I have a report, that is of vital importance to the future of our nation.*
I could do with inserting about a hundred images, in three different lots, into the appendix. They just need inserting in a simple grid layout, 6 or so to a page.
I can pdf print from the images, and the layout is ace.
Is there anyway I can do this in word?
Workaround at the moment will be to do a screen shot of the PDF'd images and insert...
*this may or may not be true, but it is for the Scottish Government...
Excel grid inserted in and pic per cell?
Or try inserting the pics normally then alter the "Text Wrapping" to "through" - you should then be able to out them anywhere you want.
Just insert a 2x3 table and insert an image into each of cells. Adjust them to be either the same height or width, add Figure reference into each cell, turn off table lines. Go home.
Yep - a table with an image in each cell
