Dishwasher/plastic ...
[Closed] Dishwasher/plastic adhesive experts - help please!
4 Users
 tang
The spray arm in the dishwasher has come apart. It's a two piece design that prob needs a bead of sealent/adhesive. What's up to the job?
Posted : 02/03/2014 8:50 am
any silicone sealant should be fine way above dishwasher operating temps.
Although I thought the sprayer arm would have been heat welded together at manufacture.
Posted : 02/03/2014 8:57 am
 tang
I think you are probably right Stoner. It looks perfectly gluable, which is preferable over a new arm.
Posted : 02/03/2014 9:00 am
Im sure it is. I as long as a decent void in the middle is preserved for water flow, Id run a bead just inside and onto the lip all the way round. Clamp it with lots of little clamps the full length, let it cure and then trim back with a knife once it's gone off.
Posted : 02/03/2014 9:03 am
 tang
Sounds good Stoner. Adhesive wise, what will like hot water and be available in B&Q?
Posted : 02/03/2014 9:07 am
no idea. Id just use some silicone lying around in the workshop initially.
If you're going out to find a particular adhesive Id just go through the whole lot reading packet backs till I found something about right.
Posted : 02/03/2014 9:11 am
Zip ties are also your friend.......
Posted : 02/03/2014 10:22 am
 tang
Well....I got some stuff from b&q but failed to read its no good on polypropylene. However, Zip ties are indeed my friend T1000! Works a treat, nice one.
Posted : 02/03/2014 12:49 pm
Old knife and blow torch/gas hob to heat it and try and 'weld' the edges back together. Not pretty and can be smelly but done quite a few repairs that way. A variable temp soldering iron works a treat too.
Posted : 02/03/2014 1:13 pm
