i want to buy an espresso machine but need help from the STW baristas!
Now i know i can make an espresso with an espresso machine, but how do you make the coffee you get in some restaurants? The type thats not as intense as an espresso, comes in a much larger cup and still has the important crema layer?
Are the cheap machines any good (Delonghi do some starting about 60-70 quid, still 15 bar pressure)? I always have black coffee so not fussed about milk frothing ability.
Lastly, do i have to use espresso coffee in an espresso machine? Just wondering as i also like to have filter / cafetiere coffee and enjoy trying stuff from different areas as they often have different tastes. If i used this in an espresso machine would i still be able to make good coffee with it, or are these beans just meant for use in filter machines / cafetieres?
thanks!
I have a Delonghi. It works just as well as my mate's KitchenAid. Doesn't look anything like as nice, and actually I'm on my third in the period he's had the KA. I'm still ahead on cost...
The difference between the coffees labelled as filter etc is the grind. You need a much finer grind for espresso so that you can tamp it good and solid. Filter / cafetiere grind is so coarse that the water goes straight through. I always grind my own, and do it fresh.
IMO it's worth spending a lot on a proper grinder more than on the machine - 15 bar is 15 bar whether the machine costs £60 or £600, but a cheap grinder will wreck the coffee before it gets near the machine. The Kitchen Aid Grinder is worth the money.
Finally, I've yet to find a decent coffee at a supermarket, yet the cheap and cheerful beans at Costco makes a really good cup for everyday drinking.
Lavazza Red is as good as [b]any[/b] thing else.
Grasshopper, your journey will be long and hard, if starting from this point.
I aint going to read all this sorry but here is my great advice
£50 on a 2nd hand 15 bar machine or one in the sale with manual control of the amount of water it puts into the beans
try and get a burr grinder if you can afford it but its likely another £50 minimum but this is the best thing you can do on a budget
dont get an electric grinder
and to answer your coffee question its all the same the difference is how fine you grind it, also effects the crema
dont try to squeeze too much water past the beans or it goes sour and you will have white speckles in the crema
das is all 🙂
Lavazza Red is as good as any thing else.
Try grinding Monmouth beans.
And don't start researching how to make the god shot. Its a long obsessional road. I've been there. And never made the god shot.
Basically as others have said, critical variables are temp, pressure, tamp, grind, pour and beans.
In my experience beans make the biggest difference, perhaps obviously perhaps not. Then the grind.
FWIW I have the Kitchen Aid machine and Grinder - is expensive but a decent machine. KA customer service is second to none - I've had 3 machines break (bad!) but all have been replaced FOC and next day.
Lavazza Red ?!?!? That is obviously a troll, and I've bitten. Lavazza Red is a blend FFS, and uses robusta ! You obviously have no taste buds whatsoever.
Also, a hand burr grinder makes a good grind but takes forever...
cheap hand burrs are temperamental tho, i wouldnt recommend
good shout on the troll
Gaggia Classic from Fleabay, repairable, tough, does a great coffee. Don't use it exclusively if you want to explore coffee. Filter coffee gets something different out of different beans so use that too.
Find a local roaster and experiment - I never met an Italian who used Lavazza when I lived there.
This is true. Try cold press too.
Some decent advice some rubbish.
First and foremost, buy good freshly roasted beans, don't bother with pre-ground heck don't bother with most of supermarket whole beans either as you have no clue how long they are on the shelves. Plenty of very reasonably priced roasters around that will mail you great coffee.
Second dont buy an espresso machine before you buy a grinder. 100£ for a decent burr one and you are set for.
Look into Gaggia Classic or Gaggia Baby, I think they are very similar and quite reasonably priced. If you can spend more spend it on a better grinder.
Good luck...
IMO a cafetiere is better than a filter. I use a cafetiere at work, espresso at home. If I use one exclusively I miss the other. The coffee maker, that is.
Much more caffeine out of the cafetiere...
Get a decent supply of beans. I use [url= http://www.hasbean.co.uk/ ]Hasbean[/url]. Beans are generally delivered within 2 days of roasting.
A secondhand Gaggia classic is a good recommendation. How about [url= http://cgi.ebay.co.uk/GAGGIA-CLASSIC-Espresso-Machine-Coffee-Maker-/170561206474#ht_546wt_1141 ]this[/url] one? I had one for a while.
And get a decent grinder.
You obviously have little understanding of what an authentic Italian espresso is about.
roasted in Pozzuoli on the edge of Naples
which has sweet FA to do with anything
I have a gaggia classic in new condition that i would sell for a reasonable offer + postage.
alexxx - Member
Very confident!
Really, prefer a steam or nuclear powered one?
..... so all beans are equal?
Sorry, it's bean (sic) a long day and I'm tired and a little drunk / cantankerous. Hic.
fresh beans are the key - http://shop.squaremilecoffee.com/ are good. I use a Bialetti stove top and love it.
It does actually - an example of Italians not using Lavazza. Also, that local roasted beans are usually a better option - provided the roaster is up to scratch. Why not add to the discourse rather than just throwing poo like an angry wee monkey?
Gaggia Classic and beans from hasbean.co.uk here. All good.
Lavazza Red is a ground blend. Using cheap/nasty Robusta beans. Not sure what an authentic Italian espresso is about but if it was meant to be good it would be with freshly roasted and ground Arabica surely with maybe a littel Robusta for crema?
You can buy as beans or pre-ground. Maybe my pallet just isn't refined enough for nicher end of the market. Good luck with it though, I'm sure the extra expense and effort is worth it if it's your thing.
Italy is a big country, so beans roasted in Naples means bugger all in Livigno - was my point.
I'd buy a Gaggia Classic if I could but have bought a stove espresso maker. Good enough to replace blood with coffee.
The coffee you asked about, pour some hot water into a cup, say 100ml of it, and then and only then set your espresso onto it. Don't do the opposite as it'll burn the crema.
For a starter I'd advise two different beans/blends, you need to see the difference. I have two Lavazza bags - red and blue. I prefer the red from a cafeteri e whilst the blue is great for the espresso maker. Horses for courses, as they say.
BTW You won't make a perfect coffee anyway, there'll always be somebody "better" than you here.
its all about the beans:
[url= http://www.happydonkey.co.uk/costaricanbeans.html ]beans[/url]
[url= http://www.happydonkey.co.uk/coffee-bean-advice.html ]bean advise[/url]
a Gaggia classic from here
[url= http://www.homewares.co.uk/gaggiaspecialists/10080.html ]classic[/url]
"I'm sure the extra expense and effort is worth it if it's your thing."
It is and it is.
Maybe some of us are [url= http://en.wikipedia.org/wiki/Supertaster ]supertasters[/url], we're all different.
Stove-tops about 3-4 bar I believe. That's why they're called mocha, i.e. it's a mock-espresso. However, much better than nothing when camping.
certainly is
gaggia classic and coffee from monmouth or square mile.
an ascaso grinder to be purchased soon.
i don't understand why people have a good machine at home but use overpriced coffee that's possibly months old like illy or lavazza when you can buy coffee/beans for the same price (or less) that was roasted in small batches by hand on days before.
Ignoring the beans - just experiment and drink what you prefer, even if someone on the Internet thinks you're a peasant for it - I have the cheap de Longhi (the Caffe Treviso), it works ok although I find a good thick crema still just about eludes me. Keep an eye on prices, you can often find it for £40 which makes it a bargain - I'm sure a Gaggia is better but the diminishing returns must kick in pretty hard.
However, a stovetop pot will do just as well. A Bialetti is probably as much as the Treviso, but a Chinese copy will set you back £10-15. It takes up less space in the kitchen so is ideal for occasional use and still makes great-tasting coffee, but you won't get a crema.
If you're grinding your own beans then a blade grinder is no good unless you want piss-weak espresso, you'll need a burr grinder.
If you don't want to grind every time you have a coffee, you can stick grounds in the freezer in a sealed pot - they'll be fine for a week at least IME.
The long coffee you're asking about is an Americano - espresso with added hot water.
2nd mr smith , small artisan roasters are often cheaper an streets ahead in terms of quality
I'm gonna make a coffee...
good idea MF...
However, a stovetop pot will do just as well.it works ok although I find a good thick crema still just about eludes me
this is why i was happy to pay fro a decent home espresso machine.
if you like perfect coffee why compromise.
a s/h gaggia is only £150. i have a babyD that i only paid £50 for as it was missing a drip tray cover and the lid to the water tank, it makes perfect espresso. the group head/boiler are the same as a classic but i wanted a stainless body not plastic.
The SS stove jobbie can be had from Whittard for £24 IIRC. I'll be buying one tomorrow or on Tuesday. The cheaper copies corrode, mine did after only 7 weeks.
Don't get a Dualit Expresif - had on on holiday and it was shite
freddy you are...
its called
sarcasm
missing word - blade
and related to grinds... not beans
now please have a nice day
Advice?
Do want you want to get a cup of coffee that you enjoy. There's so much snobbery and bollards talked about beans and coffee and crema and espresso than nearly anything else.
not as much as in mountainbiking.
Did this get answered? I can't see a reply.
The difference is in the coarseness of the ground coffee. Espresso grounds are finer than grounds designed for filters / cafetieres. Other than that, it's the same stuff.
Apart from, perhaps, the beans themselves and the roast. So, not the same stuff.
Oh good grief.
The difference between (brand and type)'s espresso grounds and (the same brand and type)'s filter coffee grounds is the coarseness of the grind.
The difference between (brand and type)'s espresso grounds and (a completely different brand and type)'s filter coffee will be considerably more.
The difference between STW and other forums is on most other forums pedantry isn't considered a competitive sport.
Just about coming to the end of my first bag of espresso and dabbling with what to get next... Have tried Lavazza red (which is quite pleasant) and am wondering about asking for a Hasbean subscription for xmas. Has anyone tried that?
Grinding beans is not an option so what source of ground would anyone recommend?
Ask for a grinder as an Xmas gift 🙂
HasBean espresso beans are normally very very good so you can't go far wrong.
The closest one to your house. Find your local decent coffee supplier and get it ground there. Or save for a grinder.
I want 15b ar on the stove top godamnnit - over to the engineers...
Are AeroPress coffee makers any good?
They are excellent - no substitute for anything else, but great. I use one every day at work as it is better than anything else available.
Has any one tried a [url= http://bit.ly/dg0Gl7 ]nespresso[/url] machine. My mate swears by his and it's idiot proof (his words)
Aeropress does not make an espresso and it does not make filter coffee either but it does make a really clean, tasty cup indeed and for a quick easy portable way to have coffee cannot really be beat.
Two downsides though, it takes a lot of coffee to make a cup. Forget the 7-8 grams of an espresso, you need twice as much at least and for a mug dose well over 16-17. Second if you use it a lot (I use mine an average 3-4 times a day) over a period of a year and a bit it does not seal as well as in the beginning so you lose pressure and you can have coffee leaking up on the sides and also the filter holder develops a bit of a curve in the middle so you eventually get weaker coffee.
Having said that it costs as little as 17£ to replace.
Nespresso is great. I bought one in August after a lot of thinking about what to get - stayed in a holiday place with one and was hooked. It is really convenient and makes very, very good coffee - seems wrong to me that something that easy can consistently make coffee that good. Sure, it's not the cheapest or most involving way to do things but for me it's ideal - to be honest I'm more interested in the outcome than the process.
Some people don't like it because it does takes the art away from making espresso and puts you in the hands of Nestle for all your bean needs, but with about 15 different blends it's hard to see how I'd tire of the choices available to me, and I don't think Nestle will dinghy it any time soon.
I have a nespresso machines its brilliant and the coffee range is great, no mess and really quick to heat up. Highly recommended.
Hi I would recommend a Rancilio Silvia and Rocky combination I have been using one for the last 10 years the Silva had a new boiler last year easy cheep diy Job. the grinder is way more important than the coffee machine you need to budget at least as much for the grinder as the machine. I would suggest you have a look at http://coffeegeek.com/ before you buy.
Regards Keith
nice naked portafilter and posh tamper.
I have no idea what you're doing there fella. 1.5 scoops of coffee will make a strong mug - just let the first fill filter through as you stir, top up the water then plunge. I've used mine about the same rate as yours for at least 2 years, a colleague a year longer and have no seal issues at all. The (tiny) curve in the filter holder makes about no difference as you plunge the coffee grounds onto it anyway.
I'm nipping out for a starbucks.
Anyone coming?
DrP
so what's the general consensus on how to make a good cup of tea then?
http://www.singletrackworld.com/forum/topic/what-is-the-best-teabag-tea
To summarise - Yorkshire tea.
TooTall the scoop that comes with the aeropress is a 12gr scoop. If you use one and a half you are using exactly what I am suggesting - 18gr, that is well over two times as much coffee as you would use on an espresso maker. Even the maker recommends two scoops - 24-26gr for a 10 ounce mug.
Other than that I do nothing different than you, and I do have non sealing issues as well as the water coming only through the centre on my old aeropress while coming through the entire filter on my new one, so the curve in the middle is making a difference. Maybe my first Aeropress was a tad defective, I don't know, see how well the second one will do.
