Correct bulb for an...
[Closed] Correct bulb for an elderly MagLite.
I was led to believe that the following bulb would be the correct one for my elderly MagLite torch. "MaglLite Mag-Num Star II xenon bulb". MagEUbrueckner-automation.de Model number LMXA201L Part number107-000-706
However, when I fitted it I found that instead of a clear torch beam there was a large circle in the middle of the beam that was black making the torch useless. Is there a bulb that will present a proper beam
Regards,BrickyBrian
Posted : 23/12/2020 12:20 pm
I thought everyone converted them to LED's? (not cheap, but as a torch come baton, some ppl prefer to keep them)
2017 video so better option maybe available
I have to ask, 30second in he focus's the torch and you get a black circle, you don't have that option on yours?
Posted : 23/12/2020 12:38 pm
That’s what happens when you turn the head of the torch to get a ‘wide-angle’ beam, you turn it in to ‘focus’ the beam to get a bright spot in the centre - that’s always been the case with Maglights, and is the same with all flashlights with a ‘zoom’ option, which is, in my opinion completely useless. Either buy a light with a smooth flood beam, or get one with a brighter centre spot and a flood ‘halo’. I’ve got finger-sized flashlights which use a 3.7v 14500 Li-ion battery that are brighter than a 4xD-cell Maglight, and a lot easier to carry!
Posted : 23/12/2020 12:54 pm
That's the only point of a Maglite these days though, it's 'just a torch' when you're saying a sentence which ends with the word "... officer".
Posted : 23/12/2020 2:21 pm
I lost a bout of arm wrestling with the wife last week so I knew my grip was not what it was but your Post reminded me of the torch focus mechanism and I got a pair of grips out and found that it did address the black round bit so many thanks.
Pity replies are not automatic or have I not worked that out either?
Posted : 23/12/2020 2:39 pm
Converted mine to LED a few weeks ago - from memory it was £7. Much whiter light and very useful to keep next to the bed as a "torch".
There appeared to be many types of LED bulb but once I checked the existing bulb it came down to a single option.
Posted : 23/12/2020 3:02 pm
Yup, led bulb from eBay for my mini maglight. Probably wasn't financially sensible but didn't want to throw it away. Beam and burn time much better.
Posted : 23/12/2020 10:48 pm
That’s the only point of a Maglite these days though
They're great if you don't want a bright torch. It may sound odd but if you're working in low light environments then a modern led torch is awful but an old AAA maglite gives enough light to be useful without ruining your night vision when you have to turn it off.
Posted : 23/12/2020 11:30 pm
 hugo
Fixed it for you!
"Making the legally justifiable metal baton useless"
Surely, no-one has them for their light emitting ability in the days of LEDs and quality rechargeable batteries?!
Posted : 24/12/2020 6:33 am
