I'm after curving some decking steps thus...
Your looking at the decking, 4 steps left, 4 on the right. each step/ tread on the left is 250mm deep, each on the right 500mm deep, space in between 4m.
I need a steady curve from 0 to 250mm ( which is the difference between 250 & 500mm ) over a distance of 4 meters. Say at an equal spacing every 400mm.
Is there a formula?
Draw it to scale?
You need to know the 'going' and the 'rise' when building steps
They are the overall height and the distance to be travelled. Look at building regs for advice. The formula is 2r + g = nlt 550/ nmt 700
I know the rise but thats not important atm. the treads are going level from right to left. If you were to look along the ' nose ' of the step it would curve outwards from 0mm to 250mm over a distance of 4.0m.
Bumping up.
Haze - Member
Draw it to scale?
Probably a formula, but drawing is easier - also different types of curve possible.
[URL= http://i597.photobucket.com/albums/tt59/mrben100/Curve_zps08b8dab7.jp g" target="_blank">
http://i597.photobucket.com/albums/tt59/mrben100/Curve_zps08b8dab7.jp g"/> [/IMG][/URL]
Edit: drawn in plan obviously
That's it. The red curve is the one I'm after. I need to transfer it to the decking though. If I was to devide the 4m up into 10 equal bits how much, going from L to R is each section bigger than the previous?
lay it all normally with an overlap - then mark the overlapped decking in situ with the curve you want
cut.
I have to curve the ' Rise ' which is a length of decking face on. Once I have the rafter ends cut to length to form the curve I can fix the decking riser. Once the ' rise ' is fixed i will overhang the decking tread and cut to length.
Trail Rat has it in one.
The pro's preferred method. No fannying about. Quick. Easy.
got a good jigsaw ?
Yep, my trusty Festo.
Well, for the puroposes of closure..........some check dimensions to the nearest mm based on a steady curve (radius shown).
[URL= http://i597.photobucket.com/albums/tt59/mrben100/Dimensionedcurve_zps83cc53a7.jp g" target="_blank">
http://i597.photobucket.com/albums/tt59/mrben100/Dimensionedcurve_zps83cc53a7.jp g"/> [/IMG][/URL]
Thanks mrben. What formula/ program did you use?
I lined up the riser today and clamped it into what I thought was the right position. When measuring I had 310mm and 370mm right.
Just goes to show that you can't beat the squint of a tradesmans eye.. 🙂
It's a beam camber (assuming you want the curve to be part of a true circle as shown by mrben above) there are a few different ways to lay it out, a compass method and a straight line method - google beam camber calculations (boatbuilding) and you'll probably find them.
tymbian - Member
Just did it in CAD innit (as use it for work), what your seeing is just a screen shot, drawn 1to1 scale and measured the results. I would only be able to figure out a formula having already drawn it.
