DSLR Camera questio...
[Closed] DSLR Camera question - Lens performance
I know 5e I was replying to Graham too 🙂 Not sure if it was needed though.. anyway as you were 🙂
My Dad bought that Chinon when we were little kids and really looked after it so it stayed mint. He decided it was too much faff after taking it to my Sister's graduation and taking loads of pics only to discover there was no film in it, so he gave it to me for I think 20th or 21st birthday. Best present ever to be honest, because as a kid that thing was like a holy item with which I was utterly fascinated.. endless questions asked on my father's knee, demonstrations and supervised picture taking.. a symbol of the whole father-son relationship 🙂
Then someone burgled my shared house in Didsbury and nicked it.
Posted : 25/05/2011 9:45 am
5th: yeah it supports camera control (you set it to f22 then flick that little lock switch) then it will function like a normal modern lens and only stop down when the shutter is pressed.
grips: I'm pretty sure that on this one the aperture ring manually moves in the aperture blades so it stops down as soon as you turn it and the preview button has no effect (but I never actually use it like that so I'm not certain).
The only time I've ever really used the aperture ring is with the lens off the camera when I'm explaining aperture to someone new to photography.
i.e. showing them something like this:
Posted : 25/05/2011 9:46 am
That's very neat. I must admit, I do like aperture rings. Seems a sensible place to put the control.
Posted : 25/05/2011 9:50 am
Well again on my old stuff, when you took it off the camera turning the ring moved the aperture. However there was a little lever in the mounting plate that the camera flicked up when you attached it, keeping the aperture wide open until it needed to be moved.
You could jiggle the lever and see the aperture open and close with a lovely snicky snicky snick. Your lens might also have one.
Posted : 25/05/2011 9:53 am
It does have a certain amount of logic to it - and it makes the aperture scale much easier to understand when you can see it all in front of you, where one stop is literally one clunk of the ring.
But...
It means every lens has to have the additional weight, size and mechanical complexity required for the aperture ring and your apertures are limited to full stops, rather than half or third stops on most modern bodies.
Posted : 25/05/2011 9:56 am
Hmm.. maybe it does then. I'll have a play tonight.
Posted : 25/05/2011 9:57 am
Mine had half clicks...
Posted : 25/05/2011 10:05 am
"I thought that when using the viewfinder (i.e. when not acutally taking a photo) the camera uses a large aperture, and the aperture only actually closes when you take the photo? Non?"
Correct. But it can only give you the largest aperture (hole) it is capable of.
So a 1.4 aperture lens will let in more light to the viewfinder and the sensor than a 2.8 or a 4.0
Posted : 25/05/2011 12:22 pm
My camera has a Fn button that you can assign to one of a load of things. Lots of the functions I would quite like to have quick access to, and I've programmed them before, but it's currently on aperture preview and I suspect it might stay there...
Posted : 25/05/2011 12:24 pm
Nikons have a dedicated preview button AND a programmable Fn button 😛
Posted : 25/05/2011 12:26 pm
Oh right.. anyone wanna buy a load of Oly kit then?
Posted : 25/05/2011 12:27 pm
Rent one and try for yourself
www.lensesforhire.co.uk
and let me know what you think - I amseriously tempted by a 17-35 f2.8!
Posted : 25/05/2011 2:15 pm
Lensesforhire. No Olympus.. buggers.
Posted : 25/05/2011 2:21 pm
Page 2 / 2
