For the academics: ...
[Closed] For the academics: Endnote Question
7 Users
Using Endnote and Word I'm looking to add something into my references that I haven't actually cited within the text. Any idea how?
I can only seem to add my citations, and can't see how I can add anything else.
* This maybe means it's technically not a list of references, but I've seen it done elsewhere
Posted : 28/09/2009 8:45 pm
There may be an official way to do this, but if it is only one or two things, then you can just cite them somewhere you have a bit of white space, and change the font colour to white (and tiny font if you need space). I know it is very gross, but it does the job.
Joe
Posted : 28/09/2009 9:02 pm
No other suggestions, so might have to go with that method unfortunately 😕
Posted : 28/09/2009 10:51 pm
It sounds like the reference you want to add should go into your bibliography. From memory, your references should only be used to substanciate your direct citations in your text.
Posted : 29/09/2009 11:37 am
Joe's idea or type it manually.
Not sure why you'd want to have a reference for something that isn't mentioned in your text though?
Posted : 29/09/2009 11:43 am
 juan
A very simple solution to all your problems is in the words of linux and LaTeX.
Assle free once you have passed the learning curve, BiBTeX works a treat. Since you are an academic you really should support it anyway.
Posted : 29/09/2009 11:47 am
Now there is a contradiction in terms!
And Scruff is right, if you haven't referred to it in the text it needs to go in a bibliography.
But TBH, if it's important to include, then there should be a bit of text you could hang it off.
Posted : 29/09/2009 11:52 am
Insert the reference as normal, e.g.
{Aplin, 2007 #447}.
But delete the author and date to leave:
{#447}
When you format the bibliography the code will disappear but the reference will appear in the bibiography.
Posted : 29/09/2009 11:57 am
