why shouldn't I?" say "I'll do what I can to reduce how much I pollute and if everybody else does too the world will be a better place".
Posted : 29/05/2017 10:40 am
thisisnotaspoon - Member
what is the possibility that engine maps have improved since my van was built and good remappers have programmed better maps for the indevidual van .
Zilch. Nadda. Not a sausage.
Depends on how you define a remap, an off the shelf map flashed to your ECU, probably not much. That's a relatively Conservative map that you can just bung on.
But there are companies who make individual maps for individual customers, and they refine them with a laptop plugged in, In real time whilst driving rather than on a rolling road, to suit the individual customers requirements.
Obviously this is expensive and probably only used by people really into motorsports with custom engine configurations, but there's theoretically no reason you couldn't specify an emphasis on economy rather than performance.
Posted : 29/05/2017 11:46 am
^ I think it's fair to say that VAG tend to drive their cars when setting their maps, wiv laptops plugged in and everyfink
Posted : 29/05/2017 11:49 am
milleboy - Member
Porsche didn't fit a LSD into the Cayman
It would need drugs to make it look attractive
Really? I'm not a big Porsche fan boy but i think it looks pretty good.
Posted : 29/05/2017 11:55 am
bamboo - Member
Yes but you've missed my point.. They have specific breif to suit most customers under a wide range of conditions, and achieve a reasonable level of efficiency resulting in a one size fits all map.
A 3rd party engine tuner can push the envelope further, the ecu can be fully reprogrammed according to one persons requirements rather then a manufacturer who will program it to mostly suit the requirements of millions of customers.
Posted : 29/05/2017 12:06 pm
Or even the least polluting possible. But that's a lot harder and more complicated. You'd need real-time monitoring of NOX.
Posted : 29/05/2017 12:12 pm
[quote="mattyfez"]A 3rd party engine tuner can push the envelope further, the ecu can be fully reprogrammed according to one persons requirements rather then a manufacturer who will program it to mostly suit the requirements of millions of customers.Mostly what they do is switch off or modify the protection features within the software (overspeed, over pressure, antiknock, emissions and so on). Then they turn everything up a bit. Fuel, air, ignition, injection timing. Then hope it doesn't blow up. That's the tricky bit, how far can you go without it blowing up.
Sometimes it does.
And it's [i]really, really[/i] obvious when you look at the engine.
Posted : 29/05/2017 12:20 pm
Thats what one team do, they hire a particular car, dump the map and save it, modify a copy of the dump, flash, test, rinse repeat until it's what they want and then re flash the unadulterated map , return the car
Posted : 29/05/2017 12:27 pm
OP, how much did your remap bump up your insurance? Or does anyone know what the typical increase would be for a run of the mill performance remap like that?
Posted : 29/05/2017 12:30 pm
The point that tinas (and maxtorque earlier in the thread) made, is that the OEMs spend millions upon millions optimising emissions, fuel economy, and driveability on test rigs and testing the cars in a full range of environments around the world. They have full working knowledge of the software and all the calibration parameters- third party companies simply cannot gain this know how. I wouldn't let anybody touch my car for this reason alone.
Third party companies who do remaps may increase torque and power, maybe even reduce fuel consumption, but nothing comes for free - emissions will increase as a result. People are outraged at VW for cheating emissions legislation; using a remap which will be far worse is antisocial.
Posted : 29/05/2017 12:35 pm
If i was to do one it would cost me nowt extra on insurance, im with TWI
But what about when OEM mappers spending millions and millions on development get it spectacularly wrong, like with the 1.6 Hdi Siemens SID 807 which was undriveable or shook the car to bits in constant speeed cruise POT in 4th gear?
Posted : 29/05/2017 12:40 pm
Mick from Derby won't ever drive above the arctic circle, or across the Sahara. He might even agree to only use high octane fuel, this gives an engine tuner a lot more to play with as some of the constraints are lifted.
Yes they can, they are just parameters on an eprom that can be downloaded, messed about with and flashed back to the chip. Whether you trust them to know what they are doing, well that's a different question.
Quite an interesting article..
[url= http://www.motorsport-developments.co.uk/whatismap.html ]http://www.motorsport-developments.co.uk/whatismap.html[/url]
Posted : 29/05/2017 12:46 pm
That'll be the engine dev team not talking to the dressed engine team or the mounts team or the body structures team.
Or any combination of the above.
It happens.
The car was probably developed around a larger, heavier engine with completely different vibration (and gearing) characteristics.
Then the marketing team decided they needed an entry level/eco car and just slung the smallest engine they could find into the car.
That happens too.
Sometimes causes great surprise to the development departments when they start getting warranty/complaints about cars they've not even considered as a viable combination.
Posted : 29/05/2017 12:47 pm
from that link... 1day to do a map? Somebody should tell vw that's all it takes, they could drastically cut their development time, and save a fortune!
Posted : 29/05/2017 1:06 pm
Exactly, OEM's aren't infallible, and neither are all tuning companies some spotty teenage tosspot banging out maps in his bedroom on a nicked copy of WinOLS
Posted : 29/05/2017 1:09 pm
And as somebody who writes software for vehicle powertrains for a living, sometimes we see oems changing parameters that they have no calibration guide for during development, without understanding the consequences. Fortunately we work with them and develop the calibration together which corrects such mistakes before production sign off occurs. Third party suppliers don't get calibration guides (for IP reasons), so they are stabbing in the dark at best.
Posted : 29/05/2017 1:10 pm
Ok, let's think about hypothetical Mick's tuning.
Only run on good quality, high octane fuel. So you can whack the boost up, increasing temps and increasing NOx.
Never drives in the artic circle. That's more an issue with making sure the diesel doesn't solidify in the tank.
Never drives across the sahara. A more valid point, and but again that's more a hardware issue with specifying a different airbox.
And..............
VAG will have temperature compensation in the maps and the ECU. If he drove it to the arctic circle it would probably open the EGR a bit more because it can (cold air bring with it more O2). If he drove it to the Sahara (or Colorado) it might up the boost a bit to keep the power up in spite of lower air density.
What he does actually do though is drive around Derby. So let's just stick with the VAG map that keeps NOx and pm10 to a minimum ehh?
Posted : 29/05/2017 2:41 pm
[quote=mattyfez ]Mick from Derby won't ever drive above the arctic circle, or across the Sahara. He might even agree to only use high octane fuel, this gives an engine tuner a lot more to play with as some of the constraints are lifted.
It would if the manufacturers hadn't already accounted for that - if he's driving around Derby on high octane fuel, then the parts of the map which will work in the arctic circle, the Sahara or with low octane fuel won't be used. You'd be amazed to find that they have sensors which can detect these things.
I've not worked with ECUs on engines, but I have done lots of work with microcontrollers interfacing with hardware - sensing the envirnoment and having different parameters for different environments is trivial. If Mick is driving around Derby he'll already have the optimum mapping for driving around Derby taking all things into account - as above, any increase in power will be at the expense of something else.
Posted : 29/05/2017 3:33 pm
It's good to see some sense being spoken on stw
Posted : 29/05/2017 3:36 pm
Do you mean 'rare'?
Posted : 29/05/2017 3:48 pm
Sigh. It depends how you define optimum.
Posted : 29/05/2017 3:55 pm
[quote=mattyfez ]Sigh. It depends how you define optimum.
Of course, Mick may reckon that emissions aren't important.
Posted : 29/05/2017 4:02 pm
We don't know what Micks preferences and goals are, I'm just trying to illustrate they may be different to the manufacturers generic audience.
Micks has options with a custom map.
Posted : 29/05/2017 4:05 pm
[quote=mattyfez ]they may be different to the manufacturers generic audience.
Ah, all those people who want less power and worse fuel economy, good point.
Posted : 29/05/2017 4:10 pm
No, with the standard map the ECU has options to deliver power/efficiency in a way that keeps pollution within legal levels (for the test at least). The OEM map is optimized around that constraint. The ECU uses a map optimised for the ~20C grey and drizzley midlands conditions of Derby. The original pollution tests were even probably done in conditions not too dissimilar because that's pretty much standard EU weather.
If Mick had his greenpeace hat (a fetching Rastafarian beanie to be precise millinery fans) on he might have it remapped to produce even less power, use less fuel and produce even less pollution, but I don't think that's what Mick has in mind does he?
Posted : 29/05/2017 4:20 pm
double post
Unless Mick puts his map through a Euro 5 (or 6, or whatever) compliance test then his options aren't really a fair comparison. They are options to take a legal car and make it illegal (C&U breach).
They were talking about changing the MoT in 2018 to test for NOx and others. Don't know where that got to, but it would make remaps less attractive (unless you change the map back for the MoT but then you really are a knob).
Posted : 29/05/2017 4:45 pm
Page 4 / 4
