faulty washing mach...
[Closed] faulty washing machine
Got a indesit washing machine wib118 and it's not draining and basically washing the clothes in filthy water. And won't do a full cycle. You have to drain, rinse then spin seperatly. Blocked filter maybe?
Posted : 16/09/2013 9:19 pm
Is it going round in the way it should?
Had similar problems a while back. Just needed new motor brushes. £25 for parts. Job done.
Posted : 16/09/2013 9:26 pm
Blocked or failure of the drain pump? I recently replaced our drain pump, straight forward job and cheap on parts (eSpares I think...)
Edit: Is it noisy when it tries to drain?
Posted : 16/09/2013 9:28 pm
It spins normally yeah. Makes a buzzing sound when draining. It's draining outside just not loads of water coming out the pipe.
Posted : 16/09/2013 9:38 pm
just took the 3rd indesit to the tip, and as per usual its broke, first one bearing fault, to expensive to get fixed, second one,electrical problems, 3rd one self destructed after belt came off and drum came loose.
Funny they spell indesit with out the h
Posted : 16/09/2013 9:39 pm
