Putting salt in water to make your pot boil quicker by lowering the BP, it only works if you put shit loads of salt in, like seawater levels.
brakes. I can barely contain myself. Is there a live web feed? If not (why not?) what time will you be posting your findings?
Let me know if you need an independent adjudicator. I can bring my own blazer and clipboard.
pffft (after a tap on the lid, obvz)
I eschew all wisdom, conventional and otherwise
and a calibrated stopwatch?
I thought that was just to season the pot contents - doesn't salt raise the boiling point?
Salt lowers it, which then takes longer to cook the food in theory because the water is cooler.
However the effect is negligible without stupid quantities, it seems.
talking of salt, and rejecting conventional wisdom.
i eat chuffing loads of the stuff - we're told this is bad, but i don't believe a word of it, even if it's true.
I've always cheerfully ignored the conventional "wisdom" that is the latest advice on food. I eat a fairly balanced diet, not too much of anything in particular and now and then drink too much.
Being cold or wet gives you a cold or flu.
Constantly nagged by my inlaws that my son is not wearing enough clothes. Sometimes when I pick him up from there he looks like the michelin man, unable to get his arms into the pushchair as they stick rigid out the sides 😯
Rejecting conventional wisdom is the new conventional wisdom, consequently I reject rejecting conventional wisdom.
"JUST BECAUSE I HAVEN'T DONE IT YOUR WAY , DOESN'T MEAN I'VE DONE IT THE WRONG WAY".
I've said this a [i]lot[/i] in my life, particularly due to my inability to articulate "my way of thinking".
" You defy logic" they say...
Yeah, their logic.
I always take the least controversial viewpoint. That's why I never argue.
I also like to post things twice, apparently.
I'm going to try this this evening with two cans of coke that have been sat in my fridge. one will get a slight shake before opening; both will be tapped
No. Shake both, tap one.
Madernat8om dends tou vlind
got any reputable sauce for that Moly ?molgrips - Member
Salt lowers it
Strange example given by OP - ie being weakened/unhealthy by being overweight and badly nourished vs being weakened/unhealthy by being underweight and badly nourished. - surely both are conventionallly unwise?
http://en.wikipedia.org/wiki/Boiling-point_elevation
Boiling point raises with added salt.
I had heard that you put the salt in to elevate the boiling point and hence cook your food faster. But never really believed it made any practical difference.
I was thinking about the salt thing earlier while I was heating a pan of water to cook some pasta..
As soon as I added salt the water began to boil.. This is often the case
What's the science behind that?
I will continue to believe my eyes rather than some debateable boffin spraff..
We all believe in goats but it's never taken years of scientific experiments and research to prove their existence
Probably about to boil anyway. As others have said, adding a pinch of salt does nothing practical for the boiling point temperature.
it's my experiment matey.
but you're probably right.
Hmm.. Admittedly it was about to expel a bubble or two, but the salt just kicked it into an instant boil..
There must be a reason for that
Did it boil or did it just bubble more as you chucked something into hot water.
It bubbled more.. Significantly more, whether that's got anything to do with temperature I don't pretend to have a clue..
Is it surface tension or summink then?
(FWIW dried pasta deffo lowers the boiling point of water 🙂 )
Pretty much yes.
gives the bubbles something to form aroundAs soon as I added salt the water began to boil.. This is often the case
like putting sugar/salt into fizzy pop
There's a thing where bubbles form at 'points' which can be imperfections in vessel. I forget the term, but it's why you get bubbles clinging to the sides of a glass; it's also how those chemical heat pads with the 'snapper' in them work. I wonder if that's what's happening here (confirmation bias aside) - the water bubbles not because the salt has changed the boiling point, but because it has corners. Might be interesting to see what happens if you do the same when adding a pre-dissolved salt solution.
Nucleation.
That's the one. I remember in chemistry you or little stones into solutions you were biking, to make lots of little bubbles instead of manic huge bubbles that burped the shakeout chemicals over your face...
Has anyone done the can experiment yet?
DrP
So.. i boiled my cans of coke in salt water then burnt my hand trying to flick the top.
What was the question?
I think.
Does it fizz faster when boiled in a salt solution.
Yes, AGW is a good start.
My previous thread is nonsense, due to autocorrect. And my laziness in checking auto correct...
DrP
I just cut the 680mm bars on my El Mar build down to 630 - feels right, but I'm told it's wrong!
Molgrips, call that contrarian? Pah! I'm just about to assemble a rigid aluminum 27 speed 26"er with 600mm flat bars, bar ends and a thudbuster st all out of new parts.
Oh yeah, and a looooooong stem too
