crap new car featur...
[Closed] crap new car features
Didn't BMW's have low friction tires and self drying brakes?! low friction tyres?! Obviously, they think their customers are thick as pig sh1t as well as sh1t drivers. Apparently, indicators are an optional extra on BMW's, they are now obsolete as no one ever had them fitted.
Posted : 14/10/2009 10:06 am
how is this 'progress'? - what was so bad about a 'normal' handbrake?
An automatic handbrake means no requirement for including and fitting a mechanical linkage. The software can be included within the car's control system. From a driver's point of view, I'd prefer to have a manually operated hand-brake. Of course, a handle could be fitted which mimics a conventional hand-brake.
Posted : 14/10/2009 10:08 am
i assumed it would just release when i tried to pull away...
nope.
i lost count of the number of times that sodding thing left me stranded in a que of traffic, trying to pull away with the handbrake on.
i just joined that Brian Blessed campaign, for my sanity i stongly suggest you all get onboard.
X
Posted : 14/10/2009 10:12 am
People not bothering to indicate (or look to decide if it is a good idea) [b]before[/b] carrying out a manoeuvre is a symptom of the feeling of safety and isolation created by many of these features.
You wouldn't switch lanes in front of an car/truck bearing down on you at 20+ mph if you felt in any danger of being shunted or spun into the other traffic resulting in death or injury, and yet people do it.... 🙄
sat-nav is ace, but i'm not buying one until i can get a Brian Blessed voice over for it.
I don't need a satnav but I honestly think I'd buy one just for using on my commute if Brian Blessed did the talking 🙂
Posted : 14/10/2009 10:14 am
you said it yourself, on a steep hill you have to press the button to release it, with your right hand, you've now take both hands off the wheel...
I have my left hand on the wheel (as I am already in gear) and right hand to tap the button. Job done.
It is only an issue on _really_ steep hills, steeper than most public roads (B&B driveway at Garve and maneouvering in a medieval French hill village that was more built for horse and cart than Passat estate spring to mind).
You do need to learn how to use it (the manual tells you pretty clearly - did you RTFM?) but it's pretty handy and works at least as well as a manual brake. And you get a big storage bin/ armrest in the centre console that will hold a dozen CDs instead of a medieval lever thingy 🙂
Posted : 14/10/2009 10:17 am
clubber; then get on face-book, and join the group. this thing needs support, we can make a difference!
i don't want flying cars, or a jet-pack, or free limitless energy from seawater, i want a Brian Blessed voice over for a Sat-Nav i don't have, and don't need!
soul-rat; the thing wouldn't even release on the flat - i had to be in neutral, with my foot on the brake before it would release.
clutch down? - in first? - noreleasey.
b*stard thing. good riddance. i fear the day they become standard.
Posted : 14/10/2009 10:19 am
Whats the problem with low friction tyres? Ever heard of different rubber compounds? If you can have softer compounds for performance use then harder compounds can be developed that last longer and reduce fuel use. As long as you design the profile and tread correctly they'll still be safe.
And the self drying brakes - it is an electronic system that very briefly touches the pads onto the discs to force the water off, but not enough to provide any noticeable braking force. Voilà, you have brakes that respond the same in the wet as In the dry.
Both good ideas, don't you think?
Posted : 14/10/2009 10:22 am
ahwiles - sounds like you had a faulty one, or were doing something wrong. (My Passat is an 07 plate BTW, the dealer said something about the very first ones not being terribly good but it was quickly sorted)
Posted : 14/10/2009 10:25 am
Yeah, that doesn't sound right at all. I drove a Volvo with an electronic handbrake and thought it was ace, apart from the switch being a bit too far for me to reach to put it on. Just press the go pedal and it releases, no problem.
Posted : 14/10/2009 10:28 am
and i hope it goes without saying that the passat handbrake was totally useless for handbrake turns in the snow...
Posted : 14/10/2009 10:35 am
 juan
I really do love this thread. Makes me love my 106 even more.
All of those automatic features are to compensate an obvious lack of brain/thinking.
Oh and to had useless weight to the car. I says eventually keep the abs (but this one can be replace by training) but get rid of everything else. If you can't use a map/a gear stick/a light switch/windscreen whipers/ and so you really shouldn't be in a car.
Posted : 14/10/2009 10:44 am
...no
Posted : 14/10/2009 10:51 am
So you think saving money on fuel and good wet weather braking are not good things?
[slaps forehead in complete amazement]
Wow.
[/slaps forehead in complete amazement]
Posted : 14/10/2009 11:05 am
Do you honestly think that I can't do any of those things just because the car has the option to do them for me?
I'm not convinced that you are safer in your 106 driving along trying to read map while you're adjusting your wiper speed, turning on your headlights, changing radio station and peering through a fogged up windscreen.
[b]Manual features (for the clever people):[/b]
[size=1](pic from http://www.ashwooddesigns.me.uk )[/size]
[b]Automatic features (for people lacking a brain):[/b]
[size=1](pic from http://www.hippyshopper.com )[/size]
Posted : 14/10/2009 11:12 am
Juan, I don't think auto wipers and lights add any weight, it's just another program in the ECU. No, they aren't essential, but neither is electronic ignition, independant suspension, folding seats, stereo's, syncro mesh gearboxes, power steering, fog lights, interior lights, padded seats, carpets, headlinings. But cars have most if not all of them. It just makes things easier, and if designed well, add to the safety and comfort of a vehicle so that the driver can concentrate on driving rather than fiddling with controls.
I personally couldn't see the point in auto wipers and light but then I drove an Astra with auto windscreen wipers and thought it worked really well. So, well, in fact, I hadn't noticed the system working. I could just see properly all the time. I certainly missed it going back to my own car.
Posted : 14/10/2009 11:14 am
 Rich
GrahamS, I did chuckle at your analogy. 😆
Posted : 14/10/2009 11:51 am
 Xan
you said it yourself, on a steep hill you have to press the button to release it, with your right hand, you've now taken both hands off the wheel...
why are you pressing the handbrake button at all. I've had the car for 4 months and not touched it once??? Are you putting on the autohold button to teh left of the gear stick after putting on your seatbelt and before trying to pull away???
Posted : 14/10/2009 11:58 am
 juan
Well never get my screen fogged up I can adjust the heating to blow hot/warm air on the screen to get it de-fogged. Map I usually plan my trip ahead. Worst case I pull over and have a look to a map or "shocker" ask people for help/directions. If I have to use my wipers it means light are already on. I can't give a damn about radio station as once again i change the cd before I start the car.
All of the above just render people lazy and oblivious of their surroundings.
To be fair all of what you describe is hardly changed/tune while driving. Head lining have a point in terms of safety if you are hit from the back buy someone. I was in a mate car once with electronic fancy whippers and they where just mad. Car got some drop of water from the condensation in a tunnel and they start working "until the water on the sensor dried" because obviously the sensor is out of reach from the wipers.
I drove WCA fancy merc once and it was buy far the worst driving experience i ever had. I almost crahed it on the car park because the car decided to go forwad on it's own. I had no control on plenty of stuff I had to think about how I would indicate as you have about 3 different mode (note I am not sure indicate is the concern of std merc drivers) plus I was so shield out from the outside world I found that dangerous.
Posted : 14/10/2009 12:10 pm
You looked like you were loving it when you drove out of that car park! 😉
I'd imagine you just weren't used to 400bhp and an auto box after doing, ohh, 30 yards from the ****ng space!
Posted : 14/10/2009 12:18 pm
Xan - i was using the rectangular button to the right of the steering wheel. the button was about the size of a playing card, sort of.
once more;
to release the 'handbrake' i needed to be in neutral, with my foot on the brake.
if a sensible person had designed it, it would release automatically as i pulled away. but clearly it was designed by a moron. and again i demand to see him beaten to death, with a cricket stump.
clutch in and 1st gear = no release.
where did i leave my cricket stumps?
X
 juan
Well that was a nervous grind 😉
Plus 400bhp on a 2 tonnes car doesn't give that much in terms of weight to power ratio 😉
Posted : 14/10/2009 12:21 pm
So you have to fiddle about with knobs and levers to switch on the heating and direct it at the windscreen.
Whereas I just say [i]"Demisting On"[/i] and it turns on front and rear demisters, turns on the AC, whacks the heat to maximum and directs it at the window. Dealt with. And I didn't even have to take my eyes off the road.
No no it doesn't. I still know it's dark, even if I don't have turn a little dial to make the lights come on and I still know it's raining even if I didn't push a little stick to make the wipers come on.
To expand my previous analogy - are you unaware that your clothes are dirty because you use an automatic washing machine? And would a wooden wash dolly get them any cleaner?
Posted : 14/10/2009 12:35 pm
 juan
Graham your analogy will only work if you car was taking you somewhere without any intervention of your part except turning the ignition on.
Which is hardly the case.
Posted : 14/10/2009 12:39 pm
No I think it stands.
A washing machine still requires "driver input". You still need to separate your load, put in the correct amount of detergent and softener and then choose an appropriate cycle and temperature.
So you're still in effective control of the "journey" to clean clothes. It's just that most of the repetitive manual boring bits are taken away.
Posted : 14/10/2009 1:06 pm
There's something to be said for the "de-skilling" argument, but IMHO it has more to do with maintaining the car (mechanics only replace sealed units half the time rather than fix something) than driving. I can choose whether to turn the lights on as I see fit or leave them in auto, normally I leave them in auto. If I want to override it for some reason (lights on in low sun for example) then I can.
Posted : 14/10/2009 1:15 pm
 juan
I think it does not 😉
Once your washing machine is turned on you don't have anything to do. On the contrary to your car. The "preparing stuff is what you do before getting into your car, decided where to go which route to take where to stop for petrol (unless you let your super fancy car do it for you 😉 )etc etc.
But once you turn your car on it doesn't drive itself 😉
Lets agree to disagree
[url= ]Grahams'car[/url]
[i]Heart-Rate Monitor
Volvo's Personal Car Communicator monitors the cabin and pulses a light on your keyfob if your car has an unexpected visitor inside. TV ads show a woman approaching her S80 in a deserted parking garage, seeing the warning and hightailing it away. The thought of having this feature is scary in and of itself — not for fear of being carjacked, but because we wonder what sort of paranoia would drive you to want it.[/i] 😀
Posted : 14/10/2009 1:26 pm
I really like my auto wipers as it means that on those time that you are passing a large truck/lorry/coach and it suddenly throws up a lot of spray the wipers clear it.
Nope never seen a car where the sensor is out of reach of the wipers as it would never work now would it.
And how is reducing the amount of extra things the driver has to think about whilst driving a bad thing?
Posted : 14/10/2009 1:33 pm
You're being a bit overly literal with my analogy here I think. The point is that the process of washing clothes involves a number of decision making and manual tasks. Automating some of those tasks doesn't mean my clothes are any less clean.
Surely the whole point of the electronic revolution is to try to remove trivial, repetitive and mundane things so we can spend more time doing more important things.
Even on your "manual" car I suspect you don't spend a lot of time worrying about the maintaining the correct oil pressure, managing the valve timing or whether you should have the choke in or out. All of which are genuinely skilled tasks that have been "dumbed down" by automation, rather than turning on the headlights which was already a dumb task.
Fair enough. Surrendered like a true frenchman 😉
Posted : 14/10/2009 1:50 pm
Auto wipers and auto lights are unnecessary and offer no advantage over manual operation, as they are not subtle/fuzzy enough in their operation.
My eye/brain/hand respond more quickly than the 'auto' function on either.
Mine are used manually and I wouldn't actively look for a used car with either those or electrically heated/operated seats.
Good Modern Features:
ABS
Heated Screens (for icy days)
A/C (for de-mist -and occasionally cooling)
Trip Computers (trip distance, fuel consumption and approximate distance remaining quite useful, average speed not...)
Power Steering
Posted : 14/10/2009 1:51 pm
 Xan
once more;
What I am trying to say is if you press the auto hold button once at the start of the journey the car does exactly what you described. Handbrake goes on when you bring the car to a complete stop and the releases without touching any bottons once you get the car to bighting point. No need to touch the button next to lights ever
Posted : 14/10/2009 1:52 pm
 Olly
can some one clear something up for me pleease 🙂
"when you brake, most cars loose this energy as heat, on the new audis, we save this energy, and use it to recharge the batteries, we call it recouperation" (all said in an apple mac users voice)
question.
WHEN did it become nessecery to recharge a car battery above and beyond the alternator (or dyanmo on a diesel iirc)
if you need to add extra charge to a battery, you need a new battery?
saving energy from the brakes in electrical form, useful in a hybrid, yes.
As useful as a chocolate teapot on a conventional car?
Also, auto handbrake is a solution, to a problem, that doesnt exist.
im gonna file it in the same box as parking sensors, as people who cant park/feel where the corners of the car are, are likely to be the same people who cant hill start?
Posted : 14/10/2009 2:29 pm
I think the audi thing is that they don't have an alternator and use this system instead as they know that most audi drivers drive so close to the car in front that they are constantly having to brake 😉
Posted : 14/10/2009 3:13 pm
 5lab
[i] don't like the way my car has one-click to unlock drivers door & two to unlock all doors. It's fine in principle, but the car then locks all doors when moving and when you remove the key from the ignition at your destination it's supposed to have remembered whether you one-clicked or two-clicked and open the correct number of doors. But mine very rarely does and so the passenger door & boot generally don't become unlocked. Which results in passengers trying to rip the door release off until I tell them they have to pull it twice to unlock it. SOunds trivial, but is annoying.[/i]
if its a ford, press and hold both lock and unlock on the keyfob for 10 secs. Indicators should flash, then the single-door-lock-thing is turned off
Posted : 14/10/2009 3:38 pm
The alternator uses crank power to generate electricity, and the amount of power drawn from the engine can be altered by the alternator depending on how charged the battery is or what sort of elec loads are present.
And the load on the crank can be quite large, using more fuel.
Audi (and a few other manufacturers) recover braking energy to recharge the battery so that the alternator does not have to take energy from the engine, and hence less fuel is used.
IIRC dynamos haven't been used for decades, a normal alternator will do just fine on petrol or D.
Posted : 14/10/2009 3:40 pm
[i]my old 1985 metro had five different speeds of intermittient wipers as well as normal and 'disco'.
I really liked that (Devon has at least twenty speeds of drizzle or rain!) and have never driven another car with it. [/i]
My Ford has [b]7[/b] speeds of intermittent plus normal and fast! But on the plus side it's got the usual heated windscreen which is ace.
Posted : 14/10/2009 3:55 pm
[i]if its a ford, press and hold both lock and unlock on the keyfob for 10 secs. Indicators should flash, then the single-door-lock-thing is turned off [/i]
I'll try that on my Transit 🙂
Posted : 14/10/2009 4:06 pm
I didn't know that - impressive if that's right.
Regenerative braking is a very old concept - at least as old as electric rail power..... just that the automotive marketeers have been slow (100+ years?) in the uptake.
Posted : 14/10/2009 4:08 pm
"I was in a mate car once with electronic fancy whippers "
I don't know whether you should be admitting to that on open forum, juan!
Posted : 14/10/2009 5:27 pm
I'm a complete Luddite and look on all this tosh in cars as being more to go wrong and just an unnecessary drain on the battery (OK, I admit the electronics probably don't use much). Not really got over my suspicion yet of this new-fangled electric heater thing on the rear window.
But Volvos - they haven't yet mastered the technology of basic on/off switches, have they.....lights always jammed on.....!
Posted : 15/10/2009 8:26 am
Never liked the idea of electronic handbrakes - i like the fact that the handbrake is a mechanical item that will work if the engine/electrics go for some reason.
First time i came across an electronic handbrake was when i had to drive my boss to a meeting, using his company car - Ford Galaxy. first lights i stopped at were on a very steep (up)hill - handbrake on, to release he said you've got to have the clutch down (it wont release if your on the bite point) and have your foot on the footbrake. blooming difficult to release the handbrake, find the bite point and get on the gas quickly - in a strange car while on a steep hill, without stalling the darn thing.
but the most useless feature was demonstrated to us when me and my mates where on as Land Rover experience day in a Disco3. the instructor demonstrated the emergency brake feature - you hit the handbrake button while moving, and it brings the car to an emergency stop automatically (while declutching too so you don't stall it)
that seemed useless - who, in a emergency is going to remove a hand from the steering wheel, find the handbrake button - rather than just stamping on the brake with your foot?
Posted : 15/10/2009 9:14 am
The problem with automation in cars isn't the automation, it's just that it's so stupid sometimes. Consistently stupid I can deal with.
Posted : 15/10/2009 9:20 am
It is indeed, for about 30 years they've had automatic voltage regulation where it maintains a set level of charge in the battery and any loads are compensated for, more recently they've added the ability to monitor things like ambient temperature to adjust the voltage expected from the battery due to chemical reaction differences etc.
Incidentally, on the automation thing, my auto wipers are about the best thing I've ever had in a car (unless the window gets greasy, then they go a bit mad). Auto lights are a pain in the neck - I know others have been "flashed" by cars passing through very short tunnels/bridges and under particularly well shaded trees where a normal human would have the common sense to leave the lights off rather than flashing the car in front and/or apparently braking in front of people.
Posted : 15/10/2009 9:55 am
Never had one myself but my dad has one on his car and it just releases automatically at the bite point. I think the clutch/footbrake bit is just when you start the ignition.
This does raise the point though, that part of the reason some people don't get on with in-car automation (or gadgets in general) may be that they either don't read, or don't understand, the manual.
(I looked for a Ford Galaxy online to check, but naturally Ford charge you for a paper copy, rather than say offering a free PDF download 🙄 )
I know others have been "flashed" by cars passing through very short tunnels...
They do come on when you go through tunnels and big bridges. But they stay on for about 30 seconds after that, so it doesn't look anything like a "flash" IMO.
Posted : 15/10/2009 10:25 am
Page 3 / 4
