Fitting a boiler - ...
[Closed] Fitting a boiler - legislation/regulations
6 Users
 Pook
We've been told our builder hasn't put the flu in right. Where can I find out if he has or not to check it?
Posted : 11/04/2011 7:52 pm
Look for your nearest HETAS installer who can inspect it. All boiler flues should be a HETAS approved installation I thought.
You could have a go at diagnosing some issues from the building regs if you like (NB regs arent the same as hetas guidelines):
what's he not done "right" then and who told you?
Posted : 11/04/2011 7:56 pm
 Pook
another builder told us that the outlet/flu goes out onto a neighbours land and so either needs re-routing or extending up the building further.
Posted : 11/04/2011 7:59 pm
see page 43 of the regs, table 3.4 and table 4.2
(Planning portal is down for me so use this link)
Posted : 11/04/2011 8:11 pm
The op dose not mention solid fuel Stoner, this could be a gas boiler issue?
If this is a solid fuel boiler Part J of the building regs I think. Hetas is only needed for self certification. The other builder may use building control.
Posted : 11/04/2011 8:15 pm
Probably just needs a plume management kit. What model boiler is it?
Posted : 11/04/2011 8:19 pm
 Pook
baxi duo tech 28
Posted : 11/04/2011 8:21 pm
building control restrictions still apply to gas flue locations at boundaries.
Gas Combi? Most installation guides are like this:
[url= http://www.worcester-bosch.co.uk/installer/products/gas-boilers/greenstar-37cdi/flue-terminal-positioning ]Flue Postioning[/url]
 Taff
600mm horizontally from boundary edge rings a bell. can be taken up the face of the building but there's normally a maximum length of flue run
Posted : 11/04/2011 8:54 pm
