Found a pinhole leak on a cold feed to a sink which I need to fix today.
Already got pipe but just deciding whether to go for push fit connectors or compression?
Access is a bit limited as the hot supply is right next to the cold.
Push fit are easy and work
Pushfit would be my choice unless you're sticking it under a floor somewhere.
Pushfit work fine.
Solder 😉
the entirety of Casa del Stoner is plumbed with Hep2O pushfit. No problems.
But they're ugly as sin so never in sight.
Oddly though, whenever I do work as a favour for anyone else I always use solder. go figure 😉
I think it's called 'showing off' 😀
Cheers Rachel 👿
Fair enough, push fit it is. Never a dull moment....
*makes note to keep some push fit fittings in the tool box just in case
Is it onto copper? Don't need the inserts in that case.
I solder everything and have only used one push fit adaptor, and that one is weeping ever so slightly. It's behind a kitchen cupboard and I only noticed the drips when I was re-fitting the sink after sanding down the worktop to re-coat. It wasn't a particularly cheap one either...
and to counter that my downstairs is all hep2 with push fits and inserts ... upstairs is soldered copper
the only leak i have had was in a copper bend where downstairs meets upstairs that had been soldered badly by a plumber - pin hole in the joint.
Its now compression fitting due to not having soldering equipment handy at the time.
