Critique my shed de...
[Closed] Critique my shed design
Needs a woodburner and a breadmaker
Posted : 05/06/2014 10:28 pm
Is that guest accommodation on the mezzanine?
Posted : 05/06/2014 10:38 pm
Nope, still a wardrobe
Posted : 05/06/2014 10:44 pm
Won't the shelf prevent you fitting in the detached front wheels?
Posted : 05/06/2014 10:48 pm
 rs
[armchairengineersecurityexpert]how are the doors going to lock, seems like they will lock to each other which seems less secure than against a more solid wall[/armchairengineersecurityexpert]
Posted : 05/06/2014 10:52 pm
Drlex - perhaps but it'll be better for hat boxes and photo albums
Posted : 05/06/2014 10:53 pm
 Euro
Needs a dinosaur and double decker bus in there for scale.
Posted : 05/06/2014 11:00 pm
 huws
Tools and parts bin accommodation on the mezzanine. Guests can sleep on the gravel outside.
Front wheels will fit in amongst the bikes. If not they can live under the bed with the hat boxes.
Left hand door will lock top, bottom and middle with padlocked shoot bolts.
Posted : 05/06/2014 11:10 pm
If I was keeping bikes in there I'd replace the wooden support bit with right angle steel sections, which would make cutting into it / crowbarring it apart much harder. Wood is pretty easy to defeat with battery powered power tools, you can just cut round all the locks with a jigsaw in seconds.....
Posted : 06/06/2014 9:52 am
 Olly
I figure you need to protect against 3types of attackers.
1: opportunist noseys. Needs to be solid enough to withstand a kicking. No windows so no clues as to contents.
2: tooled up noseys. Door needs to withstand a crowbar. Locks need to be protected from chisel attacks. They are still opening it up just to see.
3: people after your bikes. Equiped to remove the door. No amount of wood will stop them. Rely on them not bringing an angle grinder and get a big, tool steel security chain.
If someone wants in and has basic tools they will get in. The chain stops them wandering off with your bike when they do.
Posted : 06/06/2014 10:16 am
Most common tool of entry is a spade or fork borrowed from a neighbour's unlocked shed. Thieves don't carry crowbars in case they get stopped. I've seen a few doors taken off their hinges with a spade...
Posted : 06/06/2014 10:21 am
Could you not set a massive anchor coming tbrough the floor for the real security and the shed becomes a deterant?
Posted : 06/06/2014 10:26 am
Can you put a sign on it saying no bikes kept in wardrobe over night?
Posted : 06/06/2014 11:34 am
or "cash kept in mattress, leave this wardrobe alone"
Posted : 06/06/2014 11:41 am
 huws
actuLOL
The shed will only ever be a deterrent.
It being London the garden is small and overlooked with no direct access from the road. I’m hoping that a trellis on top of a rickety fence with roses growing on it should keep out most opportunists. If they’re so determined to have got that far they’ll then have to contend with a (hopefully) well-made wardrobe, a ground anchor concreted in underneath, an almax chain and some part dismantled bikes. There will likely be a cheap sacrificial bike kept lightly locked in the garden too.
I’m looking at revision 3 now that has a wider single door.
Posted : 06/06/2014 12:59 pm
What you really need is decoys in the garden, I recommend a couple of bedside tables and a standard lamp.
Posted : 06/06/2014 1:00 pm
4stick you clothes in there and keep your bikes inyour bedroom.
Posted : 06/06/2014 1:03 pm
The only way I'd fit 3 bikes in there, is if Narnia was behind a coat.
Posted : 06/06/2014 1:07 pm
You'd get all five of these in there, and still have room for the hatboxes, photo albums and a few copies of Razzle:
Posted : 06/06/2014 1:28 pm
 huws
As it seems to be shed week on STW I thought I should update my outdoor wardrobe thread now it's finished.
And for all those who doubted 3 bikes would fit. I YOUR FACES! 18mm to spare on the length and at least 50mm on the width. 😀
Posted : 28/09/2014 12:12 am
You go want a diagonal on that door though otherwise it will drop.
Posted : 28/09/2014 3:00 am
Marvellous, but I'd recommend getting some locks....
I'm thinking about a shed to house a motorbike and this has given me some food for thought, so thanks for that!
Posted : 28/09/2014 8:08 am
 huws
Is it really likely to drop? It's a single sheet of OSB. Although that sounds sarcastic it is a serious question.
Locks are in but hidden in the joints between the cladding.
Posted : 28/09/2014 10:16 am
I built this with less detailed drawings than yours
Where is that? I like the look of it. How much did it cost you to build? Got a similar idea planned...
Posted : 28/09/2014 10:54 am
Hi Konabunny
YHM
[url= http://www.homeaway.co.uk/p734714 ]My wooden house[/url]
Posted : 28/09/2014 11:18 am
Hi Konabunny
YHM
My wooden house
Must cost a fortune in varnish 😉
Posted : 28/09/2014 11:26 am
Not as much as it looks Jamie, believe it or not we don't bother varnishing the fire engine ( anymore )
Posted : 28/09/2014 11:34 am
Page 2 / 2
