electric water bath...
[Closed] electric water bath/bain marie - help
I want to heat a some liquid to a specific temperature and hold it there for a while (below boiling point). I've tried it on a stove but it's a complete PITA and I just ended up with loads of hot and cold spots.
Are there any bits of kit out there that would allow me to do that? I thought something like an electric bain marie would work?
Any ideas would be much appreciated!
Posted : 16/05/2014 7:07 am
Bowl of water in a low oven?
Posted : 16/05/2014 7:10 am
I had considered that, but I need the vapour (alcohol) to escape. Might not be a good thing to build up in my oven 🙂
Posted : 16/05/2014 7:12 am
Slow cooker?
Depends on what temperature you want.
You can build circuits that will maintain a certain temp in a slow cooker for sous vide cooking ~65C IIRC.
[Edit] Crossed posts. May not get hot enough. [/Edit]
[Edit Edit] From Morphy Richards:
Low setting - Around 80 degrees C
Medium - Around 90 degrees C for 1hr then drops to low temp for rest
of time.
High - Around 90 degrees C
[/Edit Edit]
Posted : 16/05/2014 7:13 am
One of these?
[edit] alcohol you say?
The high setting on my slow cooker might work....i'll try it when I get home!
It needs to be around 82 degrees.
Posted : 16/05/2014 7:17 am
Hopefully not peterfile's house later 😯 :
Posted : 16/05/2014 7:20 am
I think you're Heisenberg and I claim my £5.
I'm not certain though.
Posted : 16/05/2014 7:26 am
haha 🙂
A good friend has just given up alcohol due to some non alcohol related surgeries. He loves beer though, so I've been removing the alcohol from some of my beers so that he can still enjoy the odd porter/stout etc. But, doing it on my stove is a real PITA!
Posted : 16/05/2014 7:34 am
A sous vide machine would do the trick, but not cheap.
Posted : 16/05/2014 10:51 am
What temperature do you need it at? For other reasons (cooking) I've kept water in a coolbox at a 'fixed' temperature just by using a thermometer and adding more hot when needed. The temp is good to a couple of degrees. The trick is to have a large volume of water compared to the thing you are cooking (in your case heating up). Then stick your pot with beer in the middle of the coolbox filled with water
still a faff though. If you need to automate it you can use a small pump and there are temperature controllers out there to control the heater that work very well for about 30quid in parts I think
Posted : 16/05/2014 11:20 am
For the quantities involves this might not work but - maybe try looking on ebay or amazon for heated magnetic stirrers
basically a hot plate with a spinning magnet inside - you stick your pan (obviously non magnetic) of booze on top and drop a little plastic coated magnet in as well - that spins around and keeps the liquid moving and the temperature even.
Amazon recommends
"Customers who bought this item also bought the Breaking Bad Box Set"
Posted : 16/05/2014 11:38 am
