Exhaust repair goo ...
[Closed] Exhaust repair goo - is it all the same or is there a winner?
6 Users
Got a bit of a blow from the rear box on my car which I want to temporarily fix. I've used Holts gun gum before which was OK but is there a better alternative?
Posted : 09/03/2014 3:22 pm
Is it a fancy car ? Exhaust back boxes are not expensive these day. Temporary repairs ime have always been shit.
Only temporary repair i will waste my time with now is a patch from the mig.
I bought the back box for the van for 32 quid and replaced it in 20 minutes recently when it was blown.
Youll spend more than 20minutes farting round with a patch kit
Posted : 09/03/2014 4:21 pm
Blob of emetal till you can get a new back box.
Posted : 09/03/2014 5:20 pm
use a cut open coke can as reinforcement if you're using a bandage type repair.
Posted : 09/03/2014 5:37 pm
Its actually on a seam that will be pretty easy to get a good seal on using just goo. Car is an XC90 and amazingly you simply cannot get aftermarket exhausts!
Volvo replacement box would be £450 plus fitting and a used one will be £160.
Posted : 09/03/2014 5:47 pm
Gun gum is rotten but I had decent results by adding an exhaust bandage in a tight wrap over the top- stopped it from cracking and falling off like it usually does.
If you know any proper garages, a messy but solid weld-up shouldn't be too much hassle to get. (the flexi on mine was done at some point by the previous owner, terrible blobs of birdshit but it wasn't new when I got the car and it's only just failed now 2 years on since I got it, so not too shabby that. Not really structural so it doesn't have to be that strong.
Posted : 09/03/2014 7:36 pm
Would hope it would have decent thickness steel so I would see about welding. You will normally get moisture trapped around the gum stuff so they seem to rot even faster.
Posted : 09/03/2014 7:44 pm
