Driving god's, what...
[Closed] Driving god's, what to do when ESP kicks in?
The other night I was on an unfamiliar road, I wasnt driving like a loon but I misjudged a corner and took it too fast. With the damp slightly muddy road I skidded, overcorrected and then slalomed a bit. ESP light was flashing and eventually after a couple of seconds was back on course. Quite scary and made me think about my driving!
Anyway, what's the best thing to do in a situation like that, just try and steer round the corner? Should I be trying to correct the skid? Braking? lessons from Surf Mat ,😂 Is trying to correct the skid making it more difficult for the ESP?
Thanks
Posted : 26/01/2022 11:57 pm
IANAAO
Presumably drive as usual and let the ESP do it's stuff.
Posted : 27/01/2022 12:04 am
^ basically that. It’s 100’s of times faster than any of us are.
Posted : 27/01/2022 12:09 am
forget the ESP is even there and correct it and then the ESP should help to get it back in line. correcting it keeps the front wheels pointing in roughly the right direction.
also what did you do with the throttle, FWD you should floor it as thats helps pull the car straight and RWD just ease of it a little, coming suddenly right of the throttle destablises the rear even more
just thinking as i've never tried it but possibly ESP will not allow you add power in a FWD car, none of the fun cars i've had have had it.
Posted : 27/01/2022 12:11 am
Well it depends if the skid was oversteer or understeer! Flooring it in an FWD car if it's understeering isn't the answer
Posted : 27/01/2022 12:13 am
Yeah ESP is pretty damn clever.
Do the same corner but switch it off this time and see. NO DON’T.
Keep your speed constant though don’t panic and don’t try to be Colin and floor it. Unless you know what you’re doing it’ll end badly.
Posted : 27/01/2022 12:14 am
It's there to help out and ESP is one of the best things ever introduced as it prevents fish-tailing. But it can't undo mistakes, so when it kicks in try to follow the path of desired travel as it will correct any skids so try not to overcompensate. Easier said than done though!
Anyway, what’s the best thing to do in a situation like that,
Quickly turn ESP off and own that drift so hard you end up with paternity leave.
Posted : 27/01/2022 12:15 am
Turn it off, do a u-turn and go practice
Posted : 27/01/2022 12:18 am
Well it depends if the skid was oversteer or understeer! Flooring it in an FWD car if it’s understeering isn’t the answer
as he said "overcorrected and then slalomed a bit" i take that to mean oversteer.
Posted : 27/01/2022 12:20 am
^^^ I understeered to start with then oversteered trying to correct it i think. Front wheel drive car, I lifted off the throttle, don't think I braked just tried to correct the skid (badly I think!)
First scary moment in a long long time, luckily was at night and nothing coming the other way. Think I was just a bit tired and not concentrating as much as usual, got a lot ony mind at the moment. Anyway it's made me realise how lucky I was and aware of driving tired.
Actually I forgot, there was a casualty, my takeaway slid off the passenger seat onto the floor. Still edible but I've learnt another lesson, always use the little takeaway bag hookn in the passenger footwell!
Posted : 27/01/2022 12:28 am
I’ll start by confessing I am not a driving god. I can, however, get out of a skid reasonably.
Modern ESP is awesome, early incarnations not so much. I had a fairly early E46 BMW and the ESP on that was an absolute menace to anyone who had a slight clue how to recover a slide. Me included. Damp road with some camber and an enthusiastic right foot cause the rear to step out… eased off slightly and a dab of steering into it and all seemed well right up until the esp light came on and the car snapped the opposite way into a spin. I would have expected some fishtailing at that point but it was like an anchor was thrown out one side. Conversations with other owners revealed this was not uncommon.
Posted : 27/01/2022 12:39 am
understeer is horrible but i suppose it is safer, not that much you can do to control it other than come of the throttle and wait for grip to come back, straightening the steering in theroy helps also but your already heading in the wrong direction by that point. if the whole car is grip limited and understeering just coming of the throttle and finding grip again can easily snap it into oversteer.
Posted : 27/01/2022 1:14 am
Pretty much all you can do. Just keep the front wheels pointing towards where you want to go and ease off the throttle gently. The electronics are massively faster than you and you don't know which wheel(s) are starting to slip or why. All you can really do is minimize any abrupt changes in loadings on the tyres.
Much safer. Understeer is predictable. The natural reaction is to lift off the throttle when things go wrong so this will generally help with an understeering car. Oversteer is unpredictable. Despite every adult male fantacising that they are God's gift to driving, oversteer is utterly lethal. I'm pretty sure that's what happened to Frank Williams - Ford Sierra, lift off oversteer, sentenced to life in a wheelchair.
Posted : 27/01/2022 1:56 am
You need to slow down.
ESP kicking in is telling you that you have exceeded your abilities and your understanding of the capabilities of your car.
Posted : 27/01/2022 2:46 am
One of these things is not like the others. If the rear is stepping out in a FWD car then the worst thing you can do is lift off, electronic assists aside.
Posted : 27/01/2022 3:06 am
If the rear end is stepping out in a FWD car on a public road, you are either driving like a total * or have just *ed up and are likely headed for a crash whatever you do. If you lift off the throttle and stand on the brakes as hard as you can, at least you will be travelling slightly slower when you crash.
Posted : 27/01/2022 4:40 am
No sudden inputs as you don't want any big weight transfer as this will unsettle the car.
Sounds like you got lift of oversteer as you backed right off n moved the weight forward doing so.
Being smooth is always key.
Posted : 27/01/2022 6:05 am
The first thing is that ESPs have different names, ESC in a Skoda, DSC in a BMW, etc so read the handbook
Anyway, what’s the best thing to do in a situation like that, just try and steer round the corner?
Exactly that
The ESP will usually take that out of your hands and in a FWD will reduce engine power
This^^
It applies the brakes to one wheel to bring the car back into line (inner rear for understeer)
Absolutely this^^ And if the tyres can't grip then the system cannot undo your actions
Posted : 27/01/2022 6:25 am
+1 to let the electronics do thier thing while continuing to steer where you want to go and trying not to become streaky pants....
Posted : 27/01/2022 8:51 am
Another +1 to letting the car get on with it and keeping the steering pointing where you want to go. Steering angle is one of the inputs ESP will be looking at when it's determining where you're actually trying to go, applying opposite lock or whatever won't help.
Posted : 27/01/2022 9:01 am
seriousrikk
Old Clio 182 was great. As far as anyone can tell the ESP consisted of a light telling you that you were sliding 🙂
Posted : 27/01/2022 9:05 am
+1 thols2 & rusty
Posted : 27/01/2022 9:08 am
With ESP it is necessary to show your intent to computer - either brake or continue to direction pointed by the front wheels.
Posted : 27/01/2022 9:09 am
sounds to me like you went from power on understeer to lift off oversteer.  As above probably the best thing is to do very little - point the wheels where you want to go and a neutral throttle.  Easier said than done of course
Posted : 27/01/2022 9:11 am
Not convinced by this - would it not trigger a spin?  Or are the electronics good enough to prevent that?
Posted : 27/01/2022 9:13 am
So you entered the corner a few mph too quickly, hey dont sweat it we've all been there. Some debris, water run off from feilds, gravel, sand etc was on the road, and it was dark and you can't see round corners, everyone has done it.
The grip level from the tyre exceeded the grip levels from the surface, probably mid corner at the highest g loading, and the tyres started to slide.
At least you didn't panic and hammer on the brakes, ypu did pretty much the right things. The car has tried to help, probably by cutting the throttle and modulating the brakes on the wheels that are now not rotating within the parameters set up by the, usually bosch, engineers.
This takes into account steering angles, and offset from the rotating wheels.
Sounds like you applied more steering angle, the car responded and ypu regained grip on cleaner tarmac, and the esp/dcs is still helping by feathering the brakes so when grip was restored you rapidly changed direction,
Still normal in a fwd car.
Rushing back with a takeaway, all the smell of hot food wafting around the cabin setting off hunger pangs, trying to get home whilst its still hot, yep very easily done.
The only thing ypu could have done was straighten the steering wheel to lesson the tyre slip angle and regain control, modern abs may have helped if you are confident with steering and braking with pedal juddering under your foot.
No one died or was harmed apary from the noodles and you'll know next time that there might be debris on the apex of the corner and roll in 5mph slowet
Do what you think needs to be done with a little bit of throttle, the car will then decide whether to keep using that throttle or remove it, I could be wrong but without that throttle it can’t add it
Next time it snows, go out and practice then you know exactly how good these systems are
Posted : 27/01/2022 9:23 am
Check the depth of tread on your tyres just in case.
Posted : 27/01/2022 9:27 am
It would be another source that the skid is coming from 😆 as your life flashes before your eyes.
Posted : 27/01/2022 9:30 am
Not convinced by this – would it not trigger a spin? Or are the electronics good enough to prevent that?
If you've managed to get the rear wheels sliding on a FWD car without intending to, you have run out of grip. Electronics can't find grip, they can only maximize the grip you have. If you steer into the slide and the rear wheels grip again, you now have your front wheels aiming the car off the road so you will launch yourself into the scenery. This is why oval track speedway cars are set up to understeer - if the rear of the car gets loose and you steer into the slide, you'll fire yourself straight into a concrete wall. So, basically, you are probably going to crash unless the stability control sorts you out. Standing on the brakes as hard as you can will at least make the crash less severe. Assuming you have anti-lock brakes and stability control, those will monitor how much grip you have and adjust things as best it can. It shouldn't pitch you into a spin unless you were already going to spin anyway. Even if you do spin, that will bleed off speed pretty quickly and make the resulting accident less severe.
Posted : 27/01/2022 9:41 am
Open the door and jump out.
Save yourself.
Posted : 27/01/2022 9:52 am
Panic and try to drive round the corner, the chances are ESP will save you or you really were going too fast. Spend the rest of the journey trying to work out WTF happened and concocting a great story about swerving to avoid a small kitten and then a dab of oppo to get around the nuns before driving off calmly and completely unflustered.
Works for me.
Posted : 27/01/2022 10:05 am
Not forgetting the delicious takeaway!
 5lab
thats a fair exaggeration. Lots of fwd cars are relatively easy to recover a slide if you have a modicum of talent. sure, snapping back can occur (in any car, regardless of the drivetrain) if you have a lot of body movement and a lack of feel for the fact the tyres are starting to grip again, but I've only owned a fwd car with ESP for the last year (previous 18 years i've driven fwd without it) and never been launched into the scenery, despite losing the rear end on multiple occasions. my old signum would lose the back before the front on anything below mid-throttle, so would power oversteer round roundabouts (it might have been a bit broken)
Posted : 27/01/2022 10:16 am
Ooo I did that, one time at band camp... It was in my first company car, a Peugeot 309 1.9 diesel donkey. 'A' road, driving too fast, tightening left hand bend and negative camber. The car started under steering into the middle so I lifted off and it just span...nose on into the bushes on my side of the road neatly parked between a telegraph pole and a tree. (cue angel music). A salutary lesson about driving like a prized prick.
No one's mention 4wd. Presumably just ignore all the ESP excitement and carry on?
Posted : 27/01/2022 10:25 am
you’ve managed to get the rear wheels sliding
and then...
Just don't see how braking is going to help. No grip, no brakes?
Posted : 27/01/2022 10:26 am
Very broken by the sound of things and its simply impossible for a FWD car to power oversteer
Posted : 27/01/2022 10:27 am
No one’s mention 4wd. Presumably just ignore all the ESP excitement and carry on?
i have to try really, really hard to get the ESP light to come on in my subaru...
Posted : 27/01/2022 10:28 am
I was driving on ice/snow a day or so ago. Nothing exciting, just getting out of the car park at the ski chalet. The exit was quite steep and thick with frozen snow/ice. I did my usual 'momentum is your friend' and it wiggled about a bit then escaped onto the public road. Just wondered if I should be doing something different.
Posted : 27/01/2022 10:34 am
Same for Quattro, you just never see that light. Unlike the FWD V6 A6 it replaced, the dash lit up like Oxford Street in December every time it rained.
Posted : 27/01/2022 10:41 am
 pdw
+1 to steer in the direction you want to go. The ESC can do a lot, but it can't steer and doesn't know which way the road goes, so best that you do that bit.
There's probably something in this too. When you're on the limit of grip, you want a little bit of power so that the engine isn't braking the driven wheels. The ESC can remove power, but it won't add it.
A friend of mine did a car handling day when one of the tests was to mash the brakes whilst cornering at speed. Apparently the results were impressively unexciting.
Posted : 27/01/2022 10:55 am
Well Op - you have the full range of advice from stamp on the throttle to stamp on the brakes to do nothing to bail out.
I really hope that helps
Posted : 27/01/2022 11:13 am
If it was me I would lift off the accelerator ever-so slightly (if I actually had my foot on it in the first place which would be unlikely if I was negotiating a corner) and just let the system take care of it whilst continuing to steer into the preferred line. If I found I had to do anything else (ie, if the car was going properly sideways) I would keep any reactions smooth and gentle.
Posted : 27/01/2022 11:28 am
I was on a bike ride with a mate once, we were going through an industrial area where they have the newly built roads with large flat roundabouts and big verges to accommodate HGVs and the like. We'd pulled ourselves over on one of the side roads for something and I heard a car and the unmistakeable scrabbling of tyres. A young person in a Fiat 500 had come into the roundabout far too fast and in trying to steer around it past the apex she just drifted wide, hitting the kerb and bouncing onto the verge breaking her suspension. She was a bit shaken and kept saying that her steering had locked up and she couldn't steer.
I think that the ESP was detecting her about to slide and was preventing her from losing the back and spinning. But it didn't stop her crashing.
I got my first lesson in RWD driving when I booted the Merc off the roundabout down the motorway sliproad on a cold greasy morning. The back slipped and the ESP grabbed the wheel and snapped it back in before I even had a chance to do anything myself. Scary though as I would prefer not to rely on such systems - it's a complex system and all you need is some part to fail...
Posted : 27/01/2022 11:29 am
I turn it off, how the f*** do you do donuts with it on!
Posted : 27/01/2022 11:46 am
Once upon a time a friend was invited to help another friend set up the handling on his Caterham at a airfield/track day so he loaded up his (new to him) BMW company car with a bootful of tools and trundled down the M4 on a pissing wet day with a blustery cross wind. BMW gave every impression it was going to kill him at slightest notice while travelling in a straight line.
Friend of friend was a no-show. Trackday organisers offer paid-for place. Was taken as an opportunity to scope out the level of demonic possession in the BMW.
First lap, the first hint of trouble and the stability control kicked in very aggressively. Nasty lurching as the electronics modulated the throttle. But it didn't kill and it didn't oversteer and it didn't fishtail. Bimmer was a comfort spec 323 coupe with a wallowing ride quality that invariably made passengers queasy.
With the stability control off, discovery that the car had a party trick for drifting, adjustable, stable and accurate initiated at 100mph on the runway, gliding in an arc to join the coned off track in the taxiway waving at the TVRs, Loti and Porsches being overtaken. Trip to nearest tyre shop needed to get three down-to-the-canvas tyres replaced.
Moral of this story (besides public roads not being conducive to drifts initiated at 100MPH with net-positive outcomes)?: Stability control stayed engaged ever after. Bad, lurching stability control has its place. Anything you can do to expand your experience so you're not surprised by how your vehicle reacts is good.
Posted : 27/01/2022 11:56 am
 5lab
its really not impossible. Power oversteer simply means its oversteering whilst power is applied. The balance of fore/aft grip on that car was such that, whilst accelerating round a corner, if there wasnt sufficient grip, the rear would step out first. Applying more throttle would balance it, but it was still power oversteer.
Just don’t see how braking is going to help. No grip, no brakes?
tyres never have *no* grip unless they're in the air. Whilst aquaplaning they have very little grip, on a wet corner they have some grip. Grip can be used to change your momentum in some axis - so if you corner at the limits of the car, then apply throttle (or brakes), the car will no longer corner as hard (as some of that grip is being used for changing your speed).
If you get a car completely sideways, braking doesn't make much of a difference (as the tyres are sliding sideways over the tarmac, applying lateral braking force won't matter) - but locking all 4 wheels does stop the car gripping when not-quite-straight again and pinging you into a barrier.
fwiw, if you've run out of grip in any car, deploying the clutch is a good idea if you have presense of mind to do so, as it removes any engine influence from the tyres leaving more available for turning
Posted : 27/01/2022 12:14 pm
 it’s a complex system and all you need is some part to fail…
the driver is the weakest link in most cars, what proportion of crashes are due to component failure?
Posted : 27/01/2022 12:25 pm
Oh the ESP will come on 4WD when it is slippery enough 🙂
Conditions have been pretty bad here (Helsinki region) and our driveway has been turned into ice field with some water on top. Spreading grit on does not help much as it sinks into ice during the day. My winter tyres could not keep car in place on the driveway on brakes, it just slid to the bottom. Studded winter tyres in wives car are bit better.
Posted : 27/01/2022 12:39 pm
If you have anti-lock brakes, they'll brake to the limit of the grip you have. If you have stability control and have lost the back end because you overcooked it into a corner and had a panicky lift of the throttle, the rear tyres may regain traction once you bleed off some speed and the stability control will sort you out. Basically, once you get badly out of shape, you're probably going to crash so anything you can do to crash at a slower speed will help.
Posted : 27/01/2022 1:22 pm
That might be your interpretation, but it's not the generally accepted definition.
What you're describing is the rear breaking traction first on a corner, and can be due to geometry or chassis balance, or a number of other things, it's oversteer whilst on the power, but it's not power oversteer.
Posted : 27/01/2022 1:35 pm
That is not power oversteer you are describing
Posted : 27/01/2022 1:36 pm
I'm not implying that TJ is ever wrong about anything, but in this case he is right.
Posted : 27/01/2022 1:39 pm
This is going to turn into one of those threads where people start arguing that FWD cars can drift, and then try and prove it by showing loads of videos of 205s and DC2s lift off oversteering round corners, isn't it?
Posted : 27/01/2022 1:42 pm
Posted : 27/01/2022 1:51 pm
We were told that Mercedes invented ESP back when they launched the 1st A Class. It was one of the first small cars with the wheels at the extremes of the body. It failed the ELK test and rolled over so they either had to invent something that countered this or they started again costing billions.
In the old days we used to get sent with our customers to Mercedes testing facilities to see how these systems worked. Basically if you picture your car with 4 brake pedals thats in effect what you have. But a computer controls each one independantly 1000's of times per second and takes into account vehicle loading, centre of gravity, steering wheel input and throttle input. We used to have a go on a simulator which was basically 4 pads on the floor, a screen of a car driving and we had to try to get it around a track safely.
Anyhow, the next demonstration was a skid pan with a chicane of cones. The skid pan was watered slippy tiles. Just walking on it was slippy. You had to hit it at 60kph AND NOT TOUCH THE BRAKE PEDAL. I loved it, violent steering left then right. The front bumper would almost bottom out and the thing would slam on its brakes in every way to get it to follow the direction of steering. Absolutely no counter steer or hitting the throttle to pull you out of a skid. The ESP system would cut the throttle anyhow.
We would do this a few times and also take our competitors vans out and be shown why our latest generation was better than the others. Empty, 500kg, 1t. It made big differences.
We would also do the ELK tests and at the end of the day they would get the Ford Transit or whatever and compare the tyres after a whole day doing this. The ford was shagged but the Merc tyres barely worn despite out performing the ford all day on the tests.
Its an amazing piece of kit that i have unintentionally tested out at 80mph going sideways on a motorway before.
Posted : 27/01/2022 1:52 pm
its the old french clock again thols2
Posted : 27/01/2022 1:53 pm
I have never been sideways on a motorway at 80mph. Does this make me a driving god or not? It's all so complicated.
Posted : 27/01/2022 2:15 pm
ESP has been in development since 80's but first Merc A-Class definitely was one of first cars which actively relied on it.
The systems have come a long way, e.g late 90's there were some systems which couldn't handle situations where wheels on other side were on slippery surface and other side on a grippy surface.
Posted : 27/01/2022 2:17 pm
pdw
Thing is with that, you have to apply the correct amount of lock and unwind it at the right time and quickly to prevent it snapping the other way.
I used to have a fiesta which oversteered at whim and got quite proficient at this (no ESC and it still had the original and by-then rock-hard 10 year old pirelli p6000 ditchfinder pros fitted from the factory!).
However even in that very predictable car it was quite difficult to unwind at exactly the right point, would be even more so if it only happens occasionally.
But on a car with esc I think it would still be safer to simply hold the steering wheel where it is and let the computer do its thing, as the front wheels will still be pointing in roughly the right direction when it straightens back up.
Posted : 27/01/2022 2:39 pm
There's loads of vids of people driving reasonably modern motors into the scenery after what looks like the equivelant of PIO. If the clot in the hot seat is messing about, presumably it can be almost impossible for the systems to recover?
Posted : 27/01/2022 2:53 pm
There’s loads of vids of people driving reasonably modern motors into the scenery after what looks like the equivelant of PIO. If the clot in the hot seat is messing about, presumably it can be almost impossible for the systems to recover?
Ye cannae change the laws of physics
Posted : 27/01/2022 3:01 pm
If you barrel it into a corner way too fast for the conditions, no ESP/AYC is going to be able to pull you out of it, it's as simple as that.
Where it will help us with things like throttle and brake induced imbalances/changes of traction mid corner. So the classic hoofing the accelerator too hard too early on corner exit in a rwd car, or a panic lift off potential tankslapper mid corner, for instance.
Posted : 27/01/2022 3:03 pm
Posted : 27/01/2022 3:10 pm
To the OP. Best advice (and you know this I'm sure) is to slow down on unfamiliar roads and/or in poor conditions.
I can't remember the last time I triggered the ESP on one of my cars on the road, but in situations like you had the best thing is to let the system work, dont hit the brakes too hard or put in large steering inputs. New ESP systems work really well.
I do quite a few track days in my cars and they have ESP settings for quicker driving. I leave the ESP on since I'm no driving god and actually I go quicker with the ESP on. You can really feel how well they work on track and it does help you get round the corners with less drama.
Posted : 27/01/2022 4:09 pm
It's really clever stuff and it's great to see this kind of technology (sort of) filtering down to motorbikes in the form of 6-axis IMU's to help out the ABS and traction control systems.
As a biker, my next bike will certainly have the latest electronics.
Posted : 27/01/2022 4:19 pm
You are a Policeman AICM £5 😀
Posted : 27/01/2022 5:15 pm
I was driving on ice/snow a day or so ago...snip...Just wondered if I should be doing something different.
You could try an intermediate ESP setting, if there is one, so that you have engine power. Switch to full ESP when you're back on the road
Posted : 27/01/2022 8:44 pm
I've managed it a couple of times 😉
Posted : 27/01/2022 8:50 pm
Posted : 27/01/2022 10:15 pm
brings back good memorys, did about 10 trackdays in my DC2 and playing with lift off oversteer was good fun and for the fast laps the LSD did a good job allowing plenty of power without understeer.
was much more fun for the next 70+ trackdays in a severn style kitcar with high power to weight though. its a really good way of learning car dynamics with no electronics to help at all.
i'm sure that the more you can do to help the electronics contol a car the more likely it is they will save the sitution.
braking comments above, save the brakes for after the point of no return, once you're into an unrecoverable spin lock it down,you will stop quicker.
Posted : 27/01/2022 10:42 pm
tyres never have *no* grip unless they’re in the air. Whilst aquaplaning they have very little grip, on a wet corner they have some grip.
I had to pick up a BMW once somewhere down in the darkest depths of the South-west, probably Cornwall, and when I checked the tyres, the rear ones were 1.6mm, as far as my gauge could tell, which bothered me a wee bit. FFWD to the M4 and it’s started raining, by the time I get to J18 at Tormarton, I’m going uphill in fairly heavy rain, and I’m vividly aware of the fact that the car is gently fishtailing at between fifty-sixty mph.
It was at that point that instead of carrying straight on for Chippenham, I bailed and came back via Bath, with the slow traffic.
That was a bit unnerving.
Posted : 27/01/2022 10:45 pm
I'm afraid I can confirm that. Ended up rubber side up.
Posted : 27/01/2022 10:50 pm
The best advice is to learn to read the road better!
Most drivers i sit with have no idea how to read the road, in fact,few even look at it, or far enough into the distance. Really, you should never be surprised by a loss of grip, as all the signs are there, you just need to read them! I can't emphasise enough how doing some advanced driver training will totally change how you drive and give you a level of safety that is, imo, impossible to get any other way.
I'm biased, but this guy is one of the best:
http://www.reglocal.com/93-2/
He also has a good you-tube channel and has published a couple of books that are worth a read.
I actually contributed to his "how not to crash" book, in the chapter detailing how to drive a modern car with ESP, and its best to get that book at read the chapter (blantant plug!), but broadly, should you start to loose grip, these are, on average (ie they can't possibly suit every situation perfectly!), the best actions:
1) If you are at "High" throttle openings, immediately reduce your throttle by at least 50% of your currently held level. This is good rule, and it tries to balance what happens when a tyre slips due to a high torque input from the engine, against what happens when the tyre slips because it is unable to carry the lateral load asked of it (ie a momentum driven slip). You almost certainly never want to completely come off the throttle if possible.
2) If you are at a large handwheel input (note: handwheel means what most people call the steering wheel, ie the round thing you hold as a driver, but used to be clear that we are not talking about the "steering wheels" ie the wheels / tyres at the front of the car), again, either hold the same angle (understeer) or reduce it quickly by about 50% (oversteer)
3) If you then feel that the slip is not reducing but increasing, nail the brake pedal hard. The ABS will help you control the yaw of the car (under/oversteer ie rotation) and should you run out of road and talent, you'll be going both slower, and most likely forwards (rather than sideways) when you hit something. This is really important because side impacts are still the no 1 killer of car occupants, where as frontal impacts are now extremely well mitigated against
IME, after doing lots of advanced driver training as both student, observer and instructor, most drivers CANNOT accurately enough control a modern car at high slip ratios in the exact instant they need too and without warning (see poor observation / anticpation section...) and in most cases, will make things worst when they try too.
This usually involves FAR too large a handwheel input, usually about 180deg out of phase with the yaw, ie making things worse not better (fishtailling). Again, IME, to instincitively catch and control a modern car when it slides, which they do at high speed thanks to there massively wide grippy tyres and huge lateral stifness, takes a lot of skill, and critically experience and practice, which most drivers simply don't possess.
I do urge anyone to do a real skid pan session, but not to try to teach you how to correct a slide, but more importantly to help you:
1) Recognise the onset and likely hood of a slid developing BEFORE it does. To learn to feel for the onset of a loss of grip
2) Understand just how hard it is to accurately catch such a slide at any speed above about 7 mph (watch youtube for reference, as people stick no end of nice cars into the scenery, having watched too many episodes of Top Gear and thought "how hard can it be".... 🙂
It's also worth noting that most people who get into slides are only in a slide because of poor road positioning for the speed at which they are travelling. Learning to position your car properly, enabling you to drive FASTER and SMOOTHER is the real key to driving. The very best drivers (like Reg) will astonish you by the speed you see on the speedo, but the calmness and smoothness at with which they apply that speed (and often, with the lack of speed they choose to carry in a lot of situations)
Posted : 27/01/2022 10:51 pm
@bails more the doughnut reference rather than driving shenanigans... 😀
Posted : 27/01/2022 10:53 pm
lift off gently as modern cars are designed to go 'neutral' when this is done, even rear wheel drive^; unlike the German fast saloons and French hot hatches of old which were much more fun to drive. As others have said the esp* needs grip to work most effectively, once you have done this keep steering the way you want to go and reapply the accelerator pedal gently once the sliding has stopped and hopefully be on you way/ have a crash at a lower speed.
^ Obviously this is not always possible due to physics
* esp is I think Bosch groups trade mark
If you have enough space the esp will eventually sort things out but this is not the case on a road - the system is designed to assist mistakes by drivers on unfamiliar roads or when distracted and works on a basic principle of what people usually do in a panic - it will not sort out catastrophic failures of talent.
If you really know what you are doing it will interfere with your actions but I think if you are that good you will understand that the system is quicker than you and on a public road it will sort an issue in a manner which is safer due to the lack of space available.
Posted : 28/01/2022 10:51 am
My understanding is, just steer where you want to go. ESC / ESP etc is better than you, it can 'think' quicker and it can do things you can't like brake wheels independently, but it doesn't know where you want to go, it also can't entirely break the laws of physics, if you want to turn 30 degrees left, and there's only grip for 20 degrees, you're going to crash. The good news is that cars have loads of grip these days and ESP does let you get away with a lot, so you probably won't.
Again, this is only my understanding, but most systems are pretty much identical, some manufactures did develop their own systems, most just buy in Bosch, even if they brand it differently, even the ones who made their own, bought IP from Bosch to make it work.
I'd be interested to know that with really modern cars with steering assist, would the system deploy a "dab of oppo" to try to stop a slide? even with electronic steer, the wheel is still physically attached to the wheels, so it would be quiet violent and hurt the driver, also, if it resulted in the car going out of it's lane and hitting and oncoming car, would they be liable if the driver claimed the car, not them, caused the crash.
Posted : 28/01/2022 11:15 am
