DDNS service, VPN I...
[Closed] DDNS service, VPN IP Addresses Blah Blah...
5 Users
 Haze
Fancy setting up a VPN for file access to and from work, and because I'd like to get it working anyway.
I'm on Cable which I think has dynamic IP, so need a DDNS service to receive IP updates from the diskstation software. If I've understood that right?!
Any recommendations for a (preferably free) service?
Posted : 28/04/2012 11:17 pm
OpenDNS or DynDNS
Unless your router is smart enough, you'll need to have a device in your house that is constantly checking the IP against DNS and updating your provider accordingly.
Posted : 28/04/2012 11:21 pm
 Haze
Synology DS112J, DSM 4 software has the VPN service which I believe will take care of it?
e2a Router is a VM job, Netgear WGR614v9
Posted : 28/04/2012 11:26 pm
 Haze
Right, after a bit more messing around tonight I think I get what you're saying Samuri.
Basically I need an IP updater running on a device that's always on and always connected to my network. Not my work laptop for example?
Posted : 29/04/2012 11:01 pm
What Samurai said but,
Aren't most cable IPs 'sticky'?
Posted : 29/04/2012 11:06 pm
 Haze
Dynamic apparently, only the business packages get static IP's.
Posted : 29/04/2012 11:33 pm
When I worked for Telewest on broadband installs/service, and was a customer, the IP address could change, if you swapped out a modem, or had a prolonged powercut or something. Generally however they stayed the same. By that I mean the couple of times I noted it, to see if it changed it didn't, over a few weeks and customers who were getting a modem swap would sometimes ask if they would be getting "their" IP back...
Was a little while ago but I would be surprised if it changed that often. Just no one to complain to if it does...
Posted : 30/04/2012 2:39 am
I'm no expert so I might have the wrong end of the stick, but I got round this by getting my cheap isdn router to email me the log which included any change in ip address..
Posted : 30/04/2012 2:50 am
