Hi all
i need a suitable floor for a tiny pizza oven 300mm x 340mm
what do you recommend?
Soapstone if you can find any ... not cheap.
[url= http://www.worktopfactoryy.co.uk/ResourceCentre/EncyclopediaOfStoneWorktops/SoapstoneUses/tabid/1786/Default.aspx ]Custom some from them?[/url]
Salvage yard in Glasgow (you'll have one locally) sells old slate bases from pool tables, folks get them cut for fire hearths, I reckon they would be ace as are perfectly flat, smooth and are real easy to cut with a wee cutting disc.
They're not expensive.
Must be good with heat too.
Edit - just clocked your sizes - a ceramic tile will be ideal, and cheap.
It needs to be heat resistant but also absorb/distribute heat evenly
[url= https://uk.uuni.net/products/uuni-stone-baking-board ]https://uk.uuni.net/products/uuni-stone-baking-board[/url]
if you have the abilities to trim one edge
Looks just the job - would it withstand the heat of a fire directly on top?
Google fire bricks, the floor needs to be able to withstand 6 or 700 degrees C and it also needs to absorb and then radiate heat in order to cook the base.
Don't forget to insulate under the fire bricks.
I recommend a bigger pizza oven!
I wish i could have one!!
Looking at it i "think" i need 5 x 220*110mm bricks
http://shop.vitcas.com/vitcas-fire-bricks-white-866-p.asp?gclid=CjwKEAjw5_vHBRCBtt2NqqCDjiESJABD5rCJ7qLLlStbgeI7X0vB15hdYmZNpswLk0_Cpm0GrvlaSBoCnx3w_wcB
