Excel help - adding...
[Closed] Excel help - adding columns
As far as I can tell, the max number of rows and columns is preset. There's 65,000 rows yet only 280-odd columns (up to IV). Is there a way of adding more columns? Cheers!
Posted : 15/02/2010 5:04 pm
256 - I believe & no
Posted : 15/02/2010 5:05 pm
 mrmo
if you need more columns, why? buy Excel 2007, or try and create lookups between Worksheets.
Posted : 15/02/2010 5:10 pm
[i]if you need more columns, why? buy Excel 2007, or try and create lookups between Worksheets. [/i]
A girl at work's trying to do a holiday chart with all 365 days going across - it's not happening for her though! As resident Excel 'expert' I'm meant to know how to sort it out......
Posted : 15/02/2010 5:13 pm
Use the columns for months & the rows for days or split it into 2 spreadsheets
Posted : 15/02/2010 5:15 pm
 mrmo
i would have thought it would make more sense to run days as row headings and i am guessing staff names? as column headings, then run over a number of worksheets if you have more than 256 employees?
Posted : 15/02/2010 5:20 pm
 Tim
Bin out the weekends?
Posted : 15/02/2010 5:24 pm
I take it maths is not your strongest subject? ๐Ÿ˜€
Posted : 15/02/2010 5:27 pm
 Tim
I made the (admittedly large)assumption that it was a mon-fri job
so binning out 2 days a week that woudnt be used - about 100 less columns
should fit in less than 280 columns
HTH!
Posted : 15/02/2010 5:47 pm
indeed it would, unfortunately there's only 256 available ๐Ÿ™‚
Posted : 15/02/2010 5:49 pm
 Tim
I assumed the OP was correct ๐Ÿ™‚
Posted : 15/02/2010 5:51 pm
you are stuck with 256
or buy 2007 which is unlimited
Posted : 15/02/2010 8:21 pm
Standard request from secretaries trying to do tables in Excel instead of Word ๐Ÿ™‚
Turn it round the other way and use the rows.
Or use Windows Excel Fisher Price 2007 for Dummies ๐Ÿ˜‰
Posted : 15/02/2010 8:45 pm
Bit of a longshot, but...
I know if you want to run a pivot table with more than 65000 rows you can link to a csv file and run it from that.
There might be a similar workaround which applies to [b]columns[/b] and could be used in a non-pivot table situation?
That said... I'm not sure how exactly you'd store the information in csv format without using Excel 2007 and saving it as a csv file!
Posted : 15/02/2010 8:53 pm
