G3 certification
[Closed] G3 certification
Which bodies can give G3 certification for plumbers?
I know of Gas safe being the obvious one.
Is there any way to find out where a plumber might have sought their certification from?
Basically had an unvented cylinder installed. Looked them up on gas safe and they don’t have unvented work listed. Before getting too grumpy I wondered if there’s a way to check if another body has given them the necessary certification.
Posted : 06/08/2020 9:22 pm
The details of his G3 registration number should be on the Installation certificate
Could be certified by the IoP or CITB also.
Posted : 06/08/2020 9:28 pm
Problem is I don’t have an install certificate. Had nothing confirming the work has been notified to the LA
Posted : 06/08/2020 9:33 pm
How Can I check membership at the CITB and IoP?
I only have their name, company and gas safe registration details.
Posted : 06/08/2020 9:45 pm
You would ask the installer I’m afraid.
They could be registered in a number of places.
You need a certificate for Building Control as it is a requirement to notify them of the installation. The installer must provide a certificate with their registration details.
You really need to get in touch with them and ask. Report them if they can’t/won’t Provide one.
Posted : 06/08/2020 10:45 pm
Thanks Neal
How /who do I report them to?
Posted : 06/08/2020 10:56 pm
Gas Safe Register, Trading Standards and the local council/building control would be a good start (if they are not qualified/registered)
Contact the installer first though and ask. They may have registered the install already and the certificate just not arrived yet ?
Posted : 07/08/2020 1:49 am
I contacted the plumber In the first instance, they said, you don’t need anything than what’s on the cylinder, implying no certification carried out.
I contacted gas safe. They said no G3 certification by them but as unvented is plumbing and not gas it could be another body.
I contacted CIPHE and not registered there, are there any others?
I’ve contacted building control now too.
Posted : 07/08/2020 12:50 pm
