Getting a route fro...
[Closed] Getting a route from Strava to my Garmin Etrex
I have seen a couple of rides that Strava buddies have done and wanted to follow the same route....
I go to the map of the ride and click GPX download. When this has downloaded, i drag and drop into my Garmin Etrex 30x. The file appears in track manager and i select it. So far so good. However when i load these routes up, they are not the entire route, but about 3/4 of it.
Any idea what im doing wrong? Ive tried it with more than one person and route amd it seems to truncate it.
Please help!
Ian
Posted : 25/07/2020 10:27 pm
If you are trying to import them as routes, I think there's a fairly low limit on the number of points (250 ?).
If it is that, you can use one of the on-line utilities to thin the points out, or import them as tracks (which can have thousands of points).
Posted : 25/07/2020 11:00 pm
I’ve had success loading them as courses in the past (.crs)
I found a free gpx to crs converter, called gpx2crs I believe!
Posted : 25/07/2020 11:16 pm
Sounds like your downloading them as a GPX Route instead of a GPX Track, Routes have more waypoints and once the limits exceeded the route will stop, Tracks don't have this issue & can be very lengthy without any issue.
Posted : 25/07/2020 11:21 pm
 gdm4
I have the same issue with my garmin. For the complete technophobe how do you download ad tracks rather than routes please?
Posted : 25/07/2020 11:30 pm
When i go to the download button on the map on Strava it doesnt give me any options (i dont think) other than a .gpx file. I then drop it into the folder in my garmin called GPX.
I will try the gpx2crs utility when i get home.
Posted : 25/07/2020 11:47 pm
If you 'export gpx' from Strava it will be a "track" - you just need to make sure you don't try and add it as a "route" in your Garmin.
This is roughly the way I go about it:
http://www.rambler-info.org.uk/gps/howto/ht_load_etrex10.htm
Posted : 25/07/2020 11:54 pm
If you download from a Strava activity, it will be a GPX track.
The Etrex 30x should allow up to 10,000 points in a track. Most tracks from Strava will be much less than this. But some could be more, if they were recording 1 point per second, and more than a couple of hours.
There is software to simplify GPX tracks, and reduce the number of points. eg GPSBabel or Garmin Basecamp.
Posted : 25/07/2020 11:58 pm
Ok, so when i got home, i had another go at this.....
I went to the athletes profile i was copying and pulled up the map of the route. Instead of clicking DOWNLOAD GPX, i clicked CREATE ROUTE and it the pulled up a route making page. I just clicked SAVE and it created a smaller file than before, which i dragged into the GPX folder in my Etrex 30x.
When i then switched on the Garmin, i was able to see the full route on the map! Hurray!
Thanks to everyone who helped me!
Ian
Posted : 26/07/2020 11:08 pm
