Electrical help! Ca...
[Closed] Electrical help! Cable detectors??
5 Users
I need to fix a bracket to a wall. I don't have much leeway, if any at all, and I know there's a cable under it, or very close. How good/accurate are those cable sensor/detectors you can get?
Thanks in advance
Posted : 13/11/2010 2:37 pm
Just use a rubber drill bit to make the holes, and you'll be safe.
Posted : 13/11/2010 2:58 pm
HA BLEEDIN HAA! 😉
Stuff it. Just dug me a hole in the wall and had a root round. I'm OK to drill*
*If I don't report back in an hour or so, I was wrong and I'm dead.
Posted : 13/11/2010 3:07 pm
Still alive. Cupboard fitted. False alarm!
Posted : 13/11/2010 6:06 pm
You've done the right thing: cable detectors give false positives left, right and centre; just dig carefully into the plaster with a screwdriver or something else not too sharp!
Posted : 13/11/2010 6:11 pm
Mine has an adjustable sensitivity on it, was just a basic screwfix one.
Posted : 13/11/2010 6:24 pm
Lady i worked for once, she asked if i had a cable detector i said yes of course.
She said when she got married they got given a metal shield with two swords across it,with their name on it the new husband was also the proud owner of a new dril, so he decided to put the shield up.
Drilled the hole underneath a wall light that was switched off, he stepped back to look at his handy work, and noticed the shield was leaning so touched the shield , just as his wife switched on the light, he got an electric shock, he had drilled the cable.
He is now a Health and safety officer.
Posted : 13/11/2010 6:30 pm
