Flash question?
[Closed] Flash question?
3 Users
Sorry not for CFH but sure he will suggest I ping something!
Can somebody suggest a good/free program to create basic Flash movies? I only want to add in a number of images to rotate so sure this shouldn't require me buying the full CS4 package!
Thanks Shakey
Posted : 21/08/2009 5:26 pm
Easy to do in JavaScript if you want to put them in a website - only requires N++ (NotePad).
There should be a script you can nick off the 'net somewhere, or I'm sure someone on here either has one or could run you one up.
I could put the code together, maybe, if you can't find one.
Posted : 21/08/2009 6:09 pm
Marvellous!
Posted : 21/08/2009 7:13 pm
Hi JulianA, I have found some neat bits of code but unfortunately I only have access to the Body section of HTML and most of the examples require adding code to the Head and Body.
Is it possible to find a bit of JavaScript which will only require insertion to the Body or will I have to resort to a Flash movie?
Thanks Shakey
Posted : 21/08/2009 7:49 pm
Hi Shakey
I seem to recall that you can add <script>...</script> tags anywhere in a document, but don't know if that will work for what you want to do. Give it a try and let me know - just sorting out spag bol (and rioja!) at the mo, so might have to be tomorrow!
Posted : 21/08/2009 8:23 pm
Sounds good - curry and Woolloomooloo (cracking Aussie Merlot/Cab/Shiraz) for me tonight. I'll give it a go and thanks for your help. Shakey
Posted : 21/08/2009 8:47 pm
Any joy Shakey?
Posted : 22/08/2009 3:24 pm
