Exel question
[Closed] Exel question
I'm a dullard, so this will probably be a simple one.
I'm editing a workbook created by someone else, putting tasks into a simple programme of works for a year.
I've added a column to put numbers in relating to the frequency of the task, so I can filter.
So far down the sheet, when trying to input a number, all I get is a hashtag in bold. Formatting the cell to numbers or general, unlocking the cell, changing the font etc all make no difference.
Help please
Ta
Posted : 24/06/2017 10:08 am
Make the column wider?
Posted : 24/06/2017 10:12 am
 poly
Make the column width bigger - it usually means you can't fit the content it then you can work out why...
Posted : 24/06/2017 10:15 am
Nope, 52 fits, 1 shows as a hashtag - can't get it off bold either
Posted : 24/06/2017 10:19 am
Is it some sort of crazy conditional formatting?
Home -> Conditional Formatting - Clear Rules
Posted : 24/06/2017 10:21 am
Conditional formatting is greyed out
Posted : 24/06/2017 10:24 am
Sounds like the "someone else" who made it has done something to stop you from doing too much then.
Beyond me now, I'm out ๐Ÿ™‚ ๐Ÿ˜‰
Posted : 24/06/2017 10:25 am
Can you save your own copy as a different format, binary workbook, something like that? This should bring all options back.
Posted : 24/06/2017 10:29 am
 poly
But do you know if it is actually showing 1 or 1.000000000 or some other odd thing? If you select the cell and it is a number it's content is usually shown in the status bar (but not its formatting).
Is the cell protected? That sounds likely if you have it in bold. In which case google for unprotected cell for whichever version of excel you use. Hopefully it's not password protected - although excel passwords are about as much use as Poundland bike lock....
Posted : 24/06/2017 10:32 am
Sorted
Saved as a separate CSV, then back to Exel, then copied and pasted that column and all seems ok now.
Ta for helping
Posted : 24/06/2017 11:04 am
