Geek Assistance Req...
[Closed] Geek Assistance Required: Any VMware gurus here?
Long shot:
I need some help figuring out how to set up a VMware network.
I have:
One laptop running Windows XP which has:
• a USB-to-Ethernet adapter connected via a cross-over cable to a PC (running LynxOS).
• a VMware Workstation running Windows XP
• a VMware Workstation running Red Hat.
I'd like to set them up so that they all appear on a 192.168.150.* subnet. The VMware with XP must appear at 192.168.150.1 and LynxOS must be 192.168.150.2. The Red Hat box can be anything and the real XP on the laptop doesn't need to see the network.
Anyone?
Posted : 10/06/2010 10:19 am
Christ i would be amazed if that was even possible so many OS's talking to each other....
Good luck
Posted : 10/06/2010 10:22 am
 R979
Try this, if it doesn't work let me know:
Posted : 10/06/2010 10:26 am
soma: it's all just TCP/IP traffic, no clever OS-level protocols really, just basic networking (telnet, FTP and my own code)
R979: Ahh but at least two thirds of my wires and switches are virtual 😀
Posted : 10/06/2010 10:38 am
 Aidy
You'll probably want to be switching all the vmware network interfaces into bridge mode, then it should just be a case of faffing with the network settings of each OS.
Posted : 10/06/2010 10:44 am
off, then back on 🙄
Posted : 10/06/2010 10:46 am
never mind, I think I got it working. 😀
Posted : 10/06/2010 11:10 am
The VMs need to bridge to an extenal network card that the other PC is physically located on. The n give them all IP addresses etc. on the sdame subnet.
Posted : 10/06/2010 11:16 am
BTW, if you need to keep such a setup running for some time, look up running ESXi on an old worksation with plenty of RAM and HDD space - it's a free bare metal hypervisor and may save you getting strangled by your own cables 🙂
There are a few desktops capable of doing it if you look around, it often bitches about kit not on the HCL, but mainly you can get away with it. I have an old Optiplex GX620 running the hypervisor off a bootable usb stick for what is technically known as 'titting about'.
Posted : 10/06/2010 11:20 am
Two points to you! But 6 minutes too late 🙂
I hadn't realised that different VMs could have different IPs and still use the same vmnet that was bridged to a physical card.
All good ta.
Posted : 10/06/2010 11:56 am
I reckon I lose them for typos anyway, and deservedly so 🙂
Posted : 10/06/2010 1:28 pm
 Aidy
[i]"The VMs need to bridge to an extenal network card that the other PC is physically located on. The n give them all IP addresses etc. on the sdame subnet."[/i]
I said it loads before that :p
Posted : 10/06/2010 1:34 pm
Aidy summed the solution up with one word
[i] faffing[/i]
Posted : 10/06/2010 2:42 pm
