[Closed] Flickr
5 Users
Most of my photos are in sets, there are some photos of items I have sold and I would like to delete these. If I delete the set it does not delete the content. How can I delete the photos without doing it individually?
Posted : 13/06/2010 3:43 pm
should be able to do it in the organiser?
Posted : 13/06/2010 3:46 pm
Even in organizer it says "Don't worry none of your content will be lost"
Posted : 13/06/2010 3:50 pm
in your photostream under each thumbnail is a delete function , i`ve used that , seems to work .
Posted : 13/06/2010 3:55 pm
You have to do it individually, and even with this I think that Flickr still keep a copy.
I've 40 odd thousand to remove before closing my account, Yahoo are shiiiiite! 😥
Posted : 13/06/2010 3:59 pm
You can batch delete.
Go into organiser, batch organise, select set at bottom, drag all items into organizer window, choose edit photos - delete
Says "This will permanently delete these items from your Flickr account and cannot be undone."
Posted : 13/06/2010 4:09 pm
Live and learn, thanks.
Posted : 13/06/2010 4:19 pm
Found what ebygomm and Cheesy mean, still far from conveinient when you have grouped your images.
Posted : 13/06/2010 4:21 pm
Did you select your set in the bottom left? Fail to see how it's inconvenient if you did that.
Select set, drag drop, delete, repeat for further sets.
Posted : 13/06/2010 4:24 pm
Oh I see in the drop down menu?
Posted : 13/06/2010 4:40 pm
Yes, you should be able to select the set there so you can easily delete all the pictures that are in one set.
Posted : 13/06/2010 4:50 pm
thanks for your help.
Posted : 13/06/2010 5:02 pm
