Cutting sleepers fo...
[Closed] Cutting sleepers for raised beds
[#8081902]
I've got some railway sleepers to make raised beds from, but need to be able to cut them square so that they sit right when butted at the corners.
I've got a chainsaw, but I'm not sure how easy it'll be to actually follow a line accurately enough to get a square cut?
Other tools available are first fix hand saw, circular saw (won't cut deep enough), sliding chop saw (again, not enough capacity) or jigsaw (!)
Any tips?
Posted : 29/09/2016 11:21 am
Not a jig saw.
I'd personally use a circular then flip timber.
Posted : 29/09/2016 11:24 am
A decent hand saw?
They are not the evil proper railway sleepers are they that will fill your veggies full of toxic chemicals ?
Posted : 29/09/2016 11:26 am
I guess if there are a few I'd use handsaw, if there are lots I'd set it all up so I could cut half way through a batch of them with circular saw, flip them over and then cut the remaining half.
Posted : 29/09/2016 11:29 am
circular saw, then flip them. its what I did and they look good enough for a veg bed.
Are they 'proper' sleepers, as in full of tar?
Wouldn't want to put any nice tools near that but as above, use a circ saw with maybe a cheap blade fitted.
Make yourself a fence to run the saw along to get the cuts meeting.
Posted : 29/09/2016 11:31 am
They're not used sleepers, they are new ones but tanalised.
Not softwood. I'll give it a go with circular saw and hope for the best.
Posted : 29/09/2016 11:53 am
Circular saw and either make a right angle guide like above or get a nice big chunk roofing square like [url= http://www.uktoolcentre.co.uk/Shop/p~67018~Dual-Colour-Quick-Square-12in.html?refid=GoogleShopping&utm_campaign=googleshopping&utm_source=GoogleBase&utm_medium=Product+Search&gclid=CLWf8bq2tM8CFcUp0wodMzoBAQ ]this[/url] and clamp it on as a cutting guide.
Cut both sides then finish he bit in between with a handsaw if you need to
Posted : 29/09/2016 12:03 pm
fair enough, if you're sure
We had several old ones in our garden when we moved in - wept tarry shite whenever the temperature got above about 20 degrees
Posted : 29/09/2016 12:18 pm
I did as per Kayak23's post. Nice and square. I also used new sleepers and the although the blade was not too bad - I replaced it after.
Posted : 29/09/2016 12:38 pm
