FREELANDER DIESEL E...
[Closed] FREELANDER DIESEL ENGINE
6 Users
My freelander 1 diesel L series 2.0td engine is dead and i need a replacement,the engine code is 20T2N and i see other rover diesel cars with the same code engine but wondered if they will fit as i can't find a replacement engine local that i can look at .
Posted : 24/08/2010 8:43 pm
There's probably a whole bunch of people who could help you with this question at lro.com/forum
Posted : 24/08/2010 8:57 pm
HI cranberry Thanks for your info.
Posted : 24/08/2010 9:10 pm
If youre stuck a friend runs an independent landy business(inc breaking) in Scotland but sells (and races) worldwide. email me if required.
Posted : 24/08/2010 9:14 pm
am i the only one to spot the irony of the op's username ?
 U31
Depends if he's got rid of the IRD?
Posted : 24/08/2010 9:48 pm
speaking of getting rid of the ird i have read about people who have removed the prop and blanked of the ird prop hole but can you get rid of the ird box and put a driveshaft in its place which goes from the gearbox to the off side wheel like on a standard 2wd car.
Posted : 24/08/2010 11:03 pm
 U31
No idea, i only ever dropped the rear prop and run them front wheel drive when the ird went t*ts...
Posted : 24/08/2010 11:24 pm
Cant imagine the block would be any different, although werent there two versions of the 2.0 diesel ?
Yours isnt a TD4 I presume...
Posted : 24/08/2010 11:25 pm
Mine is the first engine they put in the freelander diesel called the L SERIES DIESEL ENGINE.
Posted : 25/08/2010 7:59 am
