The 2.4m posts are a bit OTT, and it'll be easier for me to trim them than to dig even further.
I can get either abrasive wheels or segmented cutting wheels for my angle grinder, any recommendations? Should I get ones for stone or a multipurpose disc?
I'd expect them to have steel cables in them for strength, so use a multi-cutter disc.
Diamond all the way, and when you say angle grinder I presume you mean a 9" one.
No, a little one.
O!
Should be doable with a little one. Easier to control too. Just work your way round and tap it with a hammer if there is still a bit bridging the middle. As long as there is no metal up the uncut bit!
Is it not easier to just dig down a bit more and make sure it's secure? How high is the fence?
Definitely diamond disk. Shouldn't be too tricky unless you can't reach to cut through the steel in the middle.
Don't forget your hard hat and steel toe caps ๐
This might be a bit overkill but its STW at the end of the day.
What would a safety deposit box thief do?
Ok, diamond tipped it is. Thanks. They're reasonably priced, so why not.
Big hammer and Big bolt croppers, carefully smash the concrete and cut the re-bar. If you forget to put the disc cutter in the van and it's too far to fetch it, this is your only option ๐ณ
Also it'll make a lot of dust. Point it away from anything you like
I've used these a few times, and you can never have too many tools
Are they new posts? Maybe exchange them for shorter ones? Shorter concrete posts are available and what you're proposing will be very noisy and dusty. And slow. Possibly nicer for all concerned to either swap them out or dig deeper holes.
A 4" angle grinder will take time, even more so if the posts are not new. Concrete gets harder as it cures.
Cutting them down will expose the steel inside and then the steel will rust and then the concrete will burst, eventually.
I'd dig deeper or at least make sure the exposed steel is not poking through the concrete you will be putting around them. 50mm cover should suffice.
