Docs/Nurses. When w...
[Closed] Docs/Nurses. When will dissolvable stitches..... err dissolve?
11 Users
Had 5 stitches in my mouth on Thursday night after a rock interface. It's well healed now (5 and a bit days later) but the stitches are somewhat flapping around in my mouth! Pissing me off slightly to be fair, what's the usual decay rate for these little ****ers, or do I need to go back to get em pulled out? Cheers in advance!
Posted : 12/10/2011 7:24 am
sounds like tapeworm AIDs
HTH x
No it was definately a big rock that caused it 😉
Posted : 12/10/2011 7:27 am
No it was definately a big co ck that caused it
Posted : 12/10/2011 7:28 am
Yup I admit, I was trying some self enjoyment!
Posted : 12/10/2011 7:34 am
Anyone?
Posted : 12/10/2011 11:35 am
Dunno - I was always told a week or so.
If they are annoying you make an appointment with the practice nurse at your GPs to get them removed
Posted : 12/10/2011 11:37 am
Yes... or maybe no... In different people they dissolve at different speeds... And in most people the inside of the mouth heals really quickly.
I know what you mean - I had some plastic surgery to the inside of my lip (after using my face as an alternative way to land a jump) 2-3 weeks ago. After 4 or 5 days it was driving me potty so I removed the stitches one by one over the next few days... and then some of the deeper sutures started to come out through a small hole in the inside of my mouth by themselves...
Interestingly I found a pair of nail scissors hugely better than the stitch-remover blades we use on patients at work...
I am NOT recommending this strategy by the way!
Posted : 12/10/2011 11:42 am
Got to see the nurse tomorrow now anyway to have the tetanus booster they forgot to give me at A and E. Just as an aside, you guys know anything about metronidiazole? It was given to me to prevent infection, from what I read it's a pretty potent drug, but then again the Internet is not always the best thing to believe!
Posted : 12/10/2011 11:47 am
 DrP
Tastes rank, sends you loopy if you drink booze....
DrP
Posted : 12/10/2011 11:50 am
Mmm that was my concern regarding the Stella!
Posted : 12/10/2011 11:58 am
i have had dissovable stiches before that didn't disolve and had to be removed. they got tighter and tighter so had to be picked out.
i have also had that medication before for dental problems and it makes me feel really floaty and dizzy (without drinking). i was told not to mix it with any booze else it would make me really sick.
Posted : 12/10/2011 12:51 pm
I had disolvable stitches in my eye following a vitrectomy.. they didn't disolve so the surgeon cut the knot them pulled them out whilst i 'watched' felt wierd!
No use at all to OP but i i love the story 🙂
Posted : 12/10/2011 1:24 pm
Depends what stitch they used....
Max-fax usually use Vicryl Rapide (or similar) inside the mouth so should take approx imately 7 days to dissolve (5 according to the manufacturers but that's a lie)
Also, if the only cut is inside your mouth you probably don't need tetanus (also if you were born after 1961 and had all your jabs as a kid; also the fact that it's 6 days later and you're still alive....)
HTH
Posted : 12/10/2011 11:51 pm
I've got non-dissolvy ones in my knuckle at the moment, wound is well healed 4 days in but the stitches are ripping through the flesh. Just about to use the nail scissor method as I CBA booking another doc visit for them to pull them, plus things hurt less when i do them myself.
Ever noticed it's far less painful to take a razor blade and slice out a splinter than let someone else loose with tweezers?!Maybe it's a control thing.
Posted : 13/10/2011 2:39 am
Metronidazole is used to treat anaerobic bacteria, the gums are susceptible to anaerobic bacteria.
When I worked on ICU metronidazole tended to be used by general surgeons pre or post abdominal surgery, again the gut being full of anerobes
Posted : 13/10/2011 6:35 am
