Concept2 PM repairs
[Closed] Concept2 PM repairs
It looks the main board on my PM4 has given the ghost. The middle button on the right hand side no longer works. No signs of dirt or corrosion. Tried resets, firmware updates but no difference.
As Concept2 rowers on here are popular anyone recommend a repair man?
If uneconomical to repair has anyone experience of the PM5 and is it worth the upgrade over the PM4?
Posted : 19/01/2016 10:29 pm
Hi, my pal knows his stuff - I'll send this on to him.
Posted : 19/01/2016 11:23 pm
Before he gives a longer reply, I was reading about pm5s this morning - more functionality but less reliable. stick with PM4. What model is the rower, D?
Posted : 19/01/2016 11:26 pm
Model D.
Only info I could find on the PM5 was USB and backlit. PM4 had been faultless until now.
Posted : 20/01/2016 12:02 am
He says;
I've disassembled and reassembled PM2 and PM3 monitors before. Often the button contacts just need a good clean with isopropanol. On the PM3 I also bought a new LCD screen and replaced that. Worked like a charm. LCD screen was only £20 or something.
Posted : 20/01/2016 8:14 am
There's a C2 Facebook group called concept 2 logbook if you want more geekery
Posted : 20/01/2016 8:15 am
Jimmy,
Does your mate do repairs? I've lent my elderly C2 to a mate, who's just told me that the monitor screen has failed (PM2) and I'm not sure it's worth getting a new unit on a ten year old machine.
Posted : 20/01/2016 9:39 am
He says;
That was my first thought so stripped it last night and it was clean as whistle inside but gave it all a good clean with IPA anyway. Whilst it was apart tried the rubber buttons from other positions on the one that isn't working and still no joy although all the others work fine.
The computer and display still work it's just the middle button that doesn't which is normally the down scroll button in the menus so whilst I can still row I can't cycle through the menus to view items such as splits.
I've had a search and can find spares for nearly everything apart from the mainboard which I assume is at fault as everything else works.
Posted : 20/01/2016 10:09 am
drlex - Member
Jimmy,
If the screen has failed it is just a matter of opening up the case, Remove the mainboard screws, lift out the screen and rubber key pad and unplug the ribbon cable.
Plug the new screen ribbon in place, locate the screen on the lugs, fit the rubber key pad, mainboard and screws and refit the case. Takes about 30mins being careful.
[url= http://www.ebay.co.uk/itm/Concept-2-PM2-monitor-replacement-LCD-display-screen-and-rubber-keypad-brand-new-/291661340626?hash=item43e85edfd2:g:OjYAAOSw5dNWmlWs ]New screen for PM2[/url]
Posted : 20/01/2016 11:22 am
Give Joe from Southern Gym Repair a call 07880 707 314
He will hook you up
Posted : 20/01/2016 12:39 pm
You can also replace PM2 with a more recent model, I believe. He has a model C with a PM4.
If you're in or near Sheffield I'm sure he'd help out.
Posted : 20/01/2016 10:11 pm
Looking like I carry on with the non working button and unable to review my workouts as the boards are no longer available unless I chance on a PM4 going for spares on eBay. Alternatives are purchasing a PM5 or using something like Rowpro. The later is more appealing as it's visually more stimulating than a monochrome display and has training functions too.
Anyone use Rowpro and if so how does it perform i.e. is it reliable bearing in mind it will be used in a cold, damp garage. I have either the choice of PC or Mac to run it on.
Posted : 22/01/2016 3:32 pm
craigxxl,
Thanks for the advice and link; good luck with yours ('Fraid no experience of RowPro to offer).
Posted : 22/01/2016 4:38 pm
I've been using RowPro (currently v4.000 on a Win7 laptop) for >5yrs, I reckon it's worth the money.
Interface isn't the greatest, the 3D graphics are basic and it sometimes fails to start (Task Manager -> manually stop the RPEng process).
On the good side: [s]pre-programmed intervals[/s] (just checked, I've been saving the good ones from the [url= http://www.concept2.com/indoor-rowers/training/wod ]Workout of the Day[/url]), custom intervals, graphs showing performance and target zones (pace, cadence, HR), training plan generator, online racing, ability to export workouts to SportTracks and thence to Endomondo.
You can get a license key for a 20-day free trial period at the [url= https://www.digitalrowing.com/ ]Digital Rowing site[/url].
How reliable is your computer in a damp garage? 🙂
Posted : 22/01/2016 5:31 pm
