Gaming PC - a new s...
[Closed] Gaming PC - a new spec/build
I have been asked by a friend to put together a spec/build for a new games PC. I am a little out of touch with the hardware side of things...
There is a budget of £1000. He would like at least 12GB of memory may be more and he obviously wants a good graphics card.
The only other concern is that the PC is located in a very dusty area, so a decent case is essential.
Any advice or pointers would be great.
Posted : 14/09/2012 8:10 am
Probably a silly question but if you're a bit out of touch with hardware why have they asked you?
There's a number of PC magazines that list 'current best for x' pc's/components - probably best to start with one of those.
Posted : 14/09/2012 8:14 am
Not a silly question, because I work in IT and I use to build PC's...more Internet/software these days.
But I always stayed away from gaming PC's because to be honest they were a pain in the arse and the ones that I did build (years ago) the users/gamers were hard to work with...
I was actually looking for more advice on the case than anything else, but I thought I would ask a more 'general question' about gaming pc's.
Cheers.
Posted : 14/09/2012 8:25 am
I reckon something [url= http://www.extremetech.com/extreme/94949-how-to-squeeze-a-ps3-and-xbox-360-into-a-desktop-pc-case ]like this[/url] would be your best bet 😉
Posted : 14/09/2012 8:30 am
Head on over to [url= http://www.chillblast.com ]chillblast[/url] for ideas, or just save hassle and buy one from them or [url= http://www.overclockers.co.uk/productlist.php?groupid=43 ]overclockers[/url]
Posted : 14/09/2012 8:32 am
A fair few motherboards and graphics cards support Quad SLI now so recommend 4 of [url= http://www.novatech.co.uk/products/components/nvidiageforcegraphicscards/nvidiaquadroseries/vcq6000-pb.html ]these[/url] too.
Posted : 14/09/2012 9:08 am
 anjs
Thats not even a gaming card. Any reason why he needs 12 GB of memory? I would post here to get an idea for parts
http://forums.overclockers.co.uk/forumdisplay.php?f=8
Then see if you can find them cheaper online.
Posted : 14/09/2012 9:18 am
Just built up a shuttle pc for £600 Intel i2600 processor and 32GB of RAM for my lab. Should be able to do something similar on that budget but might stretch it a bit as you will probably want a better processor and I am using on board graphics.
Posted : 14/09/2012 9:59 am
Bit-tech do a [url= http://www.bit-tech.net/hardware/buyers-guide/2012/08/31/pc-hardware-buyer-s-guide-august-2012/1 ]buyer's guide[/url] with kit lists at various price points - that's usually where I start when speccing up a new build.
Does the £1000 include monitor/peripherals/OS? That will make a fair few quid difference either way.
Posted : 14/09/2012 10:33 am
Get something from overclockers with an upper mid-range graphics card and an SSD system disk. If the monitor/peripherals are part of the budget it will affect the GPU you can get mostly. Not sure a decent case is going to help much with dust either, it will get in there regardless.
Posted : 14/09/2012 11:07 am
New i5 Ivybridge 3570k is a must, overclock it to 4ghz or more.
A standard 1TB HDD with a SSD for OS drive if it can fit in budget.
Best graphics card you can afford within budget. GTX 560 TI is a good starting point.
Posted : 14/09/2012 11:22 am
Could you not water cool, mount the radiator on the outside and then seal the case? Is that possible?
Posted : 14/09/2012 11:23 am
Just to add to what FuzzyWuzzy and PlopNofear say, an SSD makes a massive difference to load times so is well worth considering - I've just fitted one as a boot drive in my two-to-three year old gaming system and it's given it a whole new lease of life.
Posted : 14/09/2012 11:26 am
You can cram a reasonable graphics card in a Shuttle (I did for my hackintosh) but I would stick with a standard form factor for a gaming PC. The space makes cooling and keeping it quiet easier.
The Antec Sonata case is a decent benchmark to start your search with.
Nah, just put the whole lot in a fish tank and cover with mineral oil...[img] [/img]
Posted : 14/09/2012 11:38 am
Now, I know that theoretically that shouldn't be a problem, but personally I'd be cacking myself when I hit the "on" switch the first time!
Posted : 14/09/2012 11:44 am
