Electronics - fairy...
[Closed] Electronics - fairy lights too bright
[#6598599]
I've got a set of LED fairy lights and I'd like to be able to reduce or preferably adjust their brightness.
They're plugged into a black box power so I thought I could do something with the low voltage circuit. I'm guessing these lights are too low power to require a fancy constant current driver like bike lights do - so it's just a case of dropping the voltage somehow, yes?
Do I need a voltage regulator? I'm guessing a series resistor isn't a good idea.
Posted : 31/10/2014 12:39 pm
Can you not just stand further away?
Posted : 31/10/2014 12:42 pm
No.
Posted : 31/10/2014 12:44 pm
You need to reduce the current somehow. How will depend on how they are wired. They might have a constant current driver, no reason why they wouldn't just because they aren't bike lights. More likely they are wired with a mix of series and parallel and run from a constant voltage supply. A resistor might do it in that case but you'll need one with a high enough power rating or just swap the supply for a lower voltage one. Another option is to put a FET in series and PWM them but that is getting a bit tricky unless you have the bits to hand.
Posted : 31/10/2014 12:46 pm
Look up a PWM motor speed control/LED dimmer
Should be easy to splice into the DC side.
Posted : 31/10/2014 12:47 pm
no. you need a current regulator.
series resistor is bad, and only really a simple hack for a single LED.
what is the voltage and current output of the power adapter?
Posted : 31/10/2014 12:51 pm
[url= http://www.maplin.co.uk/p/l200cv-2a-adjustable-voltage-and-current-regulator-yy74r ]Like this?[/url]
Power supply is 24V and the label says 24x0.03W which I make out to be 1.25mA for each LED hence 30mA total.
Nail polish on the LED?
Posted : 31/10/2014 12:54 pm
ahh just saw the 24V bit, 24V ones are available. Just a case of finding UK stock if you want it quicky. For the money I don't think I would bother putting something together myself from Maplins. They may have a DC PWM motor speed control kit cheap though.
Posted : 31/10/2014 12:58 pm
Would those PWM controllers not flicker though?
Posted : 31/10/2014 1:04 pm
not if the frequency is high enough
Lol.. searched for LED dimmer on ebay, they are available for £1.07 from China. FFS I can't even buy the IC from Maplin for that.
Should've searched before thinking of doing it myself!
Posted : 31/10/2014 1:08 pm
Just measure the current draw and then stick a resistor in series with it.
Posted : 31/10/2014 1:50 pm
