Firefox add ons any...
[Closed] Firefox add ons any good suggestions
14 Users
Just started using Firefox, any good add on's pepole are using ?
Thanks
Posted : 04/01/2010 5:13 pm
Yes ... but I'm on the work laptop with IE6, so can't recall them!
Posted : 04/01/2010 5:15 pm
webmail notifier is about all i really use. puts a little ico in the bottom corner to notify of new mails on hot/google/yahoo mail etc
Have a look [url= https://addons.mozilla.org/en-US/firefox/recommended ]here[/url]
Might be something of interest?
Posted : 04/01/2010 5:18 pm
Had that one Jimmy for gmail worked perfectly or a couple of days then stopped working !
Posted : 04/01/2010 5:19 pm
NoScript for me - it basically stops anything you haven't approved running on webpages. At first you have to approve things (like 'approve singletrackworld.com'), but it then remembers that you approved stw and so it runs as normal.
The point is... it stops any malicious cr@p running that might bog your PC down. I've not had a single virus/ trojan/ malware since starting using it, compared to quite a few beforehand.
Posted : 04/01/2010 5:25 pm
I found a great one that takes a table on an html page and treats it like a spreadsheet. Allows you to select single columns or rows or even individual cells. Very useful. I forget what it's called though so that's not much use to you.
Posted : 04/01/2010 5:29 pm
 Creg
personas is fun if you want to change the appearance.
Lazarus is good if you tend to write a lot on forums. It saves the content of text boxes as you type, so if you accidentally come off the page, if your connection is dropped or if you get stung by a 'server busy' page, then you can recover what youve already typed. You can turn it on/off as desired, so it's security concsious.
SmoothWheel, Multiple Tab Handler and NoScript are all great add-ons. PDF Download is available to turn any web page into a PDF document.
Posted : 04/01/2010 5:45 pm
Second noscript. Also use DownThemAll which allows you to rip all pictures etc. with one click.
Posted : 04/01/2010 6:03 pm
The Met Office weather gadget is good.
ABP as said is ace.
Posted : 04/01/2010 6:29 pm
download statusbar
selection links
split panel
and lavafox theme
Posted : 04/01/2010 7:01 pm
 mboy
2nd vote for DownThemAll
Use Flashdance if you're fed up with the Flash adverts on this forum...
Posted : 04/01/2010 7:03 pm
If you are running it on a netbook or small laptop then little fox squeezes up all the menus at the top.
Posted : 04/01/2010 7:18 pm
 Rich
Downloadhelper, Fastestfox, Forecastfox and Youtube to mp3 all worth a look.
Posted : 04/01/2010 7:51 pm
