Connecting my MBP t...
[Closed] Connecting my MBP to my TV
I could find this out with a bit of research but I'm sure someone can reply in seconds on here.
I want to hook my MacBook uptop the TV so I can play iPlayer etc. what lead do I need (it'll be connecting into HDMI on the TV).
THanks
Posted : 09/01/2012 11:27 am
Can't help on the connections i'm afraid but does Airplay not work for iPlayer? Got an iPad?
Posted : 09/01/2012 12:18 pm
has your tv got a vga port? I use that with a converter deely for the monitor port on the mbp though the hdmi route would be a bit neater so interested if its possible
Posted : 09/01/2012 12:21 pm
If it is a new-ish MBP, get a converter from the DisplayPort to HDMI and just plug it in...
Pretty much anything with an i5 or i7 will work just fine. Mine is a Core2Duo so works but has no sound.
Rachel
Posted : 09/01/2012 12:23 pm
If it's a non-unibody MBP:
[url= http://www.amazon.co.uk/Premium-HDMI-Cable-Gold-Metre/dp/B000GDI6FC ]DVI to HDMI Cable[/url]
Also, you will need to run the audio out from the headphone socket to phono inputs on either your amp or TV if it has composite in. So a [url= http://www.amazon.co.uk/Hama-3-5mm-Stereo-Phono-cable/dp/B00006J6IM/ref=sr_1_5?s=computers&ie=UTF8&qid=1326108555&sr=1-5 ]3.5mm jack to phono cable[/url] will be needed.
Thing is, without knowing the model of your MBP, this is all pointless ๐Ÿ˜‰
Posted : 09/01/2012 12:26 pm
Hi, thanks for the replies guys - this is the model if it makes much difference:
MacBook Pro 13inch 2.4GHz (Intel Core 2 Duo, 8Gb RAM, 250Gb HDD, NVIDIA GeForce 320M graphics)
Its the mid 2010 one and is the aluminium unibody
Thanks
Posted : 10/01/2012 9:31 am
Ignore my reply then, as Rachel has the appropriate advice.
Posted : 10/01/2012 11:05 am
Hi thanks all, I've gt one of [url= http://http://www.amazon.co.uk/2m-DisplayPort-Cablesson%C2%AE-Adapter-Supports/dp/B00675Q2CW/ref=sr_1_sc_1?s=electronics&ie=UTF8&qid=1326722261&sr=1-1-spell ]these[/url]
Works a treat, both video and audio through the one lead ๐Ÿ™‚
Posted : 16/01/2012 2:59 pm
